Question about Toshiba e-Studio 350 Copier
Thoshiba E studio giving the Total Counter 220320 number and display call for service. You are requested to advise.
  • mealied Jul 10, 2008
    My 350 still say call 800# and gives counter info
    Problem Solver:
  • 9 Answers
The machine needs a PM which is a preventive maintenance overhaul. Contact a technician in your area or restart the machine holding down the 0 and 8 key and input code 252 and hit 0 and enter, then power down and restart to reset PM counter.
However, I HIGHLY RECOMMEND that you get a full PM done if you want to avoid future copy quality problems and parts ware-down.
Posted on Nov 16, 2007
How to reset counter in toshiba studio230
You mast have acode at the right of panel
For example c400
Tell us what is the code to help you
Aug 24, 2016 | Toshiba E-studio 230 Copier W/net Print,...
Call service e studio for total counter 29451
When you device is giving this advice, call the crevice centre. Without the knowledge and without the needed parts you can't solve this yourself. Safe yourself time and money and call now.
Apr 18, 2015 | Office Equipment & Supplies
Thoshiba E 163 How to verify the total copies taken by the copier
there shold be a counter button press that and if you want a printout you can select printout totaal counter list
Jul 19, 2011 | Toshiba e-Studio163 Copier
How do I find the copy counter function on the E-Studio 600 copier?
If the e-Studio 600 is similar to other Toshiba models (like the e-Studio 452 or e-Studio 3510c) you can view the copy count by simply pressing the User Functions button, and it should be displayed in the lower right corner.
If you don't see it there, select Total Counter while you're in the User Functions screen, then select Print Counter.
Did that help?
Jun 06, 2011 | Toshiba COPIERS E-STUDIO 600 Copier
E-Studio 3511 Color Copier written in the screen call for service total counter 372278, how can i solve this problem?
hello
we have like that message before in our copier also but the only thing i did is shutdown and start again and i reset the counter and it goes fine.
make hard reset remove all the power cable and plug again.
thanks
Mar 15, 2011 | Toshiba E-Studio 3511 Color Copier
How do you meter read Toshiba e-studio 453 copier?
"User functions"
"print total counter"
That's it......
Aug 12, 2009 | Office Equipment & Supplies
Hi, i have 2pcs of canon iR2016 Digital copiers which displays error codes of E246 AND E247. these errors are not in the service manual, please help
Sir i am a Canon trained tech. I just checked our website and my service information. I found the following. I suspect someone has been working on these machines or swapped some parts around.
Page 1 of 2
MODELS AFFECTED / SERIAL NUMBERS AFFECTED:
Digital Copiers, Including All imageRUNNER Products
SUBJECT:
Information About The New Soft Counter Circuits
GENERAL TECHNICAL INFORMATION
GENERAL:
This Technical Publication presents information about the new Soft Counter circuit that replaces the mechanical counter
used in the past. There are three (3) PCB’s associated with the new Soft Counter circuit; the Counter Memory PCB,
Main Controller PCB and the Serial Number PCB. A description of their function is provided below. Use this
document as a reference for current and future models that use the Soft Counter circuit.
Counter Memory PCB
On the latest Canon digital copiers, such as the imageRUNNER 5000, imageRUNNER 8500 and imageRUNNER 2200
series, there are no mechanical counters. Instead there is a Counter Memory PCB. This PCB is usually mounted on the
Main Controller PCB with one screw. The Counter Memory PCB is imprinted with the serial number of the machine
the first time power is turned ON and cannot be moved to another machine. Attempting to do so will generate an E246
error code. In the event of a Counter Memory PCB failure, a new one from stock (see Note 4) can be installed into the
machine. At that point the Main Controller PCB will transfer its present total count as indicated in “Counter Check” on
the control panel (recorded the last time power was turned OFF) to the new Counter Memory PCB and the total counter
will increment from that count on. Never attempt to operate a machine without the Counter Memory PCB
installed!
This may generate an E245 code, which can only be cleared by “zeroing out” the Main Controller PCB by
one of our A.P.R.F.’s (Authorized Parts Repair Facilities).
Main Controller PCB
The Main Controller PCB, aside from performing other tasks, retains the total count by means of SRAM with a battery
back up after power has been turned OFF. If, however, the Main Controller PCB has been replaced with either a new
one or a used one, it will read in and record the total count from the Counter Memory PCB retained the last time power
was turned OFF. The total count will then increment from that count on.
Note 1:
Even though the total count will be the correct value for that machine after replacing the Main Controller, the soft
counters in Service Mode will not. If a new Main Controller was used for the replacement, then all soft counters in
Service Mode (service counters in “Counter Mode”) will be zero. If, on the other hand, a used Main Controller was
used for this replacement, the soft counters previously recorded on that PCB would be shown. At that point it is
advisable to clear these values in Service Mode using Function>Clear>CNT-MCON.
All Main Controllers sent to our A.P.R.F.’s for repair will be “zeroed out” before being sent back to the dealer.
Page 2 of 2
GTI-T151
04-30-02 GT I
Note 2:
The Counter Memory PCB and the Main Controller PCB should never be replaced simultaneously!
This will
generate an E354 code and assistance from the Canon Reseller Technical Support Center Hotline will be required. If
the Main Controller is sent to one of our A.P.R.F.’s for repair, you must remove the Counter Memory PCB
before sending it out!
Failure to do so will only increase down time for your customer.
Note 3:
If the Main Controller PCB is replaced, ensure that connector J1023 is connected. If it is not, an E350 will be
generated.
Serial Number PCB
The Serial Number PCB’s main function is to identify the machine’s serial number. This PCB cannot be moved to
another machine.
Attempting to do so will generate an E355 and assistance from the Canon Reseller TechnicalError codes not listed in the Service Manual:
There are various error codes that are not listed in the Service Manual. Canon U.S.A., Inc. reserves the right to treat
these error codes as Proprietary Information. If you encounter any of the following error codes, contact your Canon
E245 E246 E247 E350 E354 E355
Note 4:
Please be advised that Canon U.S.A., Inc. treats the Counter Memory PCB and Serial Number PCB as “restricted” parts.
When a dealer orders these components they will be asked to provide the reason for their replacement, and the original
PCB will have to be returned to Canon U.S.A., Inc. for evaluation.
Jan 07, 2009 | Office Equipment & Supplies
Toshiba e-Studio 350 Copier Logo
611 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
