Question about Car Audio & Video
The display unit on the left end of the eurovox head unit
The display unit on the left end of the eurovox unit that displays time, station, cd and track numbers - the back light his stopped working - okay during the day but not good at night - can it be repaired, I pulled the head unit out but couldn't see how you get into the unit to repair it - has it been built to not be repaired
    President:
  • 1,348 Answers
There is a bulb in the back of the display.it does come apart but you need to be very good with electronics to fix it. try a few shops omeone will know how to fix it.if they say it is not fixable they are lying to you.
Posted on Jul 13, 2009
HAVE TO SET RADIO STATION EVERY TIME UNIT IS SWITCHED OFF HOW TO SET PERMANENTALY . ALSO WANTED TO KNOW IF DISPLAY COLER CAN BE CHANGED
For Pioneer car stereos to keep the station memory the wiring is as follows:
Yellow is 12v constant
Red is on with ignition switch.
Orange/white is for lighting switch.
as for display color, need to know the head unit model.
Dec 30, 2010 | Pioneer Car Audio & Video
My kenwood-mp342u head unit works but wont light up there is no display
Most likely the backlighting has burnt out. Repair or replace if not under warranty.
Dec 09, 2010 | Kenwood KDC-MP342U Car CD Player
Eurovox 'Maestro Series' 10 stacker displaying 'E-99'
CD ERROR DISPLAYS
CD Changers
E01:
The disc magazine is not inserted in the cd changer
E02:
No disc is inserted in the disc magazine
E04:
The disc is dirty, or the disc is inserted into the disc magazine
upside down
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
FM/RF Remote Controls
E99 RESET PROCEDURE FOR REMOTES:
Remove disc magazine from changer by pressing eject button.
changer. Press RESET button on interface unit
WAIT:
The temperature is exceeding more than 55c(130f) and the cd
changer cannot be operated. When the cd changer cools off, this
wait disappears. When the RESET button on the interface unit is
pressed, this WAIT appears for a few seconds
IF THESE ERROR CODES STILL KEEP APPEARING
CONTACT YOUR DEALER.
Jun 14, 2009 | iLO CA3000V CD Player
No radio text display on vauxhall corsa
model cdr 2005 radio/cd player works fine except there is no display above where the radio station2_bing.gif/cd track number is supposed to be displayed. I have time and temperature as normal
May 07, 2009 | Car Audio & Video
Led lights do not work on radio/cd player. no station/time displ
Work in car audio for a living. dodge caravan's are notorious for having there cd player's **** out. if the led display is out the built in reducers for the display power supply are more then likely shot. head to a junk yard and pull one out if you want to keep it stock :)
can prob get it from them for about 20 buck's and it will plug right in were the old one did. or you can go after market head unit (125-900$ at any electronic's store) buy a harness (about 18$) and a mounting kit (25$) for the easyist install :)
hope this helped
Mar 04, 2009 | 2002 Dodge Caravan
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
How do I get the clock to always display on my head unit Alpine 9884 cda
Look for "TITLE" button on the right hand side of the display.
press TITLE repeatedly until the time is displayed.
set time.
when power is OFF but iginition is ON press TITLE to display the time.
i hope this solution helps .
Jul 11, 2008 | Alpine CDA-9856 CD Player
Cant display time
Upper right-hand corner, there's a button next to the "eject" button. Pressing this button while the unit is on will cycle between displaying the clock and the track number & play time (CD) or clock & radio station.
When the unit is off, you can press the same button to completely shut off the display, which is sometimes nice if you don't want the blue ring around the volume knob glaring in your face.
Jun 22, 2008 | Pioneer DEH-P3900MP CD Player
Ink system failure erorr 0xc18a0306
Although it did not work for me, HP offered this as a solution. If it does not work, HP indicate you have a hardware fault that can only be fixed by a service engineer repair.
1. Get the unit into the “Support Menu” by following the steps below :
A. - Press and hold the “left arrow” key.
B. - Press the “Setup” key and release both keys.
Display should say “Enter Special Key Combo”
C. - Press and release the “OK” button.
Display should say “Support” and display the FW rev (something like R0616R)
2. Press and release the right arrow button until the display says “System Configuration Menu”.
3. Press and release the “OK” button.
4. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
5. Press and release the “OK” button.
6. Display should say “Hardware failure status: Clear. Press OK to clear”.
7. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
8. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
9. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
10. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
11. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK. The Printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
12. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
Mar 24, 2008 | HP Photosmart C5180 All-In-One InkJet...
Clock Setting ?????
When a station is tuned in the unit will decode the incoming clock data after 2 minutes will display the correct time when the 'DSP' button is pressed.
Note: some stations do not transmit a PTY or CT information & therefore the clock display may not be available.
For clock setting it is recommended to tune to a National Radio Station.
Hope This Helps.
Nov 12, 2007 | Goodmans CD / MP3 car radio GCE780MPT CD...
Car Audio & Video Logo
80 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
