Question about Ovens
We have a Westinghouse Gas Oven GWH 476 SNG. How
We have a Westinghouse Gas Oven GWH 476 SNG. How do we start the oven after a power failure
4 Suggested Answers
SOURCE: Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Posted on Jan 12, 2010
SOURCE: Westinghouse oven GWH 476 SLP
Hi RMSINN,
Believe it or not, the clock has to be set before the oven will light.
To set the clock, instead of using function names for buttons, we'll just call them buttons 1 through 6 going from left to right.
Push buttons 1 and 2 at the same time. You're now in clock setting mode. Push buttons 5 and 6 to make the clock go minus and plus.
Cheers
SG
Posted on Dec 25, 2010
SOURCE: cant reset clock on westinghouse 476 underbench gas oven
When I turn on my westinghouse gas oven (GOL476), it appears to ignite immediately but after 3 or 4 minutes there is a strong gas smell which lasts for sometime before it gradually disappears.
Posted on Jul 10, 2011
Need Westinghouse gas wall oven AWGB700FP manual
Request the manual directly from Westinghouse.
Jul 20, 2014 | Ovens
I have a westinghouse 476 gas oven, the oven does not turn on all the time the ignitor heats up but no gas comes out. when i take the cover off the ignitor and tap on base of oven it ignites and works...
It sound like you have a valve problem some types of ignitors have a heat release valve, by hitting it you cause this to release, I would suddjest replacing the ignitor unit but this requires a Gas Fitter that is approved, as all sorts of tests, requires specialised equipment, if you have gas central heating, the service engineer could perform the same for your cooker. remember to ISOLATE MAINS POWER if this model uses it for ignition.
Hope this has been helpful
john
Jun 06, 2011 | Ovens
My Westinghouse 668 oven turned off in a recent power failure. I need to reset the time so the oven will work. How do I do it?
A lot of the time, particularly if you haven't got a manual, it is trial and error. I normally turn the oven to on. I then watch the oven indicator light as I manipulate the timer buttons/controls. It sometimes takes 5 to 10 minutes. Just try all different combinations.
Feb 12, 2011 | Ovens
Westinghouse oven GWH 476 SLP Multifunction. The pilot cones on but not igniting ? no gas getting through
Hi RMSINN,
Cheers
SG
Sep 21, 2010 | Ovens
Cant reset clock on westinghouse 476 underbench gas oven
Sep 17, 2009 | Kenmore 33169 Gas Single Oven
F7 error code- what does this mean?
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
Display Condition Remedy
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 17, 2009 | Frigidaire 30 in. Electric Gallery Series...
Westinghouse 745 wall oven
First thing, remove the plug from the wall power for at least 10 minutes, maybe even thirty minutes and allow it to reset........ if that does not work write me at wbwill@sbcglobal.net and give more model info so I can investigate for you or check out a volunteer site, allexperts.com and you will find me there also.
Nov 10, 2008 | Ovens
Aug 20, 2008 | Ovens
Cannot turn on Oven
your oven needs a new ignitor it has to draw 3 amps or more to open the gas valve (just because it glows doesnt mean its good) let me know how you make out
Feb 21, 2008 | Ovens
Ovens Logo
562 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
