Netgear dsl/wireless dual band will not allow 2 toshiba laptops to connect, but allows 2 hp, have reset, tried all different modes and settings, nothing has worked. Help?
  • atnotary Jul 13, 2009
    Hi Tim,
    Have tried 802.11/b only and this one none of the laptops can see/connect to. I keep picking up something about private networks in all of this that doesn't seem to make sense. I am hoping someone can tell me what to look at on the Toshiba's as far as setting go that might interfere- I will go update drivers, but one of the laptops is like less than 6 months old- it is running Vista windows version 6.06.001- I have disabled most of the stupid security protocols on the Vista as I could do nothing before when I got it because of all of the protocols. But the other Toshiba is like 4 years old and running XP with service pack 3.
    Thanks Tim, pls read comments- would like to know what I should tweak to make Toshibas work w/ router.
  • 1,272 Answers
Follow the steps below to configure settings on the router:
1. Open the browser(Internet Explorer or Mozilla Firefox) on a computer connected to the router.
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router with the User Name as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a password in the passphrase box. Apply the settings.
6. Click on Setup Access List. Uncheck the option Turn Access Control on and click apply.
Perform the steps below on the Vista Toshibha:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
Perform the steps below on the XP Toshibha:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove.Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Posted on Jul 13, 2009
  • Anand Gupta
    Anand Gupta Jul 21, 2009
    Has the issue resolved? If not, then please let me know.
    President:
  • 2,777 Answers
Hello there, you say you have tried all modes and settings so I assume you have tried turning the wireless router down to 802.11/b only correct? Some Toshiba laptops' wireless card have compatibility and connectivity issues with newer mixed mode networks. Also, verify you are running the latest drivers for the wireless cards you have in the Toshibas by either doing a windows update or gong to Toshiba's site and going to the support / downloads section and looking up your model number.
Since the HPs connect just fine you know it's not the access point / router causing the problem, it's incompatibility on the Toshiba side. If you still can't get it resolved after trying the above steps give Toshiba's customer service a call to see if they know of any issues with this router. Their number is 800-631-3811 I believe.
Of course to do the windows update, directly connect to the router via a network / ethernet cable.
Hope this helps!
Thanks
Tim
Im having problems connecting to the internet after i got a netgear wireless dual band router to my pannaway modem
First check that router light is blinking. If not, need to repair or replace.
If light is blinking, you need to reset it. There will be a reset button back side of your router, press and hold it for 30 seconds. Restart your router and reconfigure.
Also check that you had enabled wireless setting. Ask here if problem still occurring http://www.vtechsquad.com/wireless-router-support/
Feb 24, 2013 | Computers & Internet
My HP G60 laptop with Vista won't connect to Netgear router
Usually there are 2 types of wireless connections, 2.4 GHz and 5 GHz. Your laptop may not be able to connect to one of these connections, so it may be incompatible with your router. You can try buying a USB networking card (no more than $20). It will plug into one of your USB ports and should allow you to connect to your router. Hope this helps!
Jun 22, 2017 | NetGear N600 Wireless Dual Band Router
I cannot connect to my 5ghz band, only the 2.4ghz band
i think the best thing to do would be to make sure your 5ghz router settings, make sure they haven't been altered, or reset.
Jan 29, 2012 | NetGear WNDR3400 N600 Wireless Dual Band...
CAN'T CONNECT TO NET BOOK WIRELESS BUT HARD WIRE PC WORKS
Try RESETTING the Netgear router and configure it again.
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash. Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = password You can now change the admin password and configure thewireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 17, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
I have 2 problems:- The first is it seems that if I've one laptop logged in via wireless I cannot connect a second wirelessly! The second is I have a 'n' capable laptop but it will not connect to the...
What you can at first check your router setting if there is a security set only for 1 computer and a pass key. If there is any, configure it to make the second laptop connect to the router.
Mar 15, 2011 | NetGear DGND3300 RANGEMAX DUAL BAND...
How can you use public access on your desktop and netbook with a netgear router and adapter walmart sales lady said it can be done with just the router and adapter setup everything we needed was in the...
Just having the wireless router without connecting it to cable modem or DSL modem will not allow you to get onto the Internet. The wireless card in your computer/laptop will allow you to get onto the Internet at a free public WiFi hot spot location such as McDonalds, Star Bucks, at the airport.
Also the wireless card in your computer/laptop may allow you to connect into an unsecured wireless router from your neighbors, if their wireless router is within range of your computer/laptop but without their permission to use their Internet, it is considered stealing from your neighbor. They have a set download limit from their Internet Service Provider and by you connecting to their ISP you may cause them to exceed their download limit and they would be charged additional costs for every Mega byte over their limit.
Sep 28, 2010 | NetGear RangeMax Dual-Band Wireless-N...
I have the NETGEAR WNDR3300 - RangeMax Dual Band Wireless-N Router and i can not get an internet connection through the router on my laptop wirelessly. My ps3 set up to it wirelessly just fine and the...
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser
window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router
status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set
up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to
access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model
router
9. cell phones, cordless phones, digital TV's, can affect the data signal
from a router. Also distance from the router can be a factor. If your
router is in a basement place the router to a upper floor and center it in
the room.
Gaming router setup steps:
1. Check for current anti-virus before doing step below.
2.Check firewall allowances or permission to be sure game is allowed
3. Try "port forwarding
4. Check the game / verify ports need for multiplayer gaming.
5. Please forward all ports UDP/ TCP To gaming computers IP address.\
6. Log in to router and place gaming computer in to DMZ.
7. When done gaming disable the game in the DMZ.
Sep 08, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Setting up Netgear Wireless-N router
try this plug up a line to laptop to modem to check to see if you can get connected if so then make sure you are on the same network and if so then call comcast to help you setup the laptop wireless settings in sound like the settings online doesn't have the laptop enable to accept the laptop
Dec 01, 2008 | NetGear WNDR3300 - RangeMax Dual Band...
Open Questions:
Computers & Internet Logo
David Payne
David Payne
