Question about Microsoft Windows Xp Home Edition English International for PC
How to change name in start menu in taskbar - Microsoft Windows Xp Home Edition English International for PC
    Scholar:
  • 174 Answers
In order to make the changes, the file explorer.exe located at C:\Windows needs to be edited. Since explorer.exe is a binary file it requires a special editor. For purposes of this article I have used Resource Hacker. Resource Hacker.
Then 'replace the 'start' word with your desirable word.
NB: take a backup of your file before doing so.
tx.
Posted on Jul 13, 2009
    President:
  • 627 Answers
Here is your problem resolved:
http://www.theeldergeek.com/change_text_on_xp_start_button1.htm
do it on your risk!!!!!!
4 Suggested Answers
askanything
  • 151 Answers
SOURCE: i wanna to change of the windows xp's strat name
Download a software named resource hacker from internet. Its of some kbs only. In that software you open your "explorer.exe" located at C:/windows/ In that go to String Table->37->1033->and change 'start' to 'yourname' Do not remove single quotes. Save it with other name as "newexplorer.exe" But before doing this make copy of your explorer.exe in other drive or place. Now change the registery by writting "regedit" in Start->Run Navigate to: HKEY_LOCAL_MACHINE\ SOFTWARE\ Microsoft\ Windows NT\ CurrentVersion\ Winlogon In the right pane double click the Shell entry to open the Edit String dialog box as shown. In Value data: line, enter the name that was used to save the modified explorer.exe file. Click OK Close Registry Editor and either log off the system and log back in, or reboot the entire system if that?s your preference. If all went as planned you should see your new Start button with the revised text.
Posted on Sep 27, 2007
SOURCE: i want to change start button s name on taskbar
How to change the text in START Button in task bar ?
I have received many emails from users on this topic. In Windows XP Pro, you can change your Start button and you are not even restricted with 5 characters as it used to be the case in previous version of Windows but the process itself of modifiying the start button is a bit more tedious than what it used to be. Anyways, gist of act is to modify your
1. First of all, make a backup of your explorer.exe This is one of the most important executables of your operating system and incase you make a mistake, you should have its backup to fall back on to ! You will see this file in C:\Windows directory. Go there, make a copy and change its name to something you remember like "explorerold.exe or explorer.old".
2. Download a freeware called ResourceHacker by going to http://www.rpi.net.au/~ajohnson/resourcehacker
3. Now, lauch resource hacker and locate your explorer.exe by going to c:\windows. Now go to String Table>37>1033. This is where the START text is located. Change it whatever you would like....
4. Once done with the changing START button text, click on the button called "Compile Script". Now its time to save the changes. Important: Save the file as explorer_modified.exe (or something similar). You can not save it as explorer.exe as file is in use as you are exploring the directories etc etc.
5. All right, reboot the computer and boot into safe mode in command prompt environment (at boot time press 'F8' a few times...) and log in as administrator.
6. Now all that you need to do is to copy the modified explorer file to original one.
Type this at command prompt "copy c:\windows\explorer_modified.exe to c:\windows\explorer.exe" (without quotes)
7. Reboot your computer as you would normally do.
If you have followed the steps correctly, you should have new explorer by now.
Posted on Jul 04, 2008
  • 50 Answers
SOURCE: missing taskbar and start menu
Probably your infected. to fix the problem u can visit kelly's korner and copy all the text and then go to notepad and paste the text and then save it as "taskbar.reg" and then after saving it run it. it will prompt you if u want to add the registry information and you say yes. see if that fix's the problem. if u dont know how to open notepad without the startmenu u can try pressing windows key+r and type "notepad" and press ok. remember to save it as a .reg file.
Posted on Nov 26, 2008
How to get taskbar back
Hi, if your on a Windows system press the Windows key to open the Start menu, in the Search option at the bottom type taskbar, this should show you Taskbar and Start Menu option.
Select the Taskbar and Start Menu option
Check the AutoHide option is not ticked, and check the taskbar location is set to Bottom, if you make any changes click the Apply then ok.
