Question about LG LHT799 Theater System
Dropped speaker now has lots of static
Have an LG "out of the box" home theater system. Front left speaker fell about 3 feet onto hardwood floor. Speaker still works, but now has lots of static. Can this be fixed? If so, how difficult and expensive? Is it worth fixing, or should I be shopping for a new set? The system is only 1 year old.
  • 615 Answers
Dear Sir
Welcome to Fixya Customer Support
I feel happy to assist on this occasion
By Analysing Your Speaker Problem it deffinately by broken speaker cones.Generally We observed that when speaker gets external shock or fell down from height speaker cones brokes, and it gives somewhat static sounds and also originality of sound also losted.So you can replace u r cones or speaker but it is quite expensive and but not originates Original Sound but somewhat satisfied. So purchase new one is better choice.
good luck
Fixya Customer support
chandrashekhar
Posted on Jul 13, 2009
    President:
  • 1,348 Answers
The driver inside needs to replaced as the magnet broke or the driver got bent..it may be cheaper to order a new speaker complete from them.
Tip
How to install a 5.1 home theater system
1. Read the installation guidline/connection diagram given with the product.
2. u will get 5 speakers and a subwoofer. speakers are front left & right, rear left & right and center speaker.
3. install the front spearkers both side of the TV at ur ear level.
4. install the centre speaker at the centre above or below the TV at ur ear level.
5. install both the rear speaker at the back side wall corners (min 1.5 feet from ur sitting position) at a hight of 5 feet. face the speakers towards ur sitting position.
6. keep the sub woofer at the right side corner of the room.
7. note that the room should be a closed one with less air ventilession & use a carpet on the floor to get clear sound.
8. use co-excial or optical fibre cable to connect ur home theater system to ur TV, DVD player or audio device.
Now u can enjoy ur home theater.
on Aug 15, 2010 | Audio Players & Recorders
Tip
Home Theater Setup - Rear Speakers
When people install their own home theater systems they typically use these small stick-type stands for the rear speakers. This leaves one (or all) rear speaker blasting right into your ear, which is not how the rear speakers should be.
Rear speakers should be mounted two to three feet above ear level or higher, get those speakers off of the stands and onto the walls. The reason for this is that they were intended to add a background effect, they are not meant to distract your from the picture.
If your room (or significant other) does not allow speakers to be mounted up, then move your rears back a bit and aim them towards each other, this will maximize their effect and not distract you from the front while you enjoy your movie.
on Jan 27, 2010 | Audio Players & Recorders
The centre speaker wires have shorted when the speaker fell off our tv cabinet and now we aren't getting any sound from that output. All the others are fine.Model:HT503PH
Did you try connecting another speaker to the center channel and confirm if the Amplifier is OK or not. Because of the fall the center channel speakers itself could have been damaged and thus not giving any sound. You can take the left or right speaker and test if the amp is OK in case you do not have any other speaker.
Jul 09, 2011 | LG HT503TH Theater System
How to hook up cable box, dvd player, and tv, to the home theatre system
Instructions things you'll need:
  • Composite video cable
  • TV
    • 1 Place the front left and right speakers on each side of the TV with the speaker labeled "Center" either above or below the TV screen. Set the rear speakers behind the seating area at head level and place the subwoofer on the floor a few inches away from the wall, which can absorb bass sounds if the sub is pressed against it.
    • 2 Connect the plug on the end of each speaker to the jack labeled for that speaker on the back of the Durabrand receiver. The cables are permanently attached to the speakers, so each may need to be moved closer to the receiver. For example, the left front speaker connects to the jack on the receiver labeled "LF."
    • 3 Plug the video cable from the Video OUT jack on the back of the receiver to a Video Input jack on the back of the TV.
    • 4 Plug in the Durabrand receiver and TV to the electricity and switch on both components.
    • 5 Press the "Input" button on the TV remote several times until the Durabrand signal displays on the screen.
Mar 25, 2011 | Durabrand STS98RW Theater System
How do i hook this up Samsung HT-WX70 Theater System with Wireless Speakers
1. Connect the front left, front right, center, and sub woofer speakers to the back of the home theater system.
2.
With the home theater system off, insert the TX card into the TX Card connection (WIRELESS) on the back of the home theater.
Important:
Make sure to insert the TX card with the slanted portion of the card facing left.
3. C
onnect the rear left and the rear right speakers to the back of the SWA-3000.
4.
Plug the power cord of the SWA-3000 into an electrical wall outlet, and then switch the power switch on the back of the SWA-3000 to [ON]
Hope this helps!
Jun 27, 2009 | Samsung HT-WX70 Theater System
I have an Onkyo Hts - 580 Theater in a box sytem. Lately I noticed no output from the front left speaker, alos no output when test tone is used. Pkease help.
you might want to switch the speakers that youre using. e.g front left put it to front right and vice versa to isolate if the speaker has the issue or the amplifier terminal.
if the left speaker works on the other terminal then its a terminal issue.
Feb 02, 2009 | Onkyo HT-S580 System
Center speaker static noise
Sorry sp106s, you have to take that to bose service center.
Its a complicated problem. Something is wrong in the amplifier
section inside your sub box. Only authorize servicemen can
open it, not any tech'n can.
Good Luck
Dec 03, 2008 | Bose Lifestyle 18 System
Speaker problems
You've probably tried this, but when you do the channel test you can turn the volume up or down on whichever speaker is currently being tested (the static). Maybe your speakers have been adjusted somehow.
Jun 08, 2008 | RCA RT2300 System
LG LHT799 Theater System Logo
727 people viewed this question
Top LG Audio Players & Recorders Experts
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
