Question about HP 530 Notebook PC
Can not built XP SP2
I run the disk sanitizer and now can not built xp cuz it says all the drivers have gone and i do not have the repair disk. Where can i find the download of that repair disk to repair my laptop for builting XP again?
    President:
  • 627 Answers
I can't install Windows Xp Sp2 For Compaq Presario Cq60 Model. a blue screen error occured after completing the files from cd to ram before entering lience agreement
You need to check your system ram or memory. If you have 2 system ram or memory unplug the other memory and install the windows xp sp2 again. If still having a blue screen try the other memory then run the setup again. Also if you have an extra hard disk drive you can test it that or plug your hard disk drive to the other laptop and run the windows xp sp2 using your hard drive. If you can install the windows xp sp2 on the other laptop that means your hard disk drive are good. If your memory and to the other laptop are compatible plug it and run the windows xp sp2 installer to see and to diagnose what are really causing problem. Have a nice day.
Apr 02, 2011 | Computers & Internet
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
Xp recovery
You need to download all the drivers installer files from manufacturer website first, and also all the software you want to install automatically with Windows. Then you build a Windows Xp boot CD with all the software setup embedded.
See the links below:
Build an XP-SP2 Recovery Disc - Solutions by PC Magazine
Geek Repair: Create Your Own Ultimate Recovery CD :
Bart's way to create bootable CD-Roms
Slipstream a Windows XP SP2 Recovery CD
Build your own XP SP3 Recovery Disk -
Build an XP SP3 Recovery Disc
Apr 18, 2009 | Microsoft Computers & Internet
Motherboard stop recognize SATA HDD after BIOS reset (default)
You'll likely need either a driver disk for your SATA drive to be recognized by Windows XP during installation or Windows XP with Service Pack 2 built in to install without a driver disk.
Creating a Windows XP installation CD with Service Pack 2 or "SP2" built in is fairly straight forward. This is called "slip streaming". Step - by - step directions can be found in the following links:
http://www.google.com/search?q=slipstream+sp2+windows+xp&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Mar 27, 2009 | MSI 865PE Neo2-V Motherboard
Windows os
Its true. the Bios or HDD driver wont allow you to install Win XP on it.. This BIOS is compatible with only Win Vista. The only easy way to do it is by creating 2 partitions while installing vista. once vista is installed- install XP with Dual boot and than format the vista partition.
Feb 04, 2009 | HP Compaq nc6000 Notebook
Sata
IF you put Vista it will have the SATA drivers you need.
Not sure what you mean about the XP disk.
You can use any XP CD to slipstream. While the ideal CD to use would be XP SP2, you always slipstream in the SP2 on top of the base XP CD.
I would advise against the SP3 as it still has issues. And SP3 still doesn't have any SATA drivers.
Once you create a slipstream XP CD, even if it is the baseline XP without any SP on it, you can always add them through Windows Update.
Aug 24, 2008 | Computers & Internet
Compaq Presario SG3430IL Desktop PC display does not work with windows xp sp2 and vista
Kindly get me the drivers as i have installed xp in my compaq system. and i want drivers for that
Aug 20, 2008 | HP Compaq Motherboard
Sound drivers for Xp sp2
For specific models with different chipset drivers, you can get the sound driver & pretty much everything else on support.toshiba.com. If you can't connect to the Internet, "Tecra, Portege", & sometimes "Qosmio" models came with a built-in HDD recovery, meaning you need to create your recovery disk by running the "Recovery Disk Creator". An application to create your recovery disk. A shortcut is created on the desktop by default, if you cannot find it there, try looking at "C:\Program Files\Toshiba\Toshiba Recovery Disk Creator" & run the "exe" file, it should give you a menu to create one. After creating the disk, you can use that disc to install the drivers for all Toshiba pre-installed devices/softwares on that machine. For Satellite models, the disc should come with the laptop when you boughtt it. When you have the disc, just insert it inside of windows, it will give you options to install the driver & software for a specific toshiba device.
Hope this helps.
Jul 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
I have two lg monitors on spreat dispaly adapters
You don't need a driver for the monitors, the native plug and play driver in XP usually works as well as any manufacturer supplied driver. What's happened is XP doesn't recognize the onboard display adapter. If this is a name brand system (you didn't mention what type it is) download the XP display driver from the manufacturer's web site. If it's a custom built system, there should be a motherboard CD that came with the system that has the display driver on it. When all else fails, download System Information for Windows from http://www.gtopala.com/ It will tell you what type of onboard display adapter the system has.
Oct 04, 2007 | LG L1717S-BN 17" LCD Monitor
HP 530 Notebook PC Logo
82 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