Aug 28, 2014 | Computers & Internet
Tip
Trick to show your name in taskbar
Here is a trick to add your name in place of AM and PM beside time in the taskbar.
It's simple
Goto Start -> Control Panel -> Regional and Language option -> Customize (beside English US) -> Go to TIME tab -> Change AM symbol and PM symbol from AM and PM to your name -> Apply -> Ok ...IS it changed ??? May be not ...
Now go to time in taskbar and Double Click it to open "Date and time property" ...
Look at the place where time changes in digital format i.e. 02:47:52 AM , click to arrow to chage the AM or PM by selecting and press arrow.
Apply -> OK.
It will Show your name!!
on Jul 28, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Tip
Hacking Your Way Through the Interface
Use Registry hacks to make a grab-bag of great interface changes.
Hidden in the mazes of the Registry are countless ways to hack XP's interface. Here are some of my favorites.
Hide All Icons in the Notification Area
The System Tray, also called the Notification Area, is the small area on the far-right side of the Taskbar, in which utilities and programs that run in the background, such as antivirus software, show their icons.
I don't find it a particularly intelligent use of screen real estate, so I'd prefer not to see the icons there. To hide them, run the Registry Editor [Hack #68] and go to HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer. Among other things, this key controls the display of objects throughout XP. Create a new DWORD called NoTrayItemsDisplay. Assign it a value of 1. (A value of 0 will keep the icons displayed.) Exit the Registry and reboot.
While you're at the HKEY_CURRENT_USER/Software/Microsoft/Windows/CurrentVersion/Policies/Explorer key, you can also delete the My Recent Documents icon on the Start menu. Create a new DWORD called NoRecentDocsMenu. Assign it a value of 1. (A value of 0 will keep the icon displayed.) Exit the Registry and reboot.
Hide Only Certain Icons in the Notification Area
You might like to display some icons in the notification area but hide others. If so, you can hide icons on a case-by-case basis. You'll do it by delving through menus, though, not by hacking the Registry. Right-click on the Taskbar and choose Properties → Taskbar. The Taskbar and Start Menu Properties dialog box appears. This dialog box, as the name implies, lets you control how the Taskbar and Start Menu look and function.
In the Notification area of the dialog box, check the box next to "Hide inactive icons," then click Customize. The Customize Notifications dialog box appears,
Click on the program's listing in the Behavior column, and choose from the drop-down menu to hide the icon when the program is inactive, always hide it, or never hide it. Click OK twice. Your changes will take immediate effect.
on Mar 17, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
How to enlarge the icons on the toolbar
If you mean enlarging the task bar items please follow the following steps:
1-Access the Taskbar and Start Menu. This particular menu will allow you to customize your taskbar features and resize the icons. Click on the Start menu, or Windows logo, from within your taskbar.
2-Select "Control Panel," then select "Appearance and Personalization." On some Windows 7 computers, this option may also read as "Appearance."
3-Click on "Taskbar and Start Menu." This will open a Taskbar and Start Menu Properties dialog box on your screen.
4-Change the size of the taskbar icons. Place a checkmark next to "Use small icons" within the Taskbar Appearance section to make your taskbar icons appear smaller.
5-Click directly on the checkmark if one is already present to enlarge the size of your taskbar icons.
6-Save your taskbar icon customization settings. Your new taskbar settings will go into effect immediately. Click on the "Apply" button to save your changes, then click "OK" to exit from the Taskbar and Start Menu Properties menu.
Apr 27, 2014 | Panasonic Toughbook CF-51 Notebook
Move task bar to bottom of page
The desktop screenshot might need reducing
Click start "Control Panel."
Click "Display" and then select the Settings tab in the Display Properties window.
Use the slider bar under in the screen resolution section of the applet to change the resolution and click "Apply."
The screen repaints at the new resolution.
Click "Yes" to keep the resolution, or answer "No" at the prompt to revert to the original settings.
