Question about SunFire V480 UltraSPARC III (A37WBPF408GRB) Server
Sunfire v480 when powered on not showing anything on monoitor server was working last 4 years without any problem
  • 145 Answers
Dear,
If your server came up without key board and monitor on last boot, you wont get anything by connecting monitor. you have reboot the server by making user, input device=keyboard and output device=monitor you can see this value by using eeprom command from os you set this value eeprom input-device=keyboard eeprom output-device=monitor
Posted on Oct 16, 2009
My laptop stop recognizing my external harddrive
chances are its no good , external HDDs in plastic cases don't last very long , its the constant plugging in and unplugging plus any wretching
will cause it to break , I myslef have 3 of them that no longer work
ranging from those reasons .
Feb 23, 2013 | Antec Computers & Internet
Please could you tell me where is the location of de EBCM from de pontiac sunfire 1998? Thanks....
i believe it is located under the left side of the drivers feet on the wall. (or side of car) it says ETS on the side of what looks like a hard drive and nothing else around. i believe that is the EBCM but i have no proof. There aint anything else around so i suspect it being it. I have a 98 sunfire too. but these damn EBCM were known from the start that they would ******* quickly. Be happy you lasted as long as you did. The ebcm costs around 350 new . i hate car computers. my car made it 13 years and 290000 kms without it burning out. and i used my ABS. cheers
Oct 15, 2010 | Pontiac Sunfire Cars & Trucks
Engine turns over, but will not start
gas line could be crushed or clogged up. but first try the battery might be dead try changing it, the starter could be messed up, or the ignition relay. try the relay before buying a starter. if at last the dont work i would have a code reader put on it and see if anything shows up the reading with cost u but will save some time
Mar 23, 2010 | 2005 Pontiac Sunfire
My sunfire subwoofer starts making humm noise after a couple minutes while listening music,,, I have to disconnect and connect back, is something that involves equipmenrt adjustment?....thanks
Try plugging the unit into a clean power supply without anything else on it. I had this problem for years and eventually resolved it by moving the system to a different room that has three power circuits - the sub is now on it's own circuit and I don't have the problem anymore.
Nov 12, 2009 | Sunfire True Sub MK II Subwoofer
Belkin F5D9230-4 won't allow a connection to M Exchange server
Login to your Belkin router and check to see if there is a firmware update available for your specific model. If so, download and install it as this may resolve the problem without doing anything else. (Be sure to save your configuration first)
The specifications for a F5D9230 state that it supports VPN passthrough so you shouldn't need to configure anything in the router itself. It may be necessary to open a few incoming ports but only as a last resort.
Would you also reply to this post and specify...
  1. What OS are you running on your pc?
  2. What VPN client are you using on your pc?
  3. Ask the administrator of the Exchange server if they're using PPTP or L2TP for VPN connections.
Another option would be to use OWA (Outlook Web Access) to access your email if it has been installed on the Exchange server.
Aug 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Kodak Easy Share z712 IS not detecting charged battery
I have the exact same camera almost a year too. It is a total "swinka" on batteries. About 10-15 shots on super ni-cads, and quits without warning.
A pair of Energizer 7X gave me near 500 shots. Much cheaper but still ...
So 4 months ago I bought a charger and 2 rechargeables. Charge one while using the other one.
I may get 70-90 shots per charge on these lithium-ion rechargeable batteries, without flash.
Testing the batteries without a load doesn't really tell you anything.
What's the reading? Should be well over 4 volts when fully charged. Mine show 4.2V
Jul 24, 2009 | Kodak Cameras
2003 Sundifre won't STAY running
The gauge problem sounds like the common issue on the 03-05 Sunfire instrument clusters where the stepper motors on the cluster's circuit board fail over time. It can be fixed, check out this page for more on how to get it repaired - Sunfire instrument cluster fix
Jun 16, 2009 | 2003 Pontiac Sunfire
1998 Sunfire power window problem
Probably not related to the accident. The motors are prone to wearing out and overheating. You should be able to get a new motor for about $50. It requires removing the door panel and drilling out 4 rivets, then removing the motor and replacing it. Harder than it sounds...but not impossible for the do-it-yourselfer. The way those motors work, the difference between up and down is not the wiring, it is the polarity on the two wires...which is controlled by the switch. A bad switch can also cause it to not go one way. The switch costs more than the motor. Your local auto parts store may be able to test the switch and motor for you. You can also use a voltmeter on the motor connection and should see a polarity change in up/down.
Jul 18, 2008 | 1998 Pontiac Sunfire
Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
Feb 07, 2008 | HP StorageWorks ESL712e Ultrium (AA934B)...
Computers & Internet Logo
797 people viewed this question
Top Sun Computers & Internet Experts
Cosma Papouis
Cosma Papouis
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
