If you are using a GSM SIM card or related chips, you may need to configure your device as required, you may need to contact your GSM provider. Go to Settings>More>Mobile networks>Access point names
select the APN you want to connect to and edit,
press options, then save(If you think you have editted correctly)
then apply that APN
Hope this helps
If android, go into settings, mobile& networks and make sure you have "data" enabled. If your provider allows roaming free, or if you want to pay extra, check the data roaming box. Many companies provide it free. Check your cellular/data plan with your company.
Usually simply rebooting your phone, regardless of make and model, takes care of any connectivity issues.
SOURCE: Unable to connect to internet through Wi Fi on Nokia E65
You need to "authenticate" the wireless meaning you need the password to the web signal. Your phone may have an internal software issue in which it prevents you from connecting to the internet. Contact your phone company to trouble shoot it or get a replacement phone.
SOURCE: Im connecting to my home WI fi and it says authentication failed
You will be asked for a password only if you are connecting to a password protected WiFi network.You can set a password for your Home WiFi modem and after that you have to enter the password whenever you try to connect.
SOURCE: LG Renoir wi-fi connection failure
When i try to turn on my wifi my Lg Renoir restarts ! Any suggestions on how to solve this ?
John
SOURCE: I have a samsung GT-G7722.
Check whether your security settings are match with your wi-fi router.
SOURCE: I had recently purchased Samsung
Dear Meghna
you have not mentioned the wifi router make and moel
no problem
for this you have to go to your router web admin to add your device as WPS client
this will solve the problem
for that all the models are differently configured so you have to try playing with the settings yourself, if you jumble up the settings of you wifi router there is a reset switch in all the routers that restors your router to factory settings.
if you find my information useful dont forget to vote me with the thumbsup
thankyou and take care
Gagan Gupta
This is a Windows BLU phone...