The taskbar is a central user interface component within the Microsoft Windows 2000 operating system.
Located along the bottom of the screen by default, it includes the "Start" button, provides one-click access to all open programs and contains a collection of utility icons and the system clock in a section called the Notification Area.
Windows 2000 gives you the ability to adjust the behavior of the taskbar in several ways.
After you know where to find the proper menu item, performing this task takes only a few clicks.
Right-click on an empty area of the taskbar and select "Properties."
Click the "General" tab located along the top of the resulting dialog box.
Check the Always on Top box if you want the taskbar to appear above all other items on your screen.
Check the Auto Hide box if you want the taskbar to disappear into the bottom of the screen when you move the cursor away from the taskbar.
Check the Show Small Icons in Start Menu box if you want to enable this behavior.
Check the Show Clock box to show the system clock within the Notification Area at the right edge of the taskbar.
Check the Personalized Menus box if you want the "Start" menu to show the items you use regularly and hide the items you don't.
Click "OK" to confirm your changes.
They take effect immediately.
Hope this helps
Nov 09, 2012 | Microsoft Windows 2000 Professional for PC
How to change name at start in taskbar?
1) Click on Start and then Control Panel
2) Then click on User Accounts
3) Then click on Change an account
4) And then on the account you wish to modify
5) Then select what you wish to change, in this case the name.
6) Then enter the name you wish to change it to and click Change Name
That's it. The new name for the account will now appear at the top of the Start taskbar and at log in if you have a password.
Dec 26, 2010 | Microsoft Windows Xp Home Edition English...
How to change start name on taskbar in win xp
Hello shinde_jagan,
I've posted a link to an article below that explains step by step how to change the text in the start button.
Change Start Button Text
Hope this helps, don't forget to vote. Thanks :)
Feb 28, 2010 | Microsoft Windows Xp Home Edition English...
I changed from classic view to movie view and i dont no how to put it back
  1. Open Taskbar and Start Menu Properties by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
  2. Click the Start Menu tab, click Classic Start menu, and then click OK.
Nov 27, 2009 | CyberLink Power DVD DX 8.0 for PC
Change start name on taskbar
hi,
if u want to change start name on taskbar then u've to go on this link and get the RESOURCE HACKER s/w.
http://forum.codecall.net/tutorials/4111-how-change-start-taskbar.html
Sep 17, 2009 | Microsoft Windows Xp Home Edition English...
In vista: taskbar does not show icons of opened files
it might be your taskbar is on auto hide try this
Show or hide the taskbar gl_icon_tip.png Applies to all editions of Windows Vista.
The taskbar is usually located at the bottom of your screen. It looks like this:
getopencontent.aspx?assetid=984f8561-57a1-4b9c-9f22-f0d8dddec294&documentset=en-us&renderkey=xml Taskbar
You can hide the taskbar to create more space. If you don't see the taskbar anywhere on the screen, it might be hidden.
Hide allShow allHide all gl_arrow_down_static.gif To show the taskbar
• If the taskbar is hidden, point to where you last saw it to show it again. If you can't remember where you last saw it, try pointing to the bottom of the screen first, and then to the side or top of the screen, if necessary. You might need to move the pointer almost off the screen to show the taskbar.
gl_arrow_down_static.gif To hide the taskbar
1. Open Taskbar and Start Menu Properties by clicking the Start button getopencontent.aspx?assetid=4f6cbd09-148c-4dd8-b1f2-48f232a2fd33&documentset=en-us&renderkey=xml, clicking Control Panel, clicking Appearance and Personalization, and then clicking Taskbar and Start Menu.
2. Clear the Lock the taskbar check box.
3. Select the Auto-hide the taskbar check box.
The taskbar is hidden from view. You can see it again by pointing to the place where you last saw it.
gl_arrow_down_static.gif To turn off auto-hide
2. Clear the Auto-hide the taskbar check box.
Jun 27, 2009 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Xp Home Edition English International for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
