Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
SOURCE: ilo tv/universal remote codes
Here are some to try, mine was 0189, but there are many to try. 0051 0189 0053 0198 1070 1024 1023. I think some listed codes for Emerson work as well.
SOURCE: need codes for universal remote for ilo television
I dont know which remote you are using but you might want to try these 2 codes... 0171 and 1990
These codes are also mentioned depending on which universal remote being used ...
10180 10171 10171 10179
Good Luck.
SOURCE: need tv code number for 32"LCD Dynex Television for my universal
Ran a search and someone said Funai made it's codes are 0818, 0179, 0171
Someone else said it's made by Orion codes are 0236, 0179, 0463
You can try these codes hope they can help you.
SOURCE: Emerson Jumbo universal remote not working with Insignia LCD tv
The code is under Sansui. It's code 135. Don't ask why. But it works and fully functional.
SOURCE: Curtis International TV remote codes for universal remote
Need a Model number of the back of your TV set for one and the model of remote your comcast company is using there. There are different brands in different place's.
Testimonial: "Comcast RC1475507/02B remote Curtis model LCD2400A"
Universal remote allow you to control multiple
electronic devices with a single remote. You can use the remote to work
your TV,DVD player, cable boxes and other devices from the comfort of
couch.Philips is a popular manufacturer of universal remotes.to program a
GE remote for SONY TV,you will either need to input the device
code or perform a code search
direct entry
first.turn on your TV manually. next.press down
and hold set-up on the remote.the red indicator light will stay
lit.after that.press the TV device button to let the remote know you
wish to program a television then.enter your device four digit codes on
the remote..GE list several codes for SONY television including 0002 0006 0007 0018 0107 0114 0310 0312 0502 0601 0704 0719 0803 0806 0810 0901 0911
..if your remote needs 3 digit codes remove only the
number zero in the beginning of the codes finally.test the remote to
ensure it works.with the turned on,press the channel button and see if
the TV responds..if it is work the remote programmed and you are done,if
it doesn't work try the different code......
IF THIS SOLUTION HELPS YOU PLEASE DON'T FORGET TO RATE MY ANSWER THANK YOU
