Question about Ricoh 4506 Copier
Networked Nashuatec printer cant print after a couple of jobs
I have this networked nashuated MP 5500 printer which is being used by two users. The PCs are able to print three or four jobs but, after that the machine can not print any thing. When I restart the hub it works for another three or four jobs and then the same problem happens. i need help, please help how to get over this problem?
  • 313 Answers
Try setting on the server for print spooling and check the available memory on printer you can also go to printer properties on the server and get it to print direct to copier
Posted on Jul 31, 2009
Got my HP laser jet P1005 plugged into 1 PC prints fine. But 2nd PC is networked to it and it takes ages to print! How can I speed up send PC print job? Both PCs Only ever print single pages.
Well, that really depends upon how you are "networked". Obviously, the primary PC is USB 2.0 connected direct to the printer. When you send a print job, the PC merely starts the print job and sends it to the printer on the fly. The other PC must first spool the entire job, packet it up, send it to the network, then network sends it to the first PC, where it must unpacket it, and send it to the printer. This is definitely going to be slower than a direct connection. And if your network connections are wireless rather than wired, even longer.
Feb 19, 2016 | HP Office Equipment & Supplies
How can I set up wireless printing?
Hi Brenda,
Considering that your printer has an in-built Ethernet feature means no need for external print servers.
  • Take the printers network/Ethernet cable and then plug it into a router/network Hub.
  • Once you've connected the computer to the network,install the printers software in all the[networked] computers that will use it.
  • Now try printing.Note that,the networked computers print jobs will be printed in order received.
Hope this helps.Thanks!
Oct 09, 2011 | HP Deskjet 6940 InkJet Printer
Printer Nashuatec Aficio dsm651 I want software
user tools>system settings>admin> address book then select the user and you can scroll down or goto authentication and change the password.
if you cant get into admin try the username administrator with no passowrd or service with no passwrd
Jul 28, 2011 | Ricoh Aficio 450 Copier
I cant print it keep sayin user intervention required what does that mean
check to make sure there is no paper jam
the print job which you have sent to printer, is it the correct paper size / PAGE LAYOUT?... i.e. A4?
is this a local printer or a networked?
Lastly... if all fails Restart the printer
Mar 08, 2011 | Computers & Internet
Recently my epson 9600 pauses during a printing job for long periods, so that it can take several hours to complete one print.
Need more info.
Are you printing from a computer directly attached to the 9600 ?
or
Are you printing through a network.
If you are using a networked printer then your print job could be slowed a good bit by heavy network traffic.
Apr 06, 2010 | Epson Stylus Pro 9600 InkJet Printer
Our Ricoh MP 171 devices go offline after one
have you tried doing a local connect using a crossover cable to the printer to see if it is the printer or the 2k3 server?
I have seen this issue when terminal services are enabled on the server.
if when you connect locally to the device using x-over it still does it it may need to have the nib firmware updated, however if it doesnt I would run a packet sniffer on the network jack that the device is plugged into and check to make sure that the port is good and transmitting and receiving all packets check the network cable and replace that and if all else fails try the device on a different network port.
Jul 15, 2009 | Ricoh Office Equipment & Supplies
Ricoh Aficio MP 2510 netwrok printer all jobs from users are Acce
the reason why the job(s) at the workstation say they are completed, and there is no job at the printer, is because the user code management has been turned ON.
if you turn user code management on, and do not setup users, with user codes, then jobs will continue to run like they are now. either turn OFF user code management, or setup users in the address book of the printer.
Mar 26, 2009 | Ricoh FT5832 Copier
Print jobs stick in prnt queue
A lot of users have no idea how to change the MS Office default from US to UK .. so they have US spellings and US paper sizes (known as 'Letter' sized) .. and (of course) any Document that started life in USA keeps it's size until some-one changes it ... since Letter size is almost the same as A4 no-one cares UNTIL they come to print it ...
I'm sure you can guess the rest :-)
Yes, the Printer is looking in it's feed tray for Letter sized paper .. yes, Letter doc's will print just fine on A4 and most printers have a setting somewhere that lets it use A4 when asked for Letter (often called "automatic A4<>Letter convert" or some such)
NB. when time permits, perhaps the unfortunate users can have their MS Office apps. set to UK mode :-)
Mar 17, 2009 | Dell Office Equipment & Supplies
Ricoh 4506 Copier Logo
110 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
