Question about Car Audio & Video
Turns off on hard hitting songs and isnt hotter than normal use then comes back on in a minute
  • KIICkERS Apr 12, 2008
    turns off wen high bass notes hit im runnin a 4 gauge power wire
Ur running it at an unstable resistance load. change ur speaker wire setup.
Posted on Mar 24, 2008
    Novelist:
  • 111 Answers
Sounds like it is clipping, turn the gain down as a temporary fix.
are you running a capacitor inline? what is the model of the amplifier? what gauge wire do you have hooked up to the power and ground? how long is the wire for the power and what do you have it connected to (fuse block, battery, distribution block)?
Posted on Nov 16, 2007
2006 Pontiac g6 code p1258 . The temperature gauge was fluctuating while driving from overheating to normal operation temp but no actual sign of overheating . So I replaced the coolant temp sensor ran it...
I suggest changing the cooling thermostat to make sure it's not getting stuck causing temporary overheating and flush the system and put fresh coolant in.
The guage will go hotter then go back to normal every time the thermostat opens to let cooled water into the engine block which is normal. Time for concern is when the guage goes hot and stays there along with bubbling sounds and coolant overflow onto the ground. Which you probably already know.
Mar 02, 2018 | Pontiac Cars & Trucks
Car only overheats when a/c is turned on.? is there a coolant temp sensor or not?
Yes there is a sensor. It tells the PCM the engines temp and from there a number of things are going on.
Have the car running and turn the a/c on and look under the hood at the cooling fan(s). If the fan is not on immediatly wait for a minute as they may come on when the a/c pressure rises and not right when the a/c is turned on.
The a/c condensor gets very hot. That would make the air being drawn in hotter than normal. The engine temp may rise higher than normal as well. Is it really over heatting or just running a bit hotter.
Aug 31, 2011 | 2001 Lincoln LS
MY SONY EREADER ISNT WORKING AT ALL. THE RESET BUTTON WILL NOT DO IS JOB AND THE ONLY THING ON THE SCREEN IS ROTATING ARROWS.wHEN I CHARGED IT DIDNT TURN YELLOW.iTS BEEN LIKE THI9S SINCE CHRISMAS AND IT IS...
Hi huffasia,
Looks like a charging problem, try this:
1. Connect the reader to the computer and make sure red steady light comes on, if not, then hit the reset button for 3 seconds.
2. Once you get the redlight, leave the reader charging for 15-30 minutes (make sure the computer does not go into sleep mode)
3. After you charge the reader, try the soft reset again and slide the power switch at the top of the unit.
If this does not resolve the problem you may try a hard reset on the reader but this will remove all content.
To hard reset:
1. Hit the reset on the bottom of the reader
2. Slide the power switch
3. Once "Opening Book" comes on the screen, press and hold the directional "down arrow" and the number "0" both at the same time until "Reset All" appears on the screen.
4. The screen will go blank, now its time to turn it on again.
Note: If after trying the hard reset, the reader goes back to the black arrows trying to turn around, then repeat the steps again.
Hope this helps!
eBookBoy
digialreader.freeforums.org/
May 16, 2011 | Sony E-reader Portable E-book MP3 Player
When I first turn on my Technika tv I get sound but no picture. After hitting the top of the tv it comes on. After a further few minutes the picture freezes and eventually fades away. Further hitting of...
The dreaded loose connection syndrome, this could be easy or hard to trace, only solusion is checking circuit boards for bad connections , it may be also capacitors in power supply neading replaced, not a novice repair
pete
Nov 11, 2010 | Televison & Video
What are some close cooking times for infrared grills
In only three minutes, the grill hit 1600° F, nearly three times hotter than a standard gas grill. Steak-Five minutes later, it was done to medium-rare perfection.
Chicken Breast After 10 minutes — half the time it normally takes, it was done. The grill uses the same radiation as similar to a microwave if that helps with determining other times. if this helped please rate me and let me know...good luck!!
Jul 18, 2009 | Kenmore 774 sq. in. Cooking Area Gas Grill...
The fan on my bmw e46 runs for about 5 minutes then goes off then about 5 minutes comes back on.
the fan on a car is not ment to come on till the motor gets to a set temprature
so as the motor is getting cooler it turns off then when it gets to the point where itsd hitting the hotter temp it cuts in to cool the motor back down
hope this helps
if your motor is not over heating thats all it is
if the car is overheating then the thermostat may need replacing
its like a electric oven it keeps one tempriture
Jul 04, 2009 | BMW M3 Cars & Trucks
How to put songs in this gogear mp3 player?
Open Windows Media Player. Hit the "Rip" tab at the top and put in the CD(s) you want to record. You can put in as many as you have hard disk space for. Each one takes 3-5 minutes to "Rip". When you are through, you will need to plug in your player via the included usb cable. Let the computer "find" it. Then, you will go back to Media Player and hit the "Sync" tab at the top. When it comes up you will see a list of the all music you recorded. You can drag and drop music from the center column to the right column under where your device is listed. If you drag whole albums, whole albums will be transferred. Once you are done, hit the "sync" button at the bottom right and wait for the fireworks to end. The "syncing" process goes very quickly. Now play music!
Mar 11, 2009 | Philips GOGEAR SA6045 MP3 Player
On then off
THE AMP IS DRAWING TO MUCH POWER WHAT SIZE WIRE ARE U USING?
May 11, 2008 | Car Audio & Video
Sansa shutting off during song
this is normal for this player - it goes to sleep fairly quickly - se p.35 of manual to see how to change frequency of shut off
Apr 18, 2008 | SanDisk Sansa e260 MP3 Player
Can't increase volume
Hold the Menu button until u see: Search.
Then go down to AVLS: then it will say "on" next to it. hit vol. up, then the down button, play/stop.
Finally hit "Menu" again to go back to music
Nov 02, 2007 | Sony Walkman Bean NW-E305 MP3 Player
Car Audio & Video Logo
152 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
