Question about NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000
Glowbuoy flashes on and off after charging,hardly been used
2 years old been used about 10 -15 times charges up couple of hours
works for about 5-ten mins then just keeps going on and off till dead
  • 640 Answers
If your swimming pool light is not holding a charge, it could be that your battery pack is defective. For this particular light, you cannot change the batteries yourself. It is designed so that the housing cannot be opened by the owner. You would need to take it to a pool professional and have them change your rechargeable batteries.
Posted on Jun 16, 2010
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Milwaukee tool 18 volt nimh battery won!t charge
If the battery pack is more than 2 years old its time for a replacement. The typical charge/discharge life cycle of a rechargeable cell is 500 - 700 times and the shelf life is about 3-4 years from the date of manufacture. If the charging indicator lights up when you dock the battery on to the base and still does not work after 5 hours - its due for a replacement.
Apr 08, 2011 | Dewalt Accessories Batteries 18 Volt
I bought a glowbuoy about a year and a half ago. I have only used it 2 or 3 times. I recently went to use it. I recharged the battery but when I tried to turn it on there was no light.red light steel...
According to the owner's manual for this pool light, a blinking red light indicates that an error has occured during charging. It says that if you have unplugged and tried again and still have a blinking red light, the condition of the battery is questionable and it might need to be replaced. The only place that you can purchase these replacement batteries is from an authorized pool store or directly from the manufacturer. You will not be able to replace the batteries yourself.
Jul 01, 2010 | NRS CANTAR GLOW BUOY FLOATING POOL LIGHT...
I have a Metz 60CT4, I've had it for years and it
A new dryfit battery is delivered fully loaded. So you will not have to charge it the first time. My 5 year old dryfit battery still is holding enough energy to help me through the darker moments. I have it charged now once after an average of 400/500 flash pictures (when do you need full power with this flash?), which is every two to three weeks (normal hobby use).
Dec 20, 2009 | Metz Mecablitz 60CT4 TTL Flash
My kodak z612 only flashes once in awhile
The flash has to "charge" up a high-voltage capacitor in order to work.
As a test: try a few flash shots, but wait ten seconds between shots. It should flash 100% of the time. If not, use new Alakaline batteries and try the test again.
If all works well, see how many you can "flash" while waiting only 2 seconds... some may work, others not. You will then get a fell of how many seconds you have top wait between flash shots.
Also, use flash for subjects nearby (up to 12 feet) ... no flash beyond that. Increase the ISO setting HIGHER (3200?) so that the flash doesn't work so hard.
Results? Use fully-charged Li-Ion or alkaline batts when you need to use the flash.
Sep 19, 2009 | Kodak EasyShare Z612 Digital Camera
Digital rebel battery drain with flash only
I would suspect the batteries
Ive got an eos Rebel think its just over 4 years old
for the last year its been used every weekend for several hours 300+ pics per weekend between 2 nights I found that recently where one battery would last a night the battery was running out midway through & also taking longer to charge afterwards
2 after market replacements cost me about £10 and things are back to normal
5 years is a pretty good lifespan for a battery so its probably just getting old
Nov 29, 2008 | Canon Digital Rebel / EOS-300D Digital...
Stand by time is about 12 hours
Couple possibilities:
1. Old battery: After a couple years of use, the battery simply can't hold a charge as well as it used to. If you are using an old battery, try getting a replacement.
2. Replaced battery with a NON-Brand name: If you replace the battery with a lesser expensive pack from china, they will typically use an inferior set of cells. Use only the name brand batteries for best performance.
3. You're in a location where you cannot pick up a DIGITAL signal. If you are roaming or unable to pick up a digital signal, the cell phone will constantly be searching for a tower wasting precious energy. For best standby times, make sure you are receiving a digital signal.
4. Battery charger malfunction: If you're accustomed to charging your battery with a wall charger, try charging it from your cigarette lighter in your car or with a different charger. If it works longer after doing this, drain the battery and charge again the way you usually do. If you're back down to only 12 hour stand-by, the usual charger may be malfunctioning.
5. Make sure your backlight is not on all the time. If your phone has a setting to keep the backlight on, turn it off.
Good Luck.
Apr 21, 2008 | HTC S620 Smartphone
NRS CANTAR GLOW BUOY FLOATING POOL LIGHT 92000 Logo
431 people viewed this question
Top NRS Pool & Spa Experts
Ian Kime
Ian Kime
Tom Chichester
David Spradling
David Spradling
Are you a NRS Pool and Spa Expert? Answer questions, earn points and help others
