Question about Canon PIXMA MP150 All-In-One InkJet Printer
The scan button will not function. All other systems seem to be OK
    President:
  • Canon Master
  • 1,447 Answers
It is the navigation key install software then it is active
Posted on Jul 13, 2009
Heater controls stop working and rear defrost inop and the park assit not working and we tried to program a keyless entry remote that didnt work eathier tried that and everything stop working
Did you check fuse's in fuse block center console ? Fuse #26 IGN3 / HVAC 10amp . Do you know what I'm talking about ?
Fuse Block - Center Console
Inside of console, behind the right console access panel
What did you do jump terminals in the DLC ?
You need a factory scan tool to program keyless entry remote .
  1. Install a scan tool.
  2. Use the scan tool in order to access programming: Vehicle Control System/Computer Integrating System/Module Setup/BCM/Program Key Fobs.
  3. Press the START soft key on the scan tool.
  4. Important: The scan tool must stay connected until all of the transmitters are programmed.
  5. Press and hold the LOCK button and the UNLOCK button simultaneously on one transmitter. After a delay of 5-10 seconds, the scan tool will indicate that the transmitter is programmed.
  6. Repeat the previous step in order to program up to 4 transmitters.
  7. Remove the scan tool.
  8. Operate the transmitter functions in order to verify correct system operation.
Oct 09, 2016 | 2004 Buick Rendezvous
My Brother DCP-145C has been causing problems since I installed Windows 7
My suggestion is to UNINSTALL the entire Brothers software and go to their web site and download if from there. DO NOT USE THE DISC that came with the printer. Just be sure to select your operating system from their drop down menu.
http://support.brother.com/g/b/downloadtop.aspx?c=eu_ot&lang=en&prod=dcp145c_eu_as
Nov 02, 2014 | Office Equipment & Supplies
Canon 2030i scanned document in memory - Need to clear
you follow this step :
- press button ADDITIONAL FUNCTION
- press button number 2 and 8 (press simultaneously with two fingers)
- press button ADDITIONAL FUNCTION again.
service mode will come out on the screen
- press FUNCTION on the screen
- press CLEAR
- press R CON
- press OK (bottom right side of the screen)
- swicth OFF the copier
- wait for 3 or 5 second
- swicth ON the copier
GOOD LUCK
if you need more, you can email me
Feb 22, 2013 | Canon ImageRunner 2030I Black and White...
Does Magnavox mdv 2100/F7 dvd player have front panel display
Hello
This DVD player has no front panel display. Its front panel have ony two LED light indications, out of which, one is for power On indication and the other for p-scan [Progressive Scan] which will ight up when you select Progressive Scan function.
There are three push button switches, for Open/Close, Play & Stop.
It has only ON-Screen display system, which will be active only after connection the DVD player to tV. OK.
http://www.dataentryjobs.us/67948.html
Feb 02, 2012 | Magnavox Televison & Video
Toshiba SD-V55HT stuck in Progressive scan mode.
Hello
Progressive Scan Video provides the highest resolution
pictures with less flicker and line structure
If you are using the COMPONENT/PROGRESSIVE
SCAN VIDEO OUT jacks, but are connecting the
DVD/VCR Receiver to a standard (analog) television,
set Progressive Scan to Off
If you are using the Component Video jacks for
connection to a TV or monitor that is compatible with a
progressive scan signal, set Progressive Scan to On.
To ON and OFF this function, Press "Setup" to display the setup screen.
Surf through, and hilight "Progressive scan" and press "Ok or Enter"
Here you can set this function ON or OFF. If you wnat to get it OFF, select OFF and press Enter.
OK.
Jun 25, 2011 | Toshiba SD-V55HT DVD/VHS Home Theater...
We see a yellow anouncement that says PSCAN and it splits the image
Hello
PSCAN; means Progressive Scan. To get the splitted picture together you have to change the scan system of your tV to progressive scan. Now it runs on Interlace Scan. If your TV has Progressive Scan function; refer to its user manual; set it to progressive scan. An other way is to change the scan system with DVD. Try either. OK.
Jun 20, 2011 | Memorex MVD-2045 DVD Player
Why do my tv screen appears in three sections when i put a dvd disc? it appears normal when i put a vcd!
hi,
check is your tv supports progressive scan, if not switch off the progressive scan mode on your sony home theater system.
