Question about Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard
Slow booting I'm using an intel d185eea motherboard and my system boot is slow.What are the cause of this and what solution do I have for the problem?
    An expert who has answered 20 or more questions within one hour.
  • 147 Answers
Use hibernate not cold boot? You will need to enable hibernate, then on closedown hold the <shift> button. When you hold the <shift> buttton the sleep mode is replace by hibernate. There could be issues with PIO disk acess with hibernate.
Known problem with disk drives running in PIO mode not UDMA. This causes slow data to internal drives. No solution but a work around is to uninstal the hard drives software: reboot: WIN-XP 'discovers new hardware and re installes hard drive(s). Make sure cable is 80 way not older cable 40 way. Do NOT mix hard drives and CD/DVD drives on same cable as disk drives as it slows down disk data (speed) rate. I have 3 hard drives and one DVD/CD drive, the disks on IDE0 run as UDMA 5. The mixed cable IDE1 runs UDMA 2.
Posted on May 31, 2010
  • 231 Answers
Hi if you are running Windows XP you can also go to:-
Start, all programs, and click on "Start Up"
Here you will find a list of programs that start auotmaticaly. You can turn these off by rigth clicking each one and selecting "Cancel" another help is to "Defrag your hard drive on a regular basis.
Regards mistyman
Posted on Nov 17, 2007
Check your start up files what gets preloaded get software like reg cure it will show what is been loaded on sartup
My PC has D101 GGC INTEL motherboard, and 2.66GHz Intel P4 processor and DDR SDRAM 1GB. My system starts but hangs very frequently and is extremely slow. Sometimes it doesnt boot and usually takes very...
when booting long press the delete button to enter bios, when your in, select the boot section and disable quick boot, then save and reboot, bios will check the memory or ram of your desktop.
after the test when the system reboot the same and didn't said ram fail or test fail the ram is working good.
now I'm sure that your running out of memory or lack of memory,
try to clean up your disk or delete unused files, or update the memory
probably your ram is ddr 1 pc333/400
Mar 21, 2011 | Intel D101GGC Motherboard
How to Fix Windows Slow Boot
It often happens that Windows boots slow. This can happen due to a number of reasons such as the presence of too many start up programs. However, the major cause of such boot delays is the registry corruption in Windows. Whatever the cause, the Windows slow boot is intolerable and there must be done something to fix it. Here you will find simple techniques which are tested in PCs around the world.
Step-1: Repair and Clean Windows Registry
You might not be aware that there is something very important inside the Windows. And due to the corruption in this internal component of the operating system, we experience Windows slow boot. The element which is referred here is the Windows Registry which contains information about all computer programs including the boot sector programs and services.
In order to have a quick Windows boot there must not be any corruption in the Windows registry entries. The best way to speed up a slow booting Windows is to use some authentic PC optimizer and registry cleaning tool.
Step-2: Reduce Start Up Items
Whether you are using Windows 7, Vista or XP, you must have some programs in your computer that start with the Windows start up. Sometimes too many programs running in background result in Windows slow boot. You can disable these programs through a start up manager tool in the PC optimizer software. Although there is a way to disable such programs through the "msconfig" function in the Windows but it is not recommended for all types of users since they can mistakenly disable the important Windows services necessary to run the entire system.
Step-3: Run An AntiVirus/AntiMalware Scan
Although not all boot problems are caused by the viruses or malwares but it is wise to run scans through these security softwares. However, it must be kept in mind that the registry repairing scan must be run prior to such scans for the best results to fix Windows slow boot.
The above guidelines will surely help you to make Windows boot faster. If you are looking for a complete PC Optimizer and Registry Cleaner software for a quick fix of your problem then it is highly recommended you run the Intel Software Partner, RegInOut scan here to fix > Windows Slow Boot.
on Aug 27, 2010 | Computers & Internet
Have a Intell D865PERL getting either 6 or 7 beeps when booting, can't be sure which. System will not boot but just beep with PS2 keyboard installed but will boot with keyboard removed. BIOS is version...
It's likely a bad keyboard- try using either an usb keyboard or another ps2 keyboard- if it works and boots normally with a different keyboard, the issue was the bad keyboard. If not, then the ps2 port has gone bad. (you could still use usb)
Feb 01, 2011 | Intel D865PERL Motherboard
Ver, very SLOW when booting up! Sometimes the
BIOS System defaults are best used for installing a new operating system or performing diagnostics. Bootchecks and memory checks due to settings on antivirus/antispyware programs are notorious for causing slow boots. In most cases these scans are unnecessary. Saying that, it is also possible you have acquired a trojan. Run a full system scan and if you have a clean machine, disabling the bootchecks and memory checks will speed up your booting. If after doing this your boots are still slow, tweak your BIOS as follows per Intel:
  • Set the hard drive as the first boot device in the boot order in the BIOS setup (Boot > Boot Device Priority menu).
  • Enable Intel® Rapid BIOS boot in the BIOS setup (Boot menu).
  • Disable Hard Disk Pre-Delay in the BIOS Setup (Advanced > Drive Configuration menu).
  • Disable system functions and features if you do not need them. Examples include:
    • Legacy USB - this must be enabled if you use a USB keyboard or USB mouse outside the Windows* environment (Advanced > USB Configuration).
    • Unused I/O ports, such as serial, parallel and IEEE-1394 ports (Advanced > Peripheral Configuration menu).
    • Event logging (Advanced > Event Log Configuration menu).
    I hope you find this solves your problem. All the best! Greg
Nov 10, 2009 | Intel D845GVSR Motherboard
Gateway E3600 (Intel D845PT MB) won't boot after MS Update
This error comes when your motherbord not read properly harddrive.
for that first reconnect both connection to harddisk.Power cable and ide or sata cable.
Change SATA or IDE cable then check.
Pull cmos cell from motherbord for 10 minutes so all settings are factory defaults.
Then when you power up the computer press F1 or F2 or "del" key then you can see bios screen.
Make sure hardddrive detect in bios.
Set first boot device as harddrive.
Then check.
Let me know if you need further assistance.
Nov 06, 2009 | Intel Desktop Board D845PT Motherboard
Sume time not booting os.then windows opening very slow
Hi there
you might have a failing hard disk or motherboard, try clear c-mos battery and try again . Also replace any faulty ram and other hardware that may cause the problem , unplug FDD, CD ROM and other devices , replace keyboard and mouse
Nov 12, 2008 | Intel D101GGC Motherboard
Problem software not support motherboard
when the message say that incorrest boot divice means the boot order is wrong so go to bios by pressing the key F1 or F2 or F10 or DELETE when the computer try to boot up then go to boot order and change the order for the first your hard drive save it and restart the computer but if there is no operative system you have to re install it that message say it can not find the operative system on the boot order devices
Dec 31, 2007 | Intel Motherboard
Mother board problem
Steps to improve your bootup time..
You can trim unnecessary start-up programs file using msconfig from the Run menu and unnessary services from Control Panel/Administrative Tools/Services.
Slow start and shutdown can be a symptom of Spyware infection.
Periodically, once a week or once a month defragment your C drive and other drives that you are using frequently.
Dec 30, 2007 | Intel Desktop Board D845WN Motherboard
Zerus Intel Desktop Board D815EEA (Z-D815EEA) Motherboard Logo
117 people viewed this question
Top Zerus Computers & Internet Experts
David Payne
David Payne
Are you a Zerus Computer and Internet Expert? Answer questions, earn points and help others
