Question about Bose 901 VI Main / Stereo Speaker
Bose 901's with Onkyo A9755B
Hi
I am looking for some advice.
I have just purchased some Bose 901 speakers along with the 901VIE equalizer this is matching in with a Onkyo A9755B amplifier. I have connected them up and I just dont seem to be getting the quality of sound that it should have, it seems to have very little base. I have adjusted the equalizer but this doesnt make any difference which leads me to believe it isnt working. It has power and is connected correctly but even when i turn the equalizer off there is no change in the sound. The instuctions mention to turn the tape button on the amplifier off but there is no tape button there is only a tape selector.
Does any one have any ideas as to why this is happening?
Thanks
I have inlcuded a link to the amplifier that is in question
http://www.intl.onkyo.com/downloads/manuals/pdf/a-9755_9555_manual_e.pdf
Greg,
I read your post tonight and realize that you may probably resolved the issue by now. However, I'll share what I know, as I have a lot of experience with Bose 901s (Series V) that I have owned and cherished since 1985. I'm not an electronic equipment expert, so I'll share my information in plain ole and simple english as I know it. To make it short, I reviewed the amp owner's manual provided in your link and see that it has a 'tape monitor loop' that is 'one' of the required options to use the EQ. I also noticed that the amp has a 'Main In' connection for bridging another power amp; however, I do not see a 'Pre-Out' connection. Based on my knowledge and experience with 2 Yamaha amps/receivers I own, I don't see how you can properly connect the EQ without the Pre-Out feature on the amp. HOWEVER, you should be good-to-go with the tape monitor loop. As a matter of fact, my owner's manual for the 'Series Vs' recommends that users connect the EQ in the tape monitor loop 'if connecting additional 'non-Bose' speakers to the amp. The other 'direct' connection (pre-out/main-in) connection for the EQ warns against using non-Bose speakers. The manual provides a bit of rationale for using the tape loop connection but I won't go there--not interested nor does it make any sense to me. All I know is that your tape monitor loop should work with no problems. The key is to 'reverse' the RCA jack patch cables for "playback and record" on the EQ and amp while keeping the 'tape' button on the amp engaged at all times. You should be able to manipulate all of your input 'devices' (CD player, tuner, etc.) with the amp's main source switch(es). As I said, I'm not expert but I've never had any problems with my 2 Yamaha stereo systems. Hope this information helps. HR. Williams, Schertz, TX.
Posted on Sep 14, 2009
  • 3 Answers
Here is how I hooked up my used Bose VI Equalizer with no manual using a Kenwood receiver and Pioneer amp. ( I read some of these instructions and none worked.) First I had to ignore some of what was written on the Bose back panel. I connected jacks from my receiver Output directly to Bose Input under where it reads "Amplifier" on the back. Then I connected jacks from Bose Output under Amplifier to my amp Input for Receiver. Then two strand peaker wire from my amp speaker outputs to Bose speaker.
It rocks loud, now the Bose equalizer adjusts bass, treble, has a button for two levels of bass that works although you have to listen closely for the difference.
The extra Tape recorder jacks (right side if looking at back of Bose equalizer) can be used for phono, CD, TV, etc. and the Monitor button on the front can be used to switch from receiver to that component. Button out is Source (receiver), button in is other component chosen. But I assume you would have to hook that extra component to the Tape Recorder side of the Bose Input, then go to from Biose Tape Output to your Amp Input for Auxillary and then switch from one to the other at front of Amp. That's switching twice for one component, but it enables use of Bose equalizer as recommended for their speakers.Good luck.
Posted on Jul 16, 2009
  • 156 Answers
Did you buy the 901's new along with the eq? If you did then I wouldn't suspect it to be the eq. If you bought it used, it sounds like the eq. I have had two of them go bad. Are you cutting the bass up on the Onkyo? Do you have the speakers placed correctly, like 18" from the wall? These speakers don't have a lot of bass unless they are placed correctly against a wall. They really sound best in a corner. You should get a difference when you move the opts on the eq though. Hope this helps some
Posted on Jul 13, 2009
    Brigadier General:
  • 8,546 Answers
The use of 901's in any digital AV receiver setup for anything EXCEPT STEREO listening through the 901's alone requires you to have a separate amplifier for them and to avoid having to use a Tape Monitor.
That is because if you activate any Tape Monitor circuit at all, you will kill any digital sources. That is a function of AV receivers in general, nothing to do with 901's. However, you can still draw the Front Left and Right signals out of any Pre-Out (with a Y-cable set, looping the Pre Out directly back to the Main In) or Tape Out jacks (remembering to NEVER activate that monitor on the receiver), go into the Active EQ's Amplifier Connections; then Out of the EQ's Amplifier Connection to a separate amp and attach the 901's to that amp. This way you won't introduce proprietary and potentially damaging Active Equalization back into anything in the AV Receiver with its conventional speakers.
The AV Receiver can still drive the Center, Surrounds and the Sub(s) as it is designed. This is how mine is wired.
Come to think of it, you could still have conventional Front L&R speakers on the AV Receiver, but why? Maybe one would prefer the 901's for music and some other speakers for surround. Level matching with the 901's to conventional front speakers would only be possible if the separate amp has its own volume, but it would work. Maybe I'll try it someday. None of my current amps has volume.
Posted on Nov 30, 2009
How to hook up bose 901 active equalizer to onkyo grand integra pre amp?
You don't.
If you have a pre-amp/power-amp combination then the Bose equalizer connects between the two. If you're using the Bose speakers as front L&R, then the connection is between the front L & R pre-out and the power amp's front L & R pre-in.
Sep 01, 2014 | Audio Players & Recorders
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
Trying to hook up bose 901 v to sansui 8080db is
Just remove the Pre-Out to Main In jumpers and connect the Active Equalizer there. This way it will affect only the power output to the amp and speakers but not to any of the Tape Loops. If you need more, look around on Fixya for 901 advice and you'll find about a million posts by me for many scenarios, including multi-channel.
Aug 04, 2010 | Bose 901 VI Main / Stereo Speaker
I just enherited a pair of bose 901 speakers
My suggestion is do not hook the 901's directly to the Onkyo. It is compatable, but they WANT more than what the receiver can give them. I suggest going and getting a dedicated amplifier for them. Trust me, you'll be a lot happier going that route.
May 27, 2010 | Audio Players & Recorders
Proper wiring connection on bose 901 speaker with onkyo tx-sv424 purchase 5 years ago
trying to hook up sereas 2 901 to onkyo sx 424 i have access to carver c 1 if that will help
Nov 29, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 equalizer hookup
how do I hook up the bose 901 EQ to a yamaha DSP3090??
Nov 08, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901
1-record out from receiver to to equalizer in.
2-equalizer out to tape pb in receiver.
Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
Onkyo tx sr 705 & bose 901
No. Active Equalization is required for the 901's and not to be used with any non-901 speakers.
Sep 13, 2008 | Bose 901 VI Main / Stereo Speaker
BOSE 901 ACTIVE EQUALIZER
i, trying to hook up a powered subwoofer to my hafler dh 110 and dh 500 running a bose 901 series v active equalizer and series v 901s any info would be appreciated
Mar 15, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
993 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
