I have the same problem with my system. In fact, I'm finding the water level in my salt tank is rising very slow with each cycle. The only information I have been able to find is that there is a blockage in the saltwater transmission line, but I have not found it in my system yet. I would also be interested in any insight to the problem.
I have a culligan softminder twin system that is releasing salt and water onto the floor also the...
(More)
I have a culligan softminder twin system that is releasing salt and water onto the floor also the sytem does not seem to be cycling thru correctly and the water is not coming out pure it is discolored and has what lookslike asn oily film to it when left standing for more than 10 minutes
Looking for ''Culligan soft-minder meter'' (part# 01-0073-47) for a 1998 Culligan Mark 100 water...
(More)
Looking for ''Culligan soft-minder meter'' (part# 01-0073-47) for a 1998 Culligan Mark 100 water softner. I believe the turbine is no longer moving as the meter does not count down. What does the part cost? Where available? Can I install myself with ordinary tools? Thank you.
I have a culligan soft minder twin that was installed around 1998. It has constant flow from the...
(More)
I have a culligan soft minder twin that was installed around 1998. It has constant flow from the bleed line even after the unit has completed a regen. I did a manual regen with it isolated and had the same results when I unisolated it. I currently have it on bypass.
