Question about Apple iPod MA446LL/A MP3 Player
My ipod video is making a spinning noise & doesn't switch on
My ipod video is making a spinning noise and will not switch on. when i attempt to switch it on it gives me a picture of an ipod with a sad face and a website. i visited the website and it told me how to fix it, but it didn't help as my ipod doesn't switch on and in order to fix it, it needs to switch on. can anyone help?
  • 317 Answers
SOURCE: my ipod shows a sad face
Hopefully your ipod is still under warranty, because this is indicative of a hardware problem.
You could try to force it into disk mode and do a restore, if that doesn't work then it needs to be sent in for repair.
http://docs.info.apple.com/article.html?artnum=61771
Posted on Jan 26, 2008
  • 13433 Answers
SOURCE: ipod shows sad face and folders
the sad face means there is a software / hardware side fault witch needs service.
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore…
www.apple.com/support/ipod/five_rs/
If they dont work you will need to send the ipod in for service.
Posted on Apr 19, 2008
ehmbee
  • 9 Answers
SOURCE: iPod won't charge and has sad face
I think this is the fix for the "sad face" problem:
http://www.instructables.com/id/DIY---Fix-Broken-iPod!/
Posted on Oct 23, 2008
dvdcdlaser
  • 1285 Answers
SOURCE: Getting www.apple.com/support/ipod with a sad face what can I do?
how to open ipod just follow this link http://www.youtube.com/watch?v=2h53otOBTsI
if its a mini or nano be extra careful sliding out (wires)
need a battery here http://www.ipodjuice.com/
Posted on Jul 06, 2009
  • 102 Answers
SOURCE: 30 gb ipod has sad face and low battery icons
could be bad charger or time to replace the battery. lots of places sell new ipod batteries.
does it work if you leave it plugged into your computer for a few hours? if it does not then its a bad abttery.
Posted on Sep 23, 2009
I have the ATR6700FS1 front load washer. It goes fine until the spin cycle. It pauses & when I hit restart it makes a noise & doesn't spin. If I hit cancel & go to the spin cycle it
Hello Deanna Lytle - Often when a unit does not spin, it is because the unit cannot properly drain and dispose of the water and detergent solution. Does the unit make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Mar 29, 2013 | Frigidaire ATF6000ES Front Load Washer
Washing/dryer machine will not spin and when drying selected attempts to wash
check this possiblities:
It doesn't pump or spin
frozen pulley or broken belt
It pumps, but doesn't spin
lid switch defective
It spins only with the lid closed
prevent to open the lid, test the switch see the diagram
May 11, 2012 | Washing Machines
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
I have a Hoover Top Loader HNT2135. The problem is that it will not spin. Makes a noise as though it is going to spin but doesn't manage to.
Hi.
If it does make noise and does not spin it is usually the drain pump clogged. Disconnect power, reach the drain pump and check for blockage in there . If that is not the problem check in order drain hose at the back, lid switch, pressure switch, and finally pump and motor from underneath the washer. The switches and motors can be tested using a multimeter.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Sep 13, 2011 | Hoover Nextra HNT 2135 Top Load Washer
My kenmore dryer makes a humming noise when u turn it on n the drum will not spin
If you are hearing a humming noise and no spinning . You have a burnt motor..Do not attempt to switch it on till you fix it to prevent further damage
Mar 07, 2011 | Dryers
My iPod turns on but the buttons dont work! They were working just fine then they stopped! How do i fix it?
Try this! http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_nano.htm Difficulty: Easy Time Required: Less than 1 Minute Here's How:
  1. NOTE: First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
    If the hold switch wasn’t the problem do the following:
  2. Move the hold switch to the on position and then move it back to off.
  3. Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
  4. If this doesn’t work at first, you should repeat the steps.
  5. If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
  6. If this doesn’t work, you may have a bigger problem, and ought to get more help.
Aug 03, 2010 | Apple iPod nano
My ipod nano keeps frezzing how can you solve the problem?
Hello :
1: First make sure that your iPod’s hold button isn’t on. This is the little switch at the top left corner of the iPod video that you can move to “lock” the iPod’s buttons. If this is on, you’ll see a little orange area at the top of the iPod nano and a lock icon on the iPod’s screen. If you see either of these, move the switch back and see if this fixes the problem.
If the hold switch wasn’t the problem do the following :
2: Move the hold switch to the on position and then move it back to off .
3: Hold down the Menu button on the clickwheel and the center button at the same time. Hold these together for 6-10 seconds. This should restart the iPod nano. You’ll know the iPod is restarting when the screen changes and the Apple logo appears.
4: If this doesn’t work at first, you should repeat the steps .
5: If this doesn’t work, you should try plugging your iPod into a power source and let it charge. Then repeat the steps.
If that didn't help , then you should take your NANO to the service .
good luck .
please rate !
Mar 30, 2010 | Apple iPod nano
I have a 30 gb ipod video, the screen says connect to computer use itunes to restore ipod. The problem is the original computer with all my music had its hard drive crash, and i havent backed up my ipod on...
probably not... but you can try these:
while the iPod is plugged in, toggle the hold switch on and off (slide it to hold, then slide it back again), then press and hold the "menu" button and the center button until you see the apple logo on the screen, if this doesn't fix it... try a different USB port (use one on the computer itself, not your keyboard or hub), if this doesn't work... restart your computer and make sure you have the latest updates for your computer, if this doesn't work... call apple at this link:
http://www.apple.com/support/expert
Nov 25, 2009 | Apple iPod MA446LL/A MP3 Player
Ipod
If your iPod nano won’t turn on or respond
1) Make sure the Hold switch is off.
2) If that doesn’t work, connect iPod nano to your computer’s USB or FireWire port. Your
iPod nano battery might need to be recharged.
3) If that doesn’t work, your iPod nano might need to be reset.
a) Toggle the Hold switch on and off (set it to Hold, and then turn it off again).
b)Press and hold the Center and Menu buttons for at least 6 seconds, until the Apple logo appears.
4) If that doesn’t work, you might need to restore iPod nano software.
Mar 12, 2008 | Apple iPod nano
Apple iPod MA446LL/A MP3 Player Logo
54 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Parshiv Luthra
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
