Question about Kenmore HE2 Plus Front Load Washer
I have to hold the power button for several minutes for it to turn on. is the button messed up and how much will it cost?
Lg phone won't turn on. It pulls up the LG logo, after several minutes it makes the start up tone and the blue TracPhone page appears, that's where it stops
You can try a factory reset, I don't know the model, but here is the usual LG reset routine
Ensure the device is powered off.
Press and hold the Volume Down button then press and hold the Power button.
When the System recovery screen is displayed, release both buttons.
From the System recovery screen, select Factory data reset.
Note Utilize the Volume buttons to highlight and the Power button to select.
Select Yes to confirm.
Note Allow several minutes for the reboot process to complete.
Note To set up the device after completing the factory data reset, refer to Initial Activation and Setup.
Sep 22, 2017 | LG Cell Phones
Tip
Factory Reset for Tungsten T5 handhelds
If you've set a password on your device, any hard reset will automatically become a Factory Reset. With this method, you'll enter a password and then perform a hard reset.
1.On your handheld, launch the Prefs application. From the list that appears, under General, select Security.
2.If the Password box says "Unassigned," tap the box and create a password for your handheld.
3.Once the password has been set, hold down the Power (on/off) button on your device.
4.While holding down the Power button, turn over your device so that you can see the back of it. Still holding the Power button, use an unfolded paper clip or a similar small object to gently press the RESET hole (where?). Keep holding the Power button throughout.
5.While still holding the Power button, the screen will show the Palm logo and a progress bar will appear at the bottom. Then the circular Palm Powered logo will appear. Release the power button when you see the Palm Powered logo.
Keep holding the Power button during this screen. When you see this screen, you can release the Power button.
6.A message will appear warning that you are about to erase all the data stored on your handheld. Press UP.
7.You may see a screen that says "Reformatting in progress. This may take several minutes." This screen will remain for several minutes (up to 10 minutes). Don't do anything while this is happening.
8.If you performed this reset correctly, the screen of your device will go blank after several minutes, and you will not be able to turn on your handheld. The charging LED will not light up. (any other activity - such as the Palm OS logo and then the Applications launcher appearing - means the reset was performed incorrectly; try again)
9.Your device will appear "dead." To wake up your handheld, perform a soft reset.
on Mar 11, 2010 | Cell Phones
Why is the lock light on
Look on the front for the buttons that say lock press them at the same time and hold for several seconds the light should go off. If that won't work try to turn off the power for several minutes then restore power.
May 14, 2014 | Kenmore 24" Built-In Dishwasher with...
Lamp or Power issue Panasonic PT56lcz70
I would think that the fact that when you held the power button in for a long time that would give you a hint! If the power button is making a poor contact there will be a small surge of power and some parts of the internal circuits will respond(indicator lights, for example). Try REPLACING THE ON/OFF BUTTON.
Jan 22, 2013 | Panasonic PT-56LCZ70 56" HDTV
Can't turn tv on stuck scanning channels
Something simple to try: remove the set from power and any box etc in line to it for several minutes and then power things back, cannot hurt and may help
Dec 23, 2012 | Sharp Televison & Video
The printer takes several minutes to print one page all ink cartridges are full and paper tray is full it just started doing this
Please try below two resets and let me know the performance.
Power Drain:
  • Turn OFF the printer, disconnect the power cable from backside of the printer and from wall outlet.
  • Press and hold the Power button for 60 seconds.
  • Connect the cable and turn ON the printer.
Partial Reset
  • Remove the power cable from back side of the printer while its ON.
  • Press and hold "#" and "3" button, while holding them both insert the power cable and release the button after 10 seconds.
  • If printer turns OFF, press power button to turn it ON.
Regards
Riztech
May 23, 2011 | HP Officejet 6500 Wireless All-in-One...
How do you set the clock on a yamaha stratoliner?
When you get to the clock, push and hold the button. The hour will flash - bump the button to go up. To get to the minute, push and hold again to get to the minutes, bump to go up. This is the method for the few Yamahas I have messed with although I've never messed with this particular model - but it's worth a try..
Scott
May 17, 2011 | Yamaha Stratoliner S Motorcycles
My Sabre LCD TV is blinking red and green on power button and will not come on
My TV just did this 2 days before Thanksgiving. I just messed with it and fixed it today. Unplug it from the power source for atleast one hour. Plug it back it. Hold the power button til constantly flashes red and green. Wait at least one minute while it continues to flash. Turn it off. Flip the big power source button on the back to off && then on. Then hit the power button on the side, and it should turn on. Worked for mine. Hope it helps.
Aug 31, 2010 | Sabre LCT371BKA LCD TV
Wheel does not respond
Turn the hold button on and then off then hold down the center button and the menu 'button' for about 8 seconds. This should reset the iPod. Try this several times. Also try turning hold on and off several times as it may be stuck as well. If all else fails see if you can 'restore' it in iTunes.
If the clickwheel is actually messed up; you may need to have it replaced.
Sep 21, 2009 | Apple iPod nano 3rd Generation
Unit is not coming on.
unj plug the unit for 15 minutes and then try to turn it back on. Is there a reset on your unit? What type of unit is it.
Dec 21, 2008 | Maytag MCD2257HES Side by Side...
Kenmore HE2 Plus Front Load Washer Logo
fordexpert
Kristen Denison
Kristen Denison
Level 1 Expert
Jim Chinnery
Jim Chinnery
Level 1 Expert
