Question about LG enV VX9900 Cellular Phone
How can i get my contact numbers when the charging port doesnt work an phone is dead
If you used backup assistant on your phone, then they should be saved on your service provider online account, such as at www.verizonwireless.com. If you have an account online, there you can sign into your account and select your phone and select an option to your contacts. Hope this helps out some.
Posted on Jul 13, 2009
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Aug 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
My apple iPhone4 will not charge and the battery is dead....bought new cord to charge but still will not charge up! Help please.....
Hi June, You need to take it to a repair shop, i would say the Power port is damaged that's why it's not charging
Mar 28, 2014 | Apple iPhone Smartphone
Hello, I have Sony Ericsson W595, 4 days ago the phone shut down it self. I can open it anymore, i am pouring in the charge but it doesnt get charge the phone like dead person it doesnt work i dont...
if that is not phisically damaged then most likely this is software problem and as this is new phone u have warranty cover so don't get panic contact service centre and problem will be solved free of cost .
Aug 06, 2011 | Sony Ericsson XPERIA X10 Cell Phone
THINKING IT WAS THE BATTERY I BOUGHT NEW BATTERY . WILL NOT CHARGE SO I PUT BACK OLD BATTERY AND STILL WILL NOT CHARGE. USUALLY IT WILL BEEP WHEN I PUT BACK IN CRADLE. BASE LIGHTS ARE ON /CHARGE INDICATOR...
Hello
This is either a problem with your charger or the charging port of your phone
Try charging your phone with another charger that works with you phone to see if it works,if it doesnt then you need to change your phone battery charger
Also you should wedge your battery at the bottom with a folded piece of paper because the battery might have become loose and doesnt fit in properly into its compartment so by doing that you will be providing better contact between battery and battery terminal.
If the above still doesn't make the battery charge then the problem is from the charging port of your phone.
The charging port is where you connect your charger into,it is probably damaged and needs to be looked into and replaced.
Oct 05, 2010 | Cell Phones
C651 not charging
This is what to do. Try and find another charger for that phone and see if it solves the problem if it doesnt then you a have something wrong with you battery or soemthing wrong with your charging ports.
You can Clean charging port on the phone with a brush and methilated spirit to remove dirt.
After cleaning it,if still not charging, that means the charging port on the phone is faulty and shoud be replace.
Thanks for contacting FixYa
Aug 23, 2010 | Motorola Mobility C651 Cellular Phone
My phone wont charge...
Hi
First thing to do is try and find another charger for that phone and see if it solves the problem if it doesnt then you a have something wrong with you battery or soemthing wrong with your charging ports.
Thanks for contacting FixYa.
Aug 23, 2010 | Samsung Memoir SGH-T929 Cell Phone
Reverse Voltage, dead USB port
First take a look at the usb port. Can you see 5 gold pins that are raised a bit as they move back? Sometimes 1 pin will get bent a bit and doesn't make good contact, causes this problem.
Oct 14, 2009 | Samsung I7500 Smartphone
When plugged in, it doesnt charge, doesnt show that is plugged in, and will not connect to laptop software either
If the cord is fine, then chances are the usb port in the phone is dead. Which results in the phone being dead and worthless.
I'm sorry about that. It is actually a common problem.
Oct 14, 2009 | RIM Blackberry Curve 8300
The charger port on my lg voyager is frayed. If i buy anew charger port, is it easy to install? i thought it was my battery, so i bought a new one on Amazon. put the battery in and it worked fine. i have...
you have done well in troubleshooting it. if you have tried another charger on it and its not charging, then you have to replace the charging port. if you are good opening phones, then replacing the charging port will not be a problem. the chrging port is usually not screwed, it is just fixed to the board by contacts. look for the replacement part and change it. other wise, take it to a phone technician with the new charging port and replace it. good luck!
May 27, 2009 | LG VOYAGER VX10000 Cellular Phone
Env Phone wont start up
Well, in my experinece, one of two issues. You said your charger port is bad. Thats not good. It will give you enough juice to barely turn the phone on and it goes out. MOST phones will do that. IF you know your charger port works, try a new battery, if it doesnt you have to get the charger port fixed as it will just constantly act as if the phone is dead, even if you put a new battery in it, it will blink on, touch a button eats up the battery bars and dies. craigslist.org usually has alot of cell phone repair people on it. depends on your community.
Jan 17, 2009 | LG enV VX9900 Cellular Phone
LG enV VX9900 Cellular Phone Logo
57 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
