3ds max 2009 - Application error
Whenever I open 3ds max 2009, there´s a sign with:
''An error occured and the application will now close.
Do you want to attempt to save a copy of the current scene?''
It´s impossible to do anything in the application because it takes about only 1 minute after starting 3ds when this sign shows. I don´t understand why this happens, i didn´t do or change the instalation of 3ds for quite long time.
So is it the only way the re-installation 3ds or are there any other solutions?
Thanks
VP
SOURCE: Can't open Coreldraw 12 file
convert bitmap object in lo-resolution by convert to bitmap option & than try to save the document
Posted on Feb 26, 2009
SOURCE: Autodesk 3Ds Max
its nothing but hardwork
Posted on Mar 19, 2009
  • 85 Answers
SOURCE: 3ds max autodesk is not opening in windows7 ultimate
some software my not be directly open in windows 7 yet, (like if u c, when u install AutoCad 2006 on Vista Ultimate u can't open it directly, 1st u have to right click on it then Run as Administrator, then it will be open and work) like this prob, i sure that u have to right click on the icon of ur software then run it as Administrator, i think it will open. and your problem will solve..
otherwise your version of 3DS Max is not compatible with Windows 7 and you have to install different version of Windows (Like Xp).
good luck.
shafky
Posted on Jun 17, 2009
Right click the 3dmax then open it with administrator.
Posted on Jan 29, 2010
oqro88
  • 10 Answers
SOURCE: i have downloaded 3ds max 2010 from the internet .
try reinstall 3ds max if problem will be same then there is 2 things 1 you version of 3ds max is corrupt or you need to reinstall your windows and there is always viruses
Posted on Feb 16, 2010
3ds Max on Windows 7 x64bit
Call to Our Window Technical Support Number 1-800-204-4427 for Windows 7 and Get Instant Resolution of Your Query.
Apr 15, 2017 | Autodesk Computers & Internet
"The application failed to initialize
Visual c++ runtime is required by most of the applications developed with visual c++.
Download and install:
http://download.microsoft.com/download/vc60pro/update/1/w9xnt4/en-us/vc6redistsetup_enu.exe
Then reboot computer, 3ds max should start without problem.
If it still persists, please contact me.
May 08, 2011 | Computers & Internet
Application error 0xc0000005 in 3ds max
You're going to want to uninstall, reboot, and then re-install 3DS Max
Mar 01, 2011 | Autodesk 3ds Max 9 Essentials
The application was unable to start correctly (0xc0000005).
Oct 25, 2010 | Autodesk 3ds Max 9 Essentials
Whenever i open application i get error as the application failed to initialize properly 0xc000007b
Your Pc might be infected with virus or malware. Do a scan on both and remove the 'dangerous objhects'
May 20, 2010 | Computers & Internet
N86 camera issue
Here are the steps.
  • go to the camera application while the main camera lens is closed. (front camera will automatically be used)
  • Once camera application is up,open the camera lens. (application will switch to main camera)
  • go to video mode (you cant access image mode settings at it will crash the application)
  • go to the settings of the video mode and choose to reset the camera settings.
  • That should fix it
Feb 24, 2010 | Nokia N86 8MP Unlocked Dual-Slider 3G...
Cmd.exe application error
Check out the below link to know the error -
http://hubpages.com/hub/cmd-exe-application-error
post further comment for more help..
Good Luck!!
Thanks
Jul 19, 2009 | Acer Computers & Internet
Sony Ericsson W350i camera not working
sony ericsson camare problem...when i will start camare ,,display message 0 hold ,,another application running ,,close to start
Jun 27, 2009 | Sony Ericsson W350i Cell Phone
good luck.
shafky
May 20, 2009 | Autodesk 3ds Max 9 Essentials
Application Error
better uninstall the program and reinstall it..
Minimum System Requirements
Software
The 32-bit version of Autodesk 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft® Windows Vista® operating system
* Microsoft® Windows® XP Professional (SP2 or higher) operating system
The 64-bit version of 3ds Max 2009 is supported on any of the following operating systems:
* Microsoft Windows Vista
* Microsoft Windows XP Professional x64
3ds Max 2009 30-day trial version requires the following browser:
* Microsoft® Internet Explorer® 6 or higher internet browser
3ds Max 2009 30-day trial version requires the following supplemental software:
* DirectX® 9.0c application programming interface (required)
* Some features of 3ds Max 2009 software are only enabled when used with graphics hardware that supports Shader Model 3.0 (Pixel Shader and Vertex Shader 3.0). Check with your manufacturer to determine if your hardware supports Shader Model 3.0.
Hardware
At a minimum, 3ds Max 2009 32-bit requires a system with:
* Intel® Pentium® 4 or AMD Athlon™ XP or higher processor
* 512 MB RAM (1 GB recommended)
* 500 MB swap space (2 GB recommended)
* Hardware-accelerated OpenGL® application programming interface and Direct3D® application programming interface supported
* Microsoft Windows – compliant pointing device (optimized for Microsoft IntelliMouse)
* DVD-ROM drive
Note: Apple® computers based on Intel processors and running Microsoft operating systems are not currently supported.
At a minimum, 3ds Max 2009 64-bit requires a system with:
* Intel EM64T, AMD Athlon 64 or higher, AMD Opteron™ processor
* 1 GB RAM (4 GB recommended)
* Hardware-accelerated OpenGL and Direct3D supported
* Microsoft Windows – compliant pointing device (optimized IntelliMouse)
* DVD-ROM drive
Nov 03, 2008 | Computers & Internet
Computers & Internet Logo
1,467 people viewed this question
David Payne
David Payne
