Question about HP Compaq Presario V2000 Notebook
Ventilation fan not running
I noticed when I turn on my HP compar presario V2000 PC, the fan at the back is not running...when I connect to the power supply,it is not running too...If the fan run automatically when it is not ?
  • 85 Answers
Most laptops fans run briefly at boot time to check that they are responding, but some do not. It is not unusual, though, for laptop fans to only run when they are hot. Try using the laptop in bed surrounded with blankets and see if the fan turns on after a while. Also check the fan (if it is visible, as some are) is not clogged somehow with lint or dust, which does happen. If it is clogged, take a vacuum cleaner on smallest nozzle with the laptop unplugged and slowly suck the lint out through the ventilation holes.
If the laptop heats up badly (HPs are known for this) and the fan never turns on at all, the fan could be bad, but this is very unlikely. If it were the case, ask HP to replace it under warranty, or if not under warranty, have a go at removing and replacing it, though this is a last resort. You can also get a cooling pad/docking station for laptops that would help, though it would tie you to carrying around a base unit.
Good luck.
Posted on Nov 16, 2007
Screen is black, but fan runs. Then computer cuts
This most often means you have a bad cpu or motherboard. When the bios does its post checks it looks for issues and will shut the pc down if all the devices are not funtioning correctly or the CPU reaches critical heat.
Dec 29, 2009 | HP Compaq Presario V2000 Notebook
High pitch noise on Notebook when Fan is on
the only two moving parts in a computer are the cooling fan and the hard drive.  Some fans have two speeds.
Mar 22, 2009 | HP Compaq Presario V2000 Notebook
A claim
I had the same problem on my v2000. apparently the fan shroud for the cpu cooling fan is made of plastic and can deform. In my case the deformation allowed the fans blades to strike the heatsink stalling the fan. This would lead to system overheat and shutdown. I disassembled the unit removed the fan shroud and installed .5mm O-rings onto the mounting screws moving the fan away from the heat sink and allowing normal operation. This repair is not for the faint of heart as these are tiny screws.
Feb 01, 2009 | HP Compaq Presario V2000 Notebook
Computer just shut off and won't come back on
One last resort would be to check the power connector at the rear of the laptop,,,if that is found to be connecting ok,,(need a volt meter to test) then i would say you need a new mainboard, time to visit ebay.
Jan 19, 2009 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 notebook screen ghosts out and system running slow
for the display you can check by connecting the laptop to the monitor through the vga port
Oct 03, 2008 | HP Compaq Presario V2000 Notebook
Compaq v2000 dies after some time
Is the machine getting hot when it shuts down? If so, then you may need to clean the fan and heat sink. A dust or dirt build up can hinder the cooling system performance allowing the machine to heat up to a level that kicks in the built in fail safes in order to keep from damaging the processor. Try cleaning them and let me know. We'll go from there.
Aug 01, 2008 | HP Compaq Presario V2000 Notebook
Heatsink fan
is the fan running? if not try to replaced new CPU.
May 26, 2008 | HP Compaq Presario V2000 Notebook
V2000 dead as...
plz check your power supply unit or checked it from a proffessional.Then post the result
Apr 01, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario v2000 Notebook problem
Hi, Take out the battery and plug in only the power adapter and see if it comes on. If it does then leave out the battery for about 15 minutes and then put it back in. Good luck!
May 25, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 "Doesn't turn ON"
1) Unplug the laptop. 2) Press and hold down the standby switch under the lid in the upper left hand side of the laptop while pressing down the power key. You should have full power startup now. Let me know if it worked..
Jan 27, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
114 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
