Front door will not release after wash - Washing Machines
  • 53 Answers
Please wait for the signal and after that try to open
Posted on Jul 13, 2009
I have a hotpoint aqualtis washing machine and the door is locked how can i release it
Most washing machines wont let you open the door if there is still water in it. Try putting the drain hose on the ground to drain the water out and try the door again. If its a front loader, there may be a drain hose or outlet next to the filter cup. Usually down on the front of the machine.
Sep 17, 2017 | Washing Machines
Door latch is not unlocking
THERE IS DOOR LOOK TEST INSTRUCTION TO ACTIVATE THE DOOR LOCK UP IN THE CONSOLE. THERE IS A MANUAL RELEASE. IN THE FRONT RIGHT CORNER OF THE DISPENSOR. FEEL AROUND WITH YOUR FINGERS. OR REMOVE THE COVER TO GET A BETTER VIEW. THEY WHERE MADE IN RED, ORANGE, GREEN LIKE HEAVY FISHING LINE.
Apr 27, 2010 | Maytag Neptune MAH6500A Front Load Washer
My Electrolux ewf1090 front loader door wont open
Turn the power off and leave for 5-10 minutes then turn on. This should release the door lock the problem could be the pump drain filter is blocked clean this and it should resolve future problems.
Apr 25, 2010 | Electrolux Washing Machines
Front door does not release
press the pause/ play button. This will unlock the door
Jul 11, 2009 | LG WM2688H Front Load Washer
Lg washing machine wm-1460fhd door locked wont open
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Jun 10, 2009 | LG WM-1480FHD Front Load Washer
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Frigidair front-loader washer door remains locked
there is an Emergancy release you can pull to open the door it is either in the soap dispenser area or behind the front lint clean out door depending on your model
Mar 30, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing Machine Door will not open
it is poss that you pressure system has not released, and this can keep the door closed. Unplugging it will not cure this fault. It is also poss that you have a blocked filter or waste. Unfortunatly has you are older people I would call an engineer
Jun 23, 2007 | Ariston Technologies AW129NA 16 Lbs Front...
Washing machine creda front loader
I had the same Problem on a 17112e Creda, I took the top off and using a torch located the red plastic door release mechanism, I then pressed a white button in the centre of it and the door released. I believe that the washing machine was overloaded and auto cut out. I reloaded the machine with fewer items and it is now working.
Mar 20, 2006 | Creda W100FW Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
