Question about Whirlpool Duet GHW9150P Front Load Washer
Simpson Esprit 550 top loading washing machine. Model 36S550
Will not wash in either NORMAL or DELICATES cycles. Setting of knob to either, there is no reaction; knob remains stationary and does not progress.
It WILL RINSE however in both cylces. That is, turning knob to RINSE results in water coming in, so solenoids would appear OK. Will agitate and spin the complete rinse part of the cycle.
Both cold and hot water inlets OK. Inlet filters checked, OK.
  • 93 Answers
Faulty timer
phone 131350 for parts
Posted on Aug 29, 2009
  • 257 Answers
SOURCE: hi, my washing machine does
Check that it is't set to drip dry or spin hold..
Posted on May 13, 2011
SOURCE: Simpson esprit 550.The agitator is not moving in
Had the same problem with mine, could be a number of things but in my case it was a relatively simple fix - but you'll need to buy a part.
Open the lid and look inside, the bit sticking up in the middle of the machine is called the agitator. Remove all the fabric softner and lint filter from it and you'll see one very small bolt at the base.
I concocted a number of ratches stuck together to reach it but once undone you can pull the enitre agitator up an remove it.
The agitator is driven by metal bolt with teeth at the bottom of the tub, however the agitator itself is made entirley of plastic, therefore (prob due to age) the metal teeth had eaten away the inside of the agitator and so it was just spinning inside its hole!
eplace the agitator and problem solved.
Posted on Dec 06, 2009
beltronic205
  • 1456 Answers
SOURCE: simpson esprit 550 washing machine stops mid-cycle
Could be timer fault although good chance its stopping as it gets to rinse indicating faulty Solonoid valve..Good luck
Posted on Mar 31, 2010
Testimonial: "thanks for the tip"
Nicesuit
  • 61 Answers
SOURCE: THE TECK SAYS THAT THE SIMPSON ESPRIT WILL ONLY
you can pick up a Y adaptor from a hardware store and fit a cold feed to both, it will take a few more minutes to comlpete cycles thats all, all new machines are fitted with a cold feed only to make them more energy efficent. the tech is talking pi**
Posted on Jul 23, 2009
rickead1
  • 1998 Answers
SOURCE: Simpson clothes Washer Model Esprit
Have you checked the water valve? here is a link showing how to replace the water valve http://www.youtube.com/user/RepairClinic?v=Fk4puRv3Vk8&feature=pyv&ad=5457342101&kw=washer%20valve&gclid=CI2f6tXrx6UCFRRKgwodM1sWZg
You should also check both side of the valve with a multimeter to assure that you have power going to the valve before you replace the valve. Please message me back if you have any further questions with the correct model and serial number and if there is anything else i can answer for you. please remember to rank how this opinion has helped in your appliance situation and have a great day
Rick
Posted on Nov 30, 2010
Simpson esprit 550 top loader washer
Have you tried the motor control switch.
Its located below the selector switch.
Its white aprox 5 x 7cm with Electrolux AMD103 stamped in it.
The wires that are plug in it goes to the selector switch.
Apr 30, 2016 | Simpson Washing Machines
How do I get my washing machine to spin
Check the interlock tab (upright models) or the hinge or latch switch (front-load.) Sometimes these switches break or simply come loose.
Aug 03, 2014 | Simpson Esprit 750 Top Load 7.5kg
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
Jan 27, 2013 | Simpson Esprit 750 Top Load 7.5kg
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Simpson esprit 550 washing machine stops mid-cycle
Mar 31, 2010 | Washing Machines
Jul 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,783 people viewed this question
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
