Question about Boating
How to manually raise 200 hp 1995 johnson motor
  • 677 Answers
Mate.Have a look at the bolt holes on the transom.If there is some that are lower than the holes used,no problem.Lower your trailer at the front all the way to the ground.Loosen the transom bolts.2 should be in holes,2 should be in a slide hole.Chock the motor under the skeg.Remove the 2 bolts that are in the holes and very slowly raise the front of the trailer.The motor being 'chocked'.will then rise as you lift the trailer.If you run a line from the bottom of the boat through to the middle of the g/box a cleaver prop should be about 2.5 inches and a chopper prop can run up to 5 inches on a really quick boat.This is for 3 blade props.Make sure when the bolts go back in,plenty of sealant.Hope this helps
Posted on Jul 23, 2009
  • thomasnee Jul 23, 2009
    Forgot to tell you.Check your steering does not get tight if you have rod type steering.Hydraulic is usually ok
What year is this evinrude 135 hp boat motor? serial #j0007646
To have the year of your engine, we'll need the engine typenumber, not the serial number...
Sep 08, 2014 | Evinrude / Johnson 135-150-175-200 HP...
How to raise manual tilt johnson (no tilt trim)
on the right side of the motor there is a lever that says tilt on it pull it up unlocks motor grab the top of motor and pull with all your mite
Mar 25, 2013 | Boating
I have a 1998 Johnson 130 hp outboard motor. Have already taken lower unit off but can't get it apart. Is there a secret to taking the lower unit apart? I would like to have a diagram.
Here is a site where you can purchase the service manual to repair your outboard motor:
http://www.tradebit.com/G/manuals/-/0-0-johnson+130+hp
Jul 13, 2011 | Computers & Internet
Boat engine 1995 Johnson Outboard 70 HP
Ihave a 1991 70 hp Johnson outboard thats hard to start the first time but starts good after that. Seems to be flooded. Starting rpm seems to be low.
Jun 25, 2009 | Boating
140hp johnson seahorse tilt will raise the motor
it needs fluid added. had a 70 johnson do the same, I saw no leaks but it was low on fluid, put some in and have had noproblems yet.
Jun 20, 2009 | Boating
Where do i put in hydraulic fluid in a johnson 225 boat motor
if its an outboard you will see a reservoir near the cylinder on back, be careful and set the shallow drive lever so the weight is off the hydros when you open it, there can be up to 3000psi if it has weight/pressure on it
once added you have to blead air bubbles, go up then down at least 10 times
also a boat parts store(phone book) may be able to help you
Jan 02, 2009 | Plumbing
Boating Logo
197 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
