Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Won't recognize color ink cartridge
I've had my original printer for awhile and it worked great, until it started not recognizing the color ink cartridge. I bought a new ink cartridge - did not solve the problem. I called Kodak and they sent me a new printhead. This also did not solve the problem. I called Kodak again and they sent me a new printer. My new printer has the same exact problem! The printer will recognize the black ink, but not the color ink. I am using Kodak ink cartridges. My color ink and black ink are brand new, never used. Is there a way to solve this problem without dealing with Kodak again? Could there be something else causing the problem or was it just my luck to get two faulty printers with the same problem?
    Problem Solver:
  • 9 Answers
This is a common problem with Kodak 5000 series and ESP series printers.
Check the silver contacts on the ink cartridges for small scratches in the center. The scratches indicate that the ink cartridges have made contact with the appropriate connections in the printer. If no marks are visible, the cartridge was not seated properly. If the contacts look ok, you'll have to call Kodak again. It's highly likely that the recertified printer you received was returned for the same problem. If you point out the fact that you are experiencing the same problem for the second time, you may wind up with an upgrade to an ESP5. Don't accept another printhead replacement as thiat will not resolve the problem.
Posted on Jul 17, 2009
    Scholar:
  • 60 Answers
It definately is a problem with ink cartridges and i can give you the link to the websites where you will find look alike ink cartridges of kodak but are actually refilled ink cartridges so as you have experienced it yourself that even a replacement printer did not help..........
Posted on Jul 15, 2009
    New Friend:
I had the same problem. I bought my color cartridge from inkjets123 or overstock or someplace like that. THey included a little pamphlet that showed a "carbon strip" in the middle of their new ink cartridge, with instructions to scratch it off with a sharp knife if the printer kept prompting you to replace the cartridge. I did so, using a utility knife. I used a straight motion as if I were cutting carpet. I then swabbed it with rubbing alcohol on a qtip. Amazingly, it worked, but the best solution, I am sure, is NEVER buy another kodak inkjet again! They guzzle ink and then nonsense like this happens.
Posted on Nov 24, 2012
Well I have no solution to add; I am frustrated enough to try the warm water and q-tip trick.
Posted on Feb 05, 2012
  • tx_moriah
    tx_moriah Feb 05, 2012
  • 788 Answers
I know this sounds stupid, but are you removing the plastic tape of the cartridge before installing them.?
Sometime a few Q-tips and a worm glass of water helps alot.
If the unit has sat for a long period of time with little or NO use, sometimes the lik cluggs the thru ports.
Get a pair of gluves, some news papper a Rag, Q-Tips and worm water.
Remove the 2 Cartridges and be gental.
Holding the Cartridge in your hand, dampen a cloth and wipe the bottom gentally. ( You should see colored ink on the rag. )
If all else fails, bring the faulty cartridge to Walgreen's and ask them to check it for you.
If the cartridge is NO Good, they will let you know. !!
Good luck, I hope you get it working.
Remember to remove the safty tape off the New Cartridges.
Readers, Please rate your Technician's
Thanks.
John Ray
Posted on Jul 13, 2009
  • John Ray Jul 13, 2009
    Thanks.
    John Ray
    Thanks.
    John Ray
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
Epson Stylus NX415 does not recognize ink cartridges. Cartridges are Epson 88's. Worked for awhile, and then stopped recognizing them. Tried powering down the printer, cleaning the cartridges, turning...
Epson Printers are sensitive in terms of Ink Cartridges.. The latest Epson Printers does not have ink reseter.. Ink reseter are already built-in on the ink cartridges.. The problem on this printer is when you have a cartridge on your printer, let say, 30% of the ink level, even though your ink is new, and you change it without using the right ink replacement method, it will recognize your ink as a 30% ink level. When your ink level drops to 0%, but you have remaining 70% of the ink, it does not recognize it anymore. The chip on the ink cartridge is already registered as an empty cartridge.
May 28, 2011 | Epson Stylus NX400 InkJet Printer
Colored refill ink cannot be recognized
It is called e5 error.
For Canon cartridges, after 4~5 refills, the color cartridge cannot be recognized by printer.
In this case...there is no solution so far...just replace with new cartridge.. that's it.
(To avoid e5 error, you need to make sure "plug out" the power, before take out your cartridge for refill. Yes... "plug out" the power cords!!!!
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 06, 2011 | Canon PIXMA iP1300 Printer
Doesn't recognize the color ink cartridge
Good day!Your cartridge is the problem..even if its new or original if the printer never detected or sense your cartridge's presence..then that error will appear..
So,try to change a while or borrow if you have friends there just for reading or proven the problem..
mastergani
Apr 03, 2010 | Olivetti wireless All-In-One InkJet...
My F4280 HP all in one wont recognize the refilled cartridge.
hello, attempt to clean the sensors on the bottom of the cartridge with some kind of solvent and q-tip. If the ink cartridge has sat awhile before you refilling it then the jets will be clogged dry and you will need to purchase a new one for your printer.
Oct 02, 2009 | Office Equipment & Supplies
My IP90 stopped recognizing the instalation of the color ink tanh
Take to a ink refill store and ask the to test on there machine(cartridge world etc) it will tell if cartridge is good or not! hope this helps!!!
Jun 21, 2009 | Canon PIXMA iP90 Mobile Printer
Lexmark x5470
Let the ink settle in the cartridge for awhile. Make sure no ink is on the outside of the cartridge which adversely effects the signal to the printer.
Apr 14, 2009 | Dell Dimension 4500 + Lexmark Z35 Printer...
Why won't my CX9400F recognize Epson ink cartridges
The Epson CX9400F printer seems to require replacement of all the color ink cartridges, even if only the Black is empty.
I print almost exclusively in Black, but with my first change of Black, I was forced to change all the color. At the time I thought Epson did not provide completely filled color ink cartridges.
Just yesterday, I replaced Black and the printer complained it did not recognize the rest of color cartridges. So I replaced all the other color ink cartridges and now it works fine.
You might want to check out www.clickinks.com for cheaper, mail order alternatives which are Epson ink compatible, if you are not in a hurry.
ew
Feb 23, 2009 | Epson Stylus CX9400 Photo Printer
Hp 2610xi not recognizing HP 97 color cartridge
If you look in the 96 (Black) cartridge loading area you might see that the retention spring has poked a hole in the circut board. I am now either trying to replace the ink cartridge holder or purchace a new printer. I have about $70.00 in new ink that I can't use now. The 2610xi worked great until the spring popped out of its holder.
Jun 10, 2008 | HP Photosmart 2610xi All-In-One InkJet...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
3,891 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
