Question about Roundup "" Weed & Grass Killer
Getting rid of weeds on my estate
How much round up do I need in a 100 liter water tank?.Do I apply a stronger mix to different type of weeds, the tougher type !? Please send me the answer to; What spray gun should I use to spray along a fence line.? How many square meters of round up can be sprayed if I use this 100liter tank? Please use my gmail address. cairnsee@gmail.comThanksIan Cairns.
    President:
  • 1,723 Answers
Use the info on the back of the Round Up container. It will tell you how to mix it. If you want it a little stronger, just use a little more than recommended by the instructions.
Posted on Sep 01, 2009
Want to kill grass is vinegar by itself enough ot do i add water to it
One quart of vinegar -- with 20 percent acetic acid -- mixed with 4 ounces of lemon juice will kill the above-ground portions of the weeds and grass. The foliage, flowers, buds and stems will wither, dry and die, but the weed's roots are left intact. For a tougher weed and grass kills, combine 1 tablespoon of 20 percent vinegar, 1 tablespoon of gin, 1 quart of water and 1 teaspoon of dish soap. This mixture kills the above-ground and below-ground portions -- including roots -- of the weeds.
Oct 14, 2016 | Miscellaneous
What is the mixing rate for round up to kill broadleaf weeds such as thistle, parthenium etc so that I do not kill the grass
Any round up mix that will kill the weeds will kill the grass. the only way I can think of is to tie a sponge to a stick dip in round up and apply to each weed, you will not have to cover the whole weed, just touch a few leaves.
Sep 03, 2016 | Garden
Mixing ratio roundup
Don't really catch your question, but 30 ml per liter is a good strong ratio. Some labels tell you to mix less, but not all weeds die if a weaker solution is mixed. Some more hardy weeds will not even turn brown. Also check the active ingredient grams per liter Ours are 480g/L. It differs from country to country as well as other suppliers selling it under another name.
Oct 07, 2014 | Roundup Garden
I just want to know how much of roundup to put in the tank, you use air to disperse the weed killer?
Yes I do use it, you can put about 1qt of round up for every gallon of water. This should kill your weeds, for most precise mixing instructions check the bottle label.
Thanks.
Jul 28, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
How much roundup do i put in 3 liters of water
Round up is currently offered in a few variations. If you have the "Spray and GO" or the "Spray and Go" refill product do not add water. The ratio is already correct. Likewise for the "Redy-to-Use Plus", do not add water.
If you have the "Weed and Grass Killer Concentrate Plus", the ratio is 3oz/gallon water. 3 liters of water=0.79 gallons so use 2.4 oz of this type of Round Up.
If you have the "Weed and Grass Killer Super Concentrate", the ratio is 1.5oz/gallon water so you would use 1.2 oz of product mixed into 3 liters of water.
If you have a different product and just need to work out the conversion from gallons to liters, 1 gallon=3.78 liters.
Hope this helps.
Dec 31, 2010 | Roundup "" Weed & Grass Killer
We have lost the instructions for mixing up Roundup. Can you help?
The mixture is 50-1 or about 2.6 ounces per gallon of water...
It can be mixed abit less for easy to kill weeds and a bit stronger for hard to kill weeds...
heatman101
Sep 04, 2010 | Garden
I will be applying Roundup to a large section of my lawn to kill a bermudagrass infestation. Will the Roundup work better on longer grass or a freshly mowed lawn?
Round up will work on any grass...I prefer to mix it a bit stronger when I know I am trying to kill grass... but yes it works... ask my daughter who wanted to help and spray the weeds for me and then decides to play around in the yard writing her name....:-)
It can take a week for a full killl though...
heatman101
Aug 12, 2010 | Roundup "" Weed & Grass Killer
Need to know how to mix round up and water
Annual and perennial weeds can be controlled with a mixture of 6 fluid ounces of Roundup (12 tablespoons) per gallon of water. Small weed seedlings can be killed with half this strength: 3 ounces per gallon. When using Roundup Super Concentrate, mix 2.5 ounces (5 tbsp.) with a gallon of water to control most weeds and a half-strength solution for small weeds. Roundup Pro Concentrate is the strongest solution available. Spray a mixture of 2 ounces (4 tbsp.) on weeds and half that amount of concentrate on emerging plants. Since Roundup doesn't discriminate between weeds and other plants, use the least amount of herbicide possible to protect desirable vegetation.
May 27, 2010 | Roundup "" Weed & Grass Killer
Roundup "" Weed & Grass Killer Logo
334 people viewed this question
Top Roundup Garden Experts
Nick Olsen
Mike
Are you a Roundup Garden Expert? Answer questions, earn points and help others
