Question about Cell Phones
Same problem as far as I can tell its either the phone writing empty blocks of data to the memory card or its memory checksum is faulty. if these phones could be hooked to a computer this could probably be fixed, but its a total failure on samsungs dont buy this phone if your gonna text alot.
I have a guess W15514G2.. and I want to change the day in the watch, In the first click I am able to adjust Date on one side and month on the other side, the next click makes me adjust the time. But what about the Day? How do i adjust that? Help me
Posted on Jul 13, 2009
What are the dell beep codes for dell inspiron m5010
Table 3-1. POST Beep Codes
Beep CodesErrorProbable Causes
1Memory refresh failure.Defective system board.
2Error occurred in first 64 KB of main memory.Faulty DIMM or defective system board.
3Read or write error occurred in first 64 KB of main memory.Faulty DIMM.
4Timer on system board malfunctioned.Defective system board.
5Microprocessor error.Defective microprocesor.
6Gate A20 failure.Defective system board.
7Microprocessor-execption interrupt error.Defective microprocessor.
8Video memory read/write error.Missing or faulty video adapter.
9ROM checksum value does not match value encoded in system BIOS.Corrupted system BIOS program or defective system BIOS chip.
10NVRAM shutdown register read/write error.Defective system board.
11Cache memory error.Defective microprocessor or cache card.
1-2Video adapter failure.Faulty video adapter.
1-3No monitor connected.Loose video cable connection or defective video cable.
Jun 17, 2014 | Dell Inspiron 15 Laptop Computer- Intel...
How can I transfer usb data to my sd card without a pc?
I suspect you'll have to delete some stuff to make room for proper operation. One of the features of flash memory, including SD cards, is the need to spread wear from writing amongst the memory blocks, because you can only write to a memory block so many times before cells wear out and go bad. The controller is probably unable to find a lightly used set of blocks large enough to do the transfer. Delete the oldest files you can part with first until you've made enough new space to accommodate the files you want to move (these are likely to be in lightly used blocks). If you can get your hands on computer that is able to read files from the phone, you can save the condemned files there before deleting them from the phone.
Jan 07, 2014 | Samsung Galaxy Centura SCH-S738C...
Startup 6 beeps
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
Loose video cable connection or defective video cable.Faulty video adapter.
13
May 15, 2013 | Samsung NP-148 NP-150 N148 N150 N128 N145...
Long beep at startup
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
Dell 4 beeps
POST Beep Codes
How to fix Dell BIOS 8 beep error.
Probable Causes
Error
Beep Codes
Faulty DIMM.
5
Gate A20 failure.
6
7
8
9
10
Cache memory error.
11
12
13
14
May 09, 2013 | Dell Inspiron 1018 Notebook
The PC does not start.Only it beeps and a red light blinks,also fen is not working.
here are some of the basic codes, depending on which BIOS you have...
Also you do not indicate which fan? I would guess you mean the main Power Supply (PS)? In which case it could just be you need to replace the PS.
Here is a link to some other codes as well...
http://www.computerhope.com/beep.htm
AMI BIOS ERROR BEEP CODES
  • 1 Beep - Memory Refresh Failure (check memory)
  • 2 Beeps - Memory Parity Error in first 64KB block (check memory)
  • 3 Beeps - Memory Read/Write Error in first 64KB block (check memory)
  • 4 Beeps - Motherboard timer not functioning (possible motherboard replacement)
  • 5 Beeps - Processor Error (may need replacement Processor)
  • 6 Beeps - Gate A20/keyboard controller failure (possible motherboard replacement)
  • 7 Beeps - Processor Exception Interrupt Error (may need replacement Processor)
  • 8 Beeps - Display Memory Read/Write Failure (reseat or replace video card)
  • 9 Beeps - ROM checksum Error (replace BIOS chip or motherboard)
  • 10 Beeps - CMOS shutdown Read/Write error (possible motherboard replacement)
  • 11 Beeps - Bad Cache Memory - test failed (replace cache memory)
Phoenix BIOS ERROR BEEP CODES
Phoenix BIOS beep codes are a series of beeps separated by a pause, for example:
beep --- beep beep --- beep --- beep beep would be 1-2-1-2
  • 1-1-4-1 - Cache Error (level 2)
  • 1-2-2-3 - BIOS ROM Checksum
  • 1-3-1-1 - DRAM Refresh Test
  • 1-3-1-3 - Keyboard controller test
  • 1-3-4-1 - RAM Failure on address line xxxx (check memory)
  • 1-3-4-3 - RAM Failure on data bits xxxx of low byte of memory bus
  • 1-4-1-1 - RAM Failure on data bits xxxx of high byte of memory bus
  • 2-1-2-3 - ROM copyright notice
  • 2-2-3-1 - Test for unexpected interrupts
I hope this helps.
Mar 29, 2011 | HP Computers & Internet
Vids/music problems with lg viewty
Viewty should be able to play 3GP and Mp4 format, what I think is probably you are inserting new memory card.
Here's the problem with new memory card.. You can't fill it with data (songs, videos, pictures) by PC before you insert the new card into your phone. What will happen is, that your new card will be containing those data but unreadable by your phone.
What you should do now, is backup your data inside the card to PC, then format the card by your phone or by PC, after it is formatted (clean), insert it once to your phone (the phone will write some system data and make folders to the empty memory card), after that, you can fill it with new songs and videos, and your phone should be able to read them. FYI , some phones need videos to be insert to video folder and picture to picture folder. But in this case, I think you just need to format your memory card and do as I instructed above. Hope that helps.
Jan 07, 2009 | LG KU990 Viewty
Sandisc 2GB micro SD Memory Card;SanDisk Wirelss Lan SecureDigital Card...
i have a 15 in 1 portable memory reader and it comes up with an error. Says please put disk in. Then it says disk is copy write protected and copy write must be taken off.
Aug 03, 2008 | Cell Phones
How to remove write protected memory card
How to remove write protected memory card pls help me
Jun 13, 2008 | Nokia 6680 Cellular Phone
Memmorycard
first of all what type of memory card are you talking about? SD for example has a little plastic piece that moved to one side blocks the card from writing and to the other side allows writing data on it... but i dont know what type you have... would you tell me to help better?
Feb 16, 2008 | Electronics - Others
Cell Phones Logo
22 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