For switching off the progressive scan mode do the following in ur home theater's remote.
Do this setting if your connected the component video
1. Press the FUNCTION BUTTON on the remote.
2.Press the VIDEO FORMATE button to select interlace scanning.
If you are connected the HDMI then do the following setting
2.Press the VIDEO FORMATE button to select the resolution
Select 720 * 480p
Jan 17, 2011 | Sony BRAVIA DAV-HDX267W Theater System...
My F4240 will print and copy but wont scan
Hi
I am providing you steps for Windows XP if your O.S is other then please reply.
Solution ;
Try copying if copying is fine then Scan through WIA.
If the scanning is successful, proceed with step 3. If scanning was not successful then I request you to perform the step given in step 4 and then perform step 3.
Step 3: Manually check for DIM
The digital imaging monitor must be running for the scan to function to work. The digital imaging monitor normally appears in the system tray in the bottom right-hand corner of the computer screen, next to the time.
If the digital imaging monitor appears in the system tray, go to the section Populate Destination List.
NOTE: If hpqtra08 is not on the list in the Startup tab, this indicates that the driver was not correctly installed. Uninstall and reinstall the driver.
9. Populate the Destination List with following steps:
a. Open the HP Solution Center.
b. Click on Settings --> Scan Settings --> Button Settings.
c. In the window opened, select "Scan to button" tab
d. Click the Destination List tab.
e. Click on each of the programs you want to appear in the scan to list.
f. Click the Add button. This moves the selected programs to the Front Panel Destination List.
g. Click OK.
h. Now try the scan to function from the all-in-one.
To save the above changes I request you to perform steps given below as Dest test.
1. Close all applications including HP Solution Center.
2. Open and run the DESTTEST file from the location:
C:\Programfiles\hp\digitalimaging\bin\Under Destination:
a. (Optional) Set the Category for the Destination List scroll
down menu on WEB_APP.
2. On the 5th option "Close Dest Test After sending to Destination", put a check mark and click on Save Results Before Exit.
3. Click on Exit in the bottom.
4. Now Open the HP Solution center, Click on Settings -> Scan Settings & Preferences -> Scan To Setup.
5. You will see all Button settings on the right side under the front panel destination List. In Case If not, click on Restore Defaults, click on Apply and click on Ok.
6. Push Scan To button on the unit you will see all the Destination List on the unit. Select the appropriate one.
Oct 03, 2009 | HP OfficeJet 6210 All-In-One InkJet...
I have a problem with keyboard volume control
These instructions are for Windows XP:
  • The volume button, brightness key, and disc eject button on some computers will not work if the HotKey Utility application is not running.
  • The Magnify button and the Fn keys will not function properly before the operating system has finished starting.
  • The setting may not be saved if the ESC key is used to close the Fn display. Press the ENTER key or allow the Fn display to close automatically to save the setting.
  1. Click the Start button, then click Run .
  2. In the Run window, next to Open , type MSCONFIG .
  3. Press the ENTER key.
  4. In the System Configuration Utility window, click the Startup tab.
  5. On the Startup tab, under Startup Item , ensure that there is a check in the HKserv checkbox. NOTE: If HKserv is missing, reinstall the HotKey Utility application and the Sony Utilities Library.
  6. Click the OK button.
  7. In the System Configuration box, click the restart button.
Feb 07, 2009 | Sony VAIO VGN-FJ270/B Notebook
Scanning
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00809848&lc=en&dlc=en&cc=us&lang=en&product=90792
Issue When the scan button is pressed on the product, nothing happens. The scan button does not work correctly. Workaround Choose one of the following options to scan without using the scan button. Option one: Scan using Windows Fax and Scan
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Windows Fax and Scan . NOTE: The Windows Fax and Scan option is available in the Business, Ultimate, and Enterprise editions of Windows Vista. If you have the Home Basic or Home Premium edition of Windows Vista, skip to Option two: Scan using Paint .
  2. Click New scan .
  3. Click File , and then click Scan .
  1. Click the Windows icon (c01319360.gif ), click Programs , and then click Accessories .
  2. Click Paint .
  3. Click File , and then click From Scanner or Camera .
  4. Click Scan .
Cause The drivers in the Windows Vista operating system do not support button press functionality on the product.
Oct 04, 2008 | HP Officejet 4110 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
66 people viewed this question
old marine
old marine
