Question about SanDisk Sansa e250 MP3 Player
My sansa wont do anything... it wont charge, it wont turn on and the computer cannot detect it... it can't be because the battery is completely dead because i had this thing for only a couple of days and it was charged fully, then i began to put more songs on and halfway through the process, it just shut off and i could never turn it on ever again. please help!!
    Problem Solver:
  • 8 Answers
Do you have earthing ? are you sure it didnt get any electric shocks?
Posted on Jul 16, 2009
  • 82 Answers
Could be ur cable faulty try with another one
Posted on Jul 13, 2009
My sansa when its connected to my computer comes on works syncs and everything so as i disconnect it from my computer it' s dead and wont turn on
Three possibilities;
1) You have a dead battery because the battery is no good.
2) You have a dead battery because your Sansa is no longer charging the battery.
3) You have a dead battery because you didn't leave your Sansa tethered long enough to charge it up.
When you have the Sansa c250 tethered to the computer, you should see a tiny yellow lightning bolt flashing, and a battery icon that shows the amount of charge on the battery.
If you see the lightning bolt, but the battery does not charge after being tethered to a working computer or charger for 24 hours, you may need a new battery. You can get one on Amazon.com. Here's a link:
http://www.amazon.com/HQRP-Replacement-Battery-Universal-Protector/dp/B001NZ981S
If you see the lightning bolt, and the battery charges after 24 hours, AND your player works when unplugged--Problem solved! You just need to let it charge for a longer time.
If you do not see the lightning bolt when the player is tethered, and the battery indicator shows "empty," It's likely that the internal plug to your Sansa c250 has broken. Your Sansa is no longer able to charge the battery.
If you happen to be an electrical engineer, or otherwise have a shop full of electronics equipment (including signal injector, volt-ohm meter, needle-tip soldering iron, and stereo magnifying goggles with work lamps) you may be able to fix it yourself. Otherwise, forget it-- your Sansa is dead.
If it's still under warranty, try to get it replaced. Failing that, it's time to get a new MP3 player.
Hope that helps! Please post a message to let others know what happened to your Sansa player.
Nov 22, 2011 | SanDisk Sansa c250 (2 GB) MP3 Player...
My Sansa Clip MP3 Player is almost new, however the battery only last about 3-4 hours from fully charged. But now it appears to be completly dead which my computer will not even recognize it to start the...
Hey, greatings from lithuania
i have the same problem. Couple days ago i changed the battery from another sansa clip ant it worked fine, pc recognized sansa again :/ i think that the battery is dead , detailier the microchip wich is on the battery..
Oct 26, 2010 | SanDisk Sansa Clip MP3 Player
My Fuze wont charge its completely dead i plug it in to charge doesnt do anything it will not charge like its suppose to
Hi, you said it all, its completely dead, i suggest you get a battery booster to boost the battery before charging it, boosting the battery will make the charging more effective.
But if you are not still satisfy with the charging, you can get another new battery, but avoid the battery going completely dead before charging, this reduces life span of battery.
I wish you best of luck.
Jan 09, 2010 | SanDisk Sansa Fuze MP3 Player
My sansa mp3 play wont turn on
Tried this? 1.Push the hold switch towards the headphone jack so you see orange
2.Press and hold record on the left of the player
3.With record still being held down, plug into the computer
4.Once you see welcome to recovery mode on the screen of the player, let go of record
At this point you can reload the manual firmware by copying the firmware files to the detected removable disk.
Firmwares- Version 1 Version 2
Download the correct version or else it will render your device useless.Version can be found on the back plate at botton right.. Extract the downloaded file and transfer the contents to removable disk detected.After transferring,disconnect the player and let it upgrade the firmware
Sep 05, 2009 | SanDisk Sansa e260 MP3 Player
My sandisk sansa 2g wont turn on with out being plugged in at tha computer n seems to be fine when its plugged in but when its unplugged it wont work! the battery is on a full battery but wont turn on at...
The battery may show "full' but still not hold a charge, so that when you unplug it from your computer, it goes dead. I assume you hold down the power button for several seconds and it still doesn't power up? Most likely, you battery is defective.
Feb 26, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Zune won't turn on or charge
man i have the same problem, i was listening to my black 120gb Zune & i just upgraded to firmware 3.0 & now this s*** wont turn on! i been using it 3 days fine, but now it just shut off like its completely dead. i have been charging it for hours & hours & it just doesnt even turn on or have a battery icon or anything! i have it plugged in now too. restarted the computer, everything.... i tried to restart it by pressing back & up... are there any other shortcuts i can try? computer doesnt detect it or ANYTHING!!! HELLLLLP
--biancapassion@yahoo.com
Sep 02, 2008 | Microsoft Zune JS8-00001 Digital Media...
SanDisk Sansa e250 MP3 Player wont turn on and isn't detected by computer.
your battery could be dead. but when you plug it in does the blue ring light up
Jan 26, 2008 | SanDisk Sansa e250 MP3 Player
Wont turn on
I don't know if this applies to the Sansa for sure or not but many MP3 devices and smartphones if completely dischard will not charge back up via usb to computer, you have to use a wall jack charger. This is true for the Motorola Q and other smart phones I know for a fact, also the Apple Ipod Gen 5 has had some issues with charging after complete discharge of the battery. Try a wall charger if possible. I don't know much about the sansas.
Jan 07, 2008 | SanDisk Sansa e250 MP3 Player
I can't turn on my Sansa e250!! Help!
Check the battery connection(s) in the back. Remove the 4 screws, remove the battery an re-connect it. Charge the device for a few hours. Best of Luck.
Oct 05, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
291 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
