Question about HP Pavilion a450n PC Desktop
PC monitor warning error of PC entering power saving mode
When i open my PC ,monitor only shows this warning "PC entering power saving mode"
and Monitor shows black screen. Can't do anything...
    Scholar:
  • 117 Answers
Hello mamaykyaw,
The steps below are for Windows XP.
Go to Start>Settings>Control Panel>Power Options(double click)
The Power Options Properties window will appear
Power Schemes. Ensure in the dropdown box it is set to Home/Office Desk. Set Turn Off Monitor to Never....Set Turn Off Hard Disks to Never.
Then go to the Advanced tab. In the two dropdown boxes at the bottom, ensure that When I press the power button on my computer is set to Shut Down
And When I press the sleep button on my computer is set to Stand By
Under the Hibernate tab, uncheck Enable Hibernation. Then click Apply then OK.
I Hope this helps you out. Have a nice day
Posted on Jul 13, 2009
  • Miles Jul 13, 2009
    You may have to access Safe Mode to make the changes I listed above. When you press the power button to bootup the PC, start tapping the F8 key. A screen labeled Advanced Boot Options will appear. Move the highlighted selector to Safe Mode and press enter. A gray box will appear telling you that Windows is currently operating in Safe Mode. Just click YES and the follow the steps I listed.
    Here is the answer according to Hewlett-Packard: For flat panel displays.
    http://h10025.www1.hp.com/ewfrf/wc/docum...
    And also turn off your screen saver:
    Start>Control Panel>Screen Saver tab. In the drop down box select NONE then Apply then OK.
  • 615 Answers
Dear Sir,
Welcome to fixya Support,
We will Help You
By analysing u r problem i am sure that u r monitor is correct,But problem is by RAM. So just take out the side cover of u r CPU and take out the RAM clean it twice and reinstall it. if it not helps check with another RAM I think it deffinately solves u r problem.
good luck
fixya Customer Support
Chandrashekhar
    Sergeant:
  • 361 Answers
1 some time we can get same problem in cpu fan error . look your cpu fan fitting is lose or not? and change afan to check once time. thanks (nepal)
    President:
  • 627 Answers
It is CPU overheating problem, Go out and get some composite paste which is keeping the temp down
I open my computer today but suddenly the monitor says " entering power save mode" and its stuck there. ive tried to do simple ways to fix but still nothing. can someone help me? im using windows 7
Switch off and remove the power cable then put in the power cable again and switch on again...try to disable the power saving mode once it is on.
Apr 05, 2013 | Dell Computers & Internet
When I turn on the monitor, I get an error message: "Warning PC entering power saving mode", then it turns off.
Unplug your dekstop from the electricity then press and hold the power button on your desktop for couple minutes with out no power cable attached to it then let go of the power button then connect your desktop back to electrical outlet and press power button once that should give you display once it turns back on you can go into your power saving options and turn off power saver mode as its conflicting with your LCD sometimes this can occur if you have Norton antivirus installed
if after doing the power drain and still get same message then you can try using a different monitor if you have one for a test.
this issue is not with your monitor but with the PC has been stuck in sleep mode but the power drain should solve your problem.
Mar 01, 2011 | HP Pavilion F1503 15" LCD Flat Panel...
Monitor displays "warning pc entering power saving mode
Hello
Sounds like to power settings were set too low. Restart the PC, before it gets to Windows press F8. This will send the PC into SAFE mode. You'll get a menu of which SAFE mode to select, just select SAFE mode with networking. Once in SAFE mode, go to START, Control Panel, Power Options. From there select new settings. Since this is a desktop, I would make the settings very long. Good luck
Mar 03, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
My monitor shuts down after one second.
Dell monitors automatically go into power-save mode after a preset amount of time when the computer is inactive. The Dell monitor will go completely black, instead of showing a screensaver. This doesn't mean that your Dell computermag-glass_10x10.gif has shut down. Instead, this allows your monitor to essentially turn off until it's needed again. You can change how long it is before the Dell monitor goes into power-save mode by changing your display settings.
  1. Step 1 Press any key on your keyboard or move your mouse. Either will turn off power-save mode. Alternately, you can press the power button on your Dell computer tower or laptop.
  2. Step 2 Press any key a second time if the monitor goes from power-save to stand-by mode. Stand-by mode allows the screensaver to appear.
  3. Step 3 Enter your user name and password into the login prompt if your computer requires a login. Press "Enter" to begin using your Dell computer.
  4. Step 4 Change the display settings on your Dell monitor to prevent your monitor from going into power-save mode prematurely. Right-click anywhere on your desktop and choose "Properties." Click the "Screensaver" tab and press "Power." Beside "Turn off Monitor," choose a time amount from the drop-down list and press "Apply."
Nov 13, 2009 | Dell Dimension 3100 PC Desktop
Monitor warning pc enter power saving mode
Are you using usb keyboard and muse. if so your usb ports are dead
Jun 16, 2009 | HP Pavilion a450n PC Desktop
WARNING: PC ENTERING POWER SAVING MODE
sounds like a faulty power supply unit
Mar 24, 2008 | HP Pavilion a450n PC Desktop
Pc entering power save mode
I am having the same problem . The system is starting up and th epc entering power save mode. I have a Hp pavilion f1503 model monitor. I hit the power off button on the power surge to shut the entire power off. I turn the power surge button back on. Sometimes it works. Or have to hit the power on button to reboot.
Dec 12, 2007 | HP Pavilion a810n (PP164AA) PC Desktop
Monitor automatically clicks into power saving mode
I have an LG W2261V, and an old Sharp LL-T19D1-H. The PC runs both just fine, and the PSU has plenty of power. Unfortunately the LG handles power save mode very differently, where the LG would not switch on after entering this mode unless reset (unplugged, PC rebooted, etc). Extremely frustrating, as the old Sharp never had any problems exiting its own power save mode. The LG would enter this mode based on the monitor power settings (in whatever power scheme you are using) in the screensaver tab in display properties. I fixed this by selecting "Never" for "the Turn off monitor" property. I guess this is a warning to those who may wish to buy a new LG monitor, but want to use a power scheme to turn off the monitor.
Oct 01, 2006 | LG Flatron L1951S 19" LCD Flat Panel...
HP Pavilion a450n PC Desktop Logo
1,761 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
