Tricty bindix it won,t spin pump and filter are fine it will do the wash
  • 1 more comment
  • eamonn close Nov 21, 2007
    If it was the belt it would not wash thank you. Close
  • eamonn close Nov 30, 2007
  • alrita Feb 05, 2008
    belt came off in good condition, How do you put back on
    Problem Solver:
  • 9 Answers
Sounds like you have a broken drive belt - if a washing machine doesn't spin, the usual cause is that the belt that goes between the motor and the wash tub has worn out and broken.
The usual procedure is to open the top of the unit and locate and remove the broken belt and replace with a brand new belt, the most expensive part of this repair is the labor, and it is not that difficult for most models if you have some basic tools.
Will need your specific make and model of unit in order to look up the part number of the belt and find out how easy the replacement process is, if you can leave this information, perhaps I can help more. :)
Posted on Nov 16, 2007
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Won't drain and won't spin ,makes a clicking sound
sound as though the drain pump has something hitting the impeller making the clicking noise,and the filter basket next to the pump is blocked by debris and not letting it drain
Sep 01, 2012 | Maytag MAH6700AWW Neptune Front-Load...
My washing machine dont spin or drain water can you please tell me what to do and where about are the filter in then machine/
Either your drain pump is bad or something is stuck in it. It won't spin until it drains so fix the drain pump, and it will spin. You should be able to get at the drain pump by taking off the bottom panel, or back panel.
Jan 13, 2012 | Speed Queen AWS52NW Top Load Washer
Washer won't spin
Hi hometownrock,
The washing machine may have a problem draining the water, if it cannot drain the water, then the cycle will not progress to Spin. You may have a foreign object in the Drain Pump Filter, this must be checked.
Please follow my below Tip on how to do this:
Kind Regards
* If this solution helped you, please rate it
Aug 15, 2011 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer did fill, but won't spin or drain now and the door won't open
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
Kind Regards d")
Aug 05, 2011 | Kenmore HE2 Plus Front Load Washer
My samsung washing machine J1453S is having a problem with spinning, no problem with loading water, drive belt is fine.
Hi donna sarmie,
It could be your machine is stuck on the drain cycle, and won't continue to spin, because the drain filter is clogged.
You may need to clean the Drain Filter, please find my Tip below on the procedure:
Kind Regards :-)
Aug 01, 2011 | Samsung Washing Machines
My LG washing machine model-fuzzy logic WF-s6607tc, is not spinning
The filter for your empty pump is probably clogged. The machine can't drain the water in the alloted time because it is draining to slowly through the clogged filter. The machine won't start the spin cycle if all the water hasn't been evacuated. You will need to find and clean out your empty pump filter (Probably behind a little door at the bottom of the machine.
Jun 23, 2011 | LG Washing Machines
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
