Question about GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher
Machine stops Dishwasher stops in the middle of the wash.  When the door is pushed it will restart.  Hence there is a loose connection in the door latch.  How do I fix this?
  • 25 Answers
Re: Machine stops - GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Dishwashers
The door switch need some ajusting.
Posted on Nov 16, 2007
0 characters
3 Points
My maytag dishwasher will run for a short then stop running, I'll push on the door the machine will run again then will stop again
your door is not staying latched.. imagine if it did stay running and the door came completely open, what a mess that would be. so there are safety switches that help stop the washing if the door opens. not too sure how to fix your exact washer.. but the problem is the door not staying closed. maybe you can jamm the door shut while it is running? its not the best answer, but probably the most free way to fix it
Oct 29, 2013 | Dishwashers
try re-setting it. unplug power. visually see if d/w looks clean. re-connect and run an empty short cycle ensuring door properly closed. good luck
Jul 26, 2013 | GE GSD3200J Dishwasher
The dishwasher stops in the middle of the wash cycle. I then have to push in on the door and it begins again. This happens very often, 10 plus times per wash,
faulty or loose door safety switch,,,check for mounting screws loose,,or wear on door catch,,if not loose or wear,,faulty switch,,replace.
Jan 29, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
De Dietrich dishwasher model DVF300JU2 Child opened door during wash cycle closed door but m/c did not restart,now all lights on! unable to clear/restart, tried to cancel programme by pressing 'Start' for...
try pressing stop or cancel button for 10 full seconds. If this does not work, unplug the machine for 10 minutes. While unpluged, press and hold cancel or stop but for 10 seconds, then plug machine back in. If it still does not work, test the door switch with an ohmmeter to make sure the door switch is not faulty.
Jul 12, 2010 | De Dietrich Dishwashers
Whirlpool GU2300 Dishwasher. The machine stops for long periods during the cycle. All lights go out. If the machine is opened before the cycle finishes, it will not resume. If I try to restart, the normal...
Door latch.
Open and close the door to make sure the door latch is securely fastened.
Check the dishwasher wiring for a possible loose connection where it connects to the house wiring.
Fuses or circuit breakers.
Check your house fuses or circuit breakers to make sure you have power to the dishwasher.
Thanks for contacting
Oct 24, 2009 | Dishwashers
Kenmore dishwasher blinking light
I have a solution. For Kenmore Dishwashers begining with model 587 and the flashing washing will not start.
inside the front door there are two black and two white wires that lead to the handle. this connection is an on/off saftey for the door latch and if wet will short. The light is flashing because the machine thinks the door is open.
these connections on my machine are very loose. a needle nose pliers to tighten the crimps clean the prongs recconect hard reset at breaker box and you should be ready to go.
Feb 01, 2008 | Dishwashers
Hi generally if the door is not closed on a dishwasher all functions are disabled, This is for saftey. Hence this is a cut out switch operated by the door. Try holding the door shut and seeing if the functions come to life
Sep 16, 2007 | Dishwashers
Water leakage in dishwasher? Cant turn on. Model LD-12AW2.
possible you have not pushed seal in far enough hence door not closing fully. press fairly hard and see if it then starts
Jul 01, 2007 | LG 24 in. LD-12BW5 Free-standing...
GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Logo
87 people viewed this question
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Michael Thomas
Michael Thomas
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
