Question about Dishwashers
My Candy CD112 Dishwasher stops halfway through cycle
My Candy CD112 Dishwasher stops halfway through the cycle, the led flashes quickly, when I open the machine I notice that the detergent door has not opened and there is water in the bottom. I have checked all the hoses and the salt level they are all ok, the machine still drains so not sure why it is stopping any ideas?
  • 105 Answers
SOURCE: Candy Nova CD112 dishwasher
not enough water in machine
do you have hi or low pressure
when machine is washing try adding a extra litre of water manually eg milk bottle or jug
note the sound of washer before and after
if this improves then that is problem
Posted on Feb 24, 2008
  • 641 Answers
SOURCE: LG LD-2160 dishwasher
Get an aqua vac and suck out the water (with the dissolved detergent)from the salt container. Refill it with water and repeat the process couple of times. Fill the container with water and salt and it should be fine. Good luck !!
Posted on Jun 28, 2006
SOURCE: dishwasher not running
just got this, and have same prob, i have run through all checks
Posted on Jan 29, 2008
jaylex
  • 417 Answers
SOURCE: dishwasher and salt
run a few times with nothing in the machine on full washes it may be that the salt you are using is not suitable for that machine also check that you have the machine plumbed into the hot water outlet.
Thanks J
Posted on Feb 16, 2008
faggly
  • 74 Answers
SOURCE: Instruction booklet for Candy Nova CD112
Hiya...click on this link.... it will ask you to download this file and save... this is the manual.....please note you will need an adobe reader programme to read and print it off!
http://service.candy-domestic.co.uk/manuals/pdfs/CD112.pdf
If you have any problems go direct to the site link!http://service.candy-domestic.co.uk/manuals/Manuals.aspx?Section=3
Regards Faggly
Posted on Mar 27, 2008
I have a candy cdi 3515 and after about 1/2 an hour into the programme it stops and a continuous alarm bleeping starts.
Is there water in the dishwasher when it stops?
Are you able to check if the water is normal temperature or warm/ hot?
Can you try the dishwasher in a short cycle and see if it completes the cycle?
Oct 11, 2010 | Candy Dishwashers
Hotpoint Aquarius FDW60 Machine stops halfway through its cycle & the "fast" & "delicate" cycle LED's are flashing - what is my problem?
This sounds like the heater is not energising usually means the heater has failedalthough a blocked or sticking pressure switch will cause the same problem
Apr 14, 2010 | Hotpoint 24 in. FDW60 Free-standing...
The water in my Candy Nova CD112 Dishwasher does not heat up.
your water comes from your hot side of your water but your element in the bottom might be bad
Nov 30, 2009 | Dishwashers
Dishwasher won't finish cycle
it means that your heater or board are bad
Aug 20, 2009 | Dishwashers
Candy nova cd112 dishwasher fills with water then stops working
nova cd112 this is a simple fix the machine has a electronic switch to add water to the machine it then has another switch to say the machine has water iin it , this switch is the one that is not working this is the one that turns on the element and heat the water .it costs around a tenner to replace u can find it as it is connected to the element via a wire conection .this a a common problem of over enginearing as this switch is not needed and is not on older machine .ie this switch can only come on when the machine has water in it in other words only after the switch to put water in the machine has been on.can this go on i hope u know what i mean lol. now u can replace this yourself or get an engineer it should take an engineer no more than 10/15 mins to fix better still have him bypass this switch and u will never haver the problem again as this switch is prone to going fixthis and the machine should last years no problem as its not a bad machine not quite a bosch but better than a zanussi or indicit etc hope this helps and may i just say that i tried everything including replacing the element ,stat and cpu non of which worked before realizing it was this .i must also say before u try this. Switch on your machine on put it on a universal cycle as u hear the water going in the machine open the door and add hot water as hot as u can close the door and the machine should do a full cycle including emptying and reheating the water this proves its not the cpu ,element or stat note the machine will not do the cycle without the hot water going in at the start if it does the cycle then its 100 % this switch hope this helps and sorry for the lond explantion bye
Feb 20, 2009 | Candy 24 in. CD622 Free-standing...
Candy nova cd112
I appear to have solved this problem. Firstly I slightly adjusted the door catch on the actual machine, the strong wire bit, outwards. Then I undid the screws on the top part of the door exposing the electrics of the dial and door micro switch. I noticed that the microswitch (the small metal part pushed in and let out by the plastic arm rotated when opening and shutting the door) was dirty or rusty. I sprayed a little WD40 on this and played with the door catch a few times. I then screwed everything back in to place and the machine works perfectly. Easy and quick and a lot cheaper than the £80 I had just been quoted by a service person to come and change the switch mechanism as he called it!
Sep 06, 2008 | Candy 24 in. CD623 Free-standing...
Jennair dishwasher timer stops halfway thru wash cycle.
Try using a cycle that doesn't boost the heat. Usually a quick or china/delicate cycle. Any cycle that heats the water pauses the timer until it is done. Some machines even select this with heated dry. The sensor that controls this can go bad and stop the timer completely. If it operates for the complete cycle , look for the sensor and replace it. There is usually a wiring diagram somewhere in the machine sometimes in an envelope inside the door, control panel or behind the front bottom panel
Jul 04, 2008 | Dishwashers
Regards Faggly
Mar 27, 2008 | Dishwashers
Zanussi ZDT6252 stops 1min into cycle
You need to reset the computer on the bottom. Had the same problem with mine. The Blinking led means the heating element is bad and will not operate.
Dec 30, 2007 | Zanussi 23 in. ZDT6252 Built-in Dishwasher
Dishwashers Logo
407 people viewed this question
Top Dishwashers Experts
Mike
Marvin
Marvin
