Fisher & Paykel Smartdrive 701 again! AUS/NZ 230V model. Replaced pump after fluff etc. blocked the outlet. Got it running, more of same fluff slowed then slowed draining/spinning, removed pump again, removed fluff ball, reinstalled pump, now 4A fuse in control box keeps blowing. No moisture at all in electronics or micro-switch pad. Could water have entered the motor when I removed the pump? If so, how do I remove the tub? Many thanks in advance. Roger.
SOURCE: Fisher & Paykel Smartdrive 701 Model GW701-U
Hi mate
I had the same problem replaced the board still no go. In my case it turned out to be the drain pump. Nothing wrong with it but a small bit of grit that although difficult to see was impeding the impeller
chee3s
Pul
Posted on Dec 11, 2007
SOURCE: service manuals and diagnostic codes with results/reset code
Washer says it has too many suds all the time.
Posted on Apr 05, 2008
http://www.aars.com.au/F&P%20Service%20manual%20517735.pdf
Posted on Feb 06, 2009
  • 17 Answers
SOURCE: fisher paykel smartdrive 601
Most likely a blocked pump
Posted on Apr 19, 2009
Healeyman
  • 1198 Answers
SOURCE: F&P Smartdrive 701 doesn't fill with water
There is a fill control switch. It will ususlly be up high in the machine with a small tube going to it. Pull the tube off it and blow the tube clear. Attach a piece of tube to the control and blow in that too, the switch should click. If you can, check around inside where the tube attaches to the washer to make sure there is no debris there.
Posted on Apr 28, 2009
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Washing Machine
Check out the fuses on the main controller board if they are fitted. If you need a new motherborad you can get one from Fisher & Paykel in Australia at http://www.fisherpaykel.com.au/customercare/contactus/
Sep 08, 2012 | Fisher and Paykel Washing Machines
How to unblock fisher and paykel excellence smartdrive washing machine
sounds that you have a jammed or blocked water pump. Just remove the pump and try to unblock it, it can affect the electronic board which may need replacing
Sep 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher&Paykel Laundry: Fisher&Paykel Washer: smartdrive 058 leaking by the pump...
Hi if you can see the water leaking from the base of the pump pump needs replacement better to do now than later when pump fails and takes out main board :)
May 18, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fault 37 - on my washer can you help me? It works sometimes . I think it will be a faulty switch or a blocked pump... Can I undo the pump myself? I am handy...
Well, I bit the bullet and I FIXED IT MYSELF!!!! I had to undo the main bracket .... which allowed the tiny water pump to be taken out. Surprising how small it is . Anyway there was a ball of fluff/lint ready to fall out !!! so I think I have fixed it . It was an anoying intermittent, but growing, problem - and these can be the worst to diagnose. This fluff was blocking the outlet! Have done a complete wash and will do more tomorrow. This machine has already done a mountain of work over the years; can now recommend. Cheers Gaz - the expert! [not]
Nov 07, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher paykel smartdrive 601
I can talk you through diagnostics if you want to go on live chat cheers
Mar 13, 2009 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Feb 20, 2009 | Fisher Paykel Eco IWL16
Hi mate
chee3s
Pul
Dec 08, 2007 | Fisher Paykel EcoSmart GWL15
Service manuals and diagnostic codes with results/reset code
Click on Fisher & Paykel (below FIXYA)on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, voila! u hv your manual on line!!
Sep 21, 2007 | Fisher Paykel Eco IWL16
Washing Machines Logo
296 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
