Question about Garden
Craftsman key start and no spark at spark plug?
Key turns motor but no spark at the plug? Where should I look now?
It is a 2 year old Craftsman KEY star 6.1
  • 154 Answers
The coil,may be bad
Posted on Aug 05, 2009
What is the problem when you have spark and you put starter fluid in spark plug hole and it doesn't fire?
might have a sheared flywheel key therefore out of time . not smart to use starting fluid in OLD motors. use mixed gas instead.
Sep 18, 2014 | Boating
Why won't my riding lawn mower crank over?
Hi if you have got it cranking remove the plug and check for a spark the plug must be earthed to do this if you have a spark it must be fuel pore a small amount in top of carb make sure ign is switch on hope this helps.Ron.
Jun 20, 2014 | Craftsman 420cc 30 6-Speed Rear Engine...
Why Craftsman riding mower wont turn over & only makes click sound when turn key on??
1.try jumping the battery with your car battery. I have had same issue in the past with a brand new battery.
2. Try spraying starter fluid into the carb while cranking. If it starts or at least tries to start (assuming cranking is fixed), you have a fuel problem. Again, when I first tried to fire my Used mower, had to use starter fluid to get it to start the first time, but never since.
Jun 19, 2014 | Craftsman Garden
Suzuki Vitara 2007
The battery terminal connections is loose or corroded.
Battery faulty or discharged, if the cable are clean and tight on the battery turn the key to the ON position and switch the headlights or windshield wipers. If they won't run then the battery is discharged.
Broken, loose or disconnected wires in the starting circuit.
Starter motor pinion jammed in flywheel ring gear.
Starter solenoid faulty, Starter motor faulty, Ignition switch faulty.
Nov 23, 2013 | Suzuki Cars & Trucks
Intermittent engine start when key is turned
Check Oil level and water level in radiator. Check Spark Plug caps and Wires to Spark Plugs. Make sure Battery is Charged.
Sep 19, 2013 | 1986 Toyota Camry
What size spark plug do I need for my craftsman 550 lawn mower? It tries to start but won't turn over so I think that could be the problem
I don't believe your problem to be with your spark plug. Did you hit anything with your blade before this problem started? If so your problem is with your timing.
You will have to check your shear key. Remove the top cover to your engine and any attachments. Remove your flywheel, and you will see the shear key between the flywheel and the top of the engine crankshaft. If the shear key is even slightly dented replace it . This is what is causing your problem. You will be up and running soon. GOOD LUCK.
May 21, 2011 | Craftsman 550 Torque 22 in Deck 2n1 Side...
Craftsman 30" mid-engine will not fire - model # 536.270321
You need to find out if the switches are normally open or closed, that can be done with an ohm meter. Then bypass each one at a time either by just disconnecting the switch or by putting a jumper wire between the contacts (wires off switch). For example the seat kill switch is normally open while operating (no connection) it closes (makes connection) when seat is raised (rider off) and grounds the ignition to shut down the motor. Hope this helps
Apr 28, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a 6hp Craftsman 6hp Mulcher 21" Lawnmower' about 8 years old that has lost its spark, replaced the s/plug removed the flywheel, checked the wire at the magneto end, checked the wire at the shutoff...
The only thing I can think of off hand is the flywheel key. Take the flywheel off and check the key. If it is broken, sometimes you cannot get a spark. Sometimes it will just backfire. Check it and I hope you are sucessful...Lee
Sep 23, 2009 | Garden
Garden Logo
162 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
