My mouse doesn't move properly it sticks, then jumps and I find it hard to stop it where I want to.
  • 716 Answers
Is It A Ball Mouse Laser Mouse??
Posted on Jul 13, 2009
    Sergeant:
  • 361 Answers
Go on control panel --(go run and type control) click hardwere .. then set mouse property.
How do i stop my computer curser from jumping every time i move my mouse?
Mouse needs more Cheese, Seriously it may be the Mouse not working 100% Thats all I can suggest . New Mouse from approx £ 8.00 up
Mar 14, 2015 | Anyware Computers Computers & Internet
Wireless mouse and stick won't work
Have you tried to add a mouse pad under it. I have a capricious mouse myself that has to be on a pad to work fine. If you don't have a pad just try it on a dark surface, no glass that's the worst one...
It can also be a simple battery matter, distance is also important depending of the communication technology in use.
good luck
Nov 28, 2013 | Trust Wireless Optical Mouse Mi-4150K
Hello I'm using a hp compact nc6320 and my sensor
Do you use an external mouse or the built in touchpad/pointing stick? If you use an external mouse try another and see if the random movement disappears.
If you are using the touchpad/pointing stick for day to day use, plug in a mouse if you have one spare, go to the control panel in whatever version of MS Windows the laptop is running and do the following:Start Button > control panel > mouse (goto the hardware tab on the window that opens) choose the 'synaptics' device > properties > driver > choose 'disable' then ok. This should disable the touchpad if the random jumping stops then it is probably a physical problem with the touchpad/pointing stick, you may want to contact HP and request a repair.
Link below is to manuals for your laptop model:
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=135&prodTypeId=321957&prodSeriesId=1839146
Good Luck
Jan 10, 2013 | Computers & Internet
Logitech wireless remote not working
if the mouse uses a ball on the bottom then remove the ball from the mouse and cean all of the dirt and dust from in the compartment.
this can cause the mouse not to work properly
Jul 25, 2009 | Logitech Cordless Mouse
MOUSE PROBLEM
run a virus checker through i had the same problem with the moving mouse thought i had a good virus checker but somehow it got through hope this helps regards Jim
Apr 23, 2009 | Computers & Internet
Mouse sticking
AAHHHHHHHHH, quite often optical mice have PTFE non-slip pads under them which aid the physical movement of the mouse. Look under the mouse - are they missing? If so, spares are hard to come by, and optical mice are relatively cheap nowadays. Try using the mouse on a surface thats even and flat (a 210gsm bit of card may do it). Hope this helps
Mar 12, 2009 | Logitech Cordless Mouse
Laptop keep sticking/jumping
sounds like its not able to process everything make sure you dont have a virus taking up your memory
Feb 11, 2009 | Toshiba Satellite M45-S165 Notebook
Jumping mouse cursor
Elsamma, If you are positive keeping the cable stationary prevents the problem try this: Try holding the mouse connector stationary and wiggle the cable. If the problem occurs then the connection between the mouse connector/cable is defective, due to the low value of this mouse the fix would typically be replacing rather than repair. If that doesn?t work try wiggling the mouse connector where it plugs into the PC. If this causes the problem to reappear then either your mouse connector or the PC socket is damaged. Try another mouse and if the problem goes away, again the fix would be to replace the mouse. If a new mouse doesn?t fix the problem then there is a good chance the PS2 connector is damaged. At this point I would purchase a USB mouse which should solve your problem Let us know how things go and if you need any more assistance.
Jul 11, 2007 | Logitech -9536890403 Mouse
Fixing optical mouse problem
try a diff mouse. try a diff usb port
Jul 31, 2017 | HP OPTICAL SCROLL MOUSE (8131)
Computers & Internet Logo
188 people viewed this question
David Payne
David Payne
