Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
I would like to know if i can put a Seagate Barracuda 1.5 TB Internal Hard Drive on a laptop? Thanks in advance.
  • 788 Answers
The answer is yes, if your BIOS will support a 500 G/B drive.
If you were running a 5400 and want to jump up to a 7200 NO PROBLEM.
If your BIOS supports SATA1 and 2.
You may have to use Disk Manager to setup the drive before hand.
Example, I am running a ASUS high speed M/B at home which only supports SATA1 and does not support SATA 2 drives.
The Speed in which I wanted was 100mb/sec
I had to negotiate down to half that.
It is fast for a SATA but not SATA2 fast.
Good luck, Check the specs. on your laptop and see what it will handle.
John Ray
john@johnrraycomputer.com
Readers, please rate your technician's
Posted on Jul 13, 2009
Seagate barracuada makes buzzing for 3 seconds, stops for 3 seconds and starts buzzing agian...
if power is good, to it, its dead.
try other connectors first.
my guess is it will not spin up, (fault) and detects that then keeps trying to do that. start up.
try it , in another system. if still dead, then it is.
Oct 03, 2013 | Seagate Barracuda St31000524as 1 Tb...
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
My hard drive is recognized in bios but windows will not format for windows 7 install
You have to have the current drivers loaded on the motherboard for the HDD to be able to load your operating system.
Jul 16, 2011 | Seagate Barracuda St31000524as 1 Tb...
Seagate Barracuda external hardrive - damage to usb connector on
Assuming the drive itself is still ok (it sounds like it would be), then yes, you can put the drive into another case or directly into the motherboard if you know how to do that.
May 27, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Iv got a 1 tb external hard drive iv pluged a power suply from a toshiba 19 v and i think its blown it there is a little bord concected to the hard drive will that be the problem and if so where can i get...
Improper power supply will cause the malfunction of the HDD. Try to coordinate with vendor/dealer who provided the product and repair the same.
Hope this gives you the information you need
Dec 16, 2009 | Seagate BARRACUDA ES.2 - HARD DRIVE - 1TB...
New internal hard drive not showing up
Did it showing on MY COMPUTER AND MENAGMENT CONSOLE???
Nov 15, 2007 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
102 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
