Question about Danby DCD5505W Electric Dryer
Runs on "iron dry" no matter what setting i select.
When i turn it on, any setting, it switches it's self to "iron dry". can i fix this somehow? even if i put it on timed dry it still runs iron dry for whatever reason. runs for maybe 20 minutes then turns off.
  • razorbites Jul 13, 2009
    er, i mean "machine ironing" not iron dry. whoops!
  • harborcountr May 11, 2010
    was it the thermo-safety switch? It's behind the back panel and has a reset button on it.
Same with mine. did you get yours fixed? I took my back panel off, reset the thermo switch and removed it but leaving it plugged in and presto it works........so it probably needs a thermo switch.
Posted on Aug 25, 2009
How do you turn on a rival steam wave iron
The Manual for the Rival IR699 and IR999 Steam Wave Iron may be downloaded in PDF from the following link:
http://www.rivalproducts.com/manuals/MANUALS/IR999_43_64403016.PDF
STEAM IRONING
1. Fill the Water Reservoir.
2. Plug the cord into a 120-Volt AC outlet.
3. Select the fabric setting you desire using the dial. Allow the iron to
heat for 2 minutes. While the iron is heating, make sure it is sitting on
its heel rest on a stable, protected surface.
4. Turn the Steam Selector to the appropriate setting. Begin Ironing.
IMPORTANT: When not ironing, always set the Variable Steam Selector
to (Dry) and the Fabric Select Dial to OFF.
Jun 19, 2012 | Rival Steam Wave Iron
How do you run clean cycle - I have lost the manual
Self-Cleaning and Maintaining Sole Plate
Use the self-cleaning feature once a month by moving the steam lever back and forth from the "dry" setting several times. This will remove any residue from the steam valve and ensure that the steam system works properly.
Wipe the sole plate with a soft, damp cloth while the iron is cool and unplugged.
Run the iron over a cotton cloth several times to remove any residue from the sole plate.
Cleaning Anti-Calcium Feature
Fill the water cup that came with your iron. Use enough water to reach the Sunbeam logo in the top corner of the cup.
Add a teaspoon of salt to the cup and stir.
Empty the salt solution into the water reservoir in your iron.
Allow the iron to stand for 15 minutes, then empty out the water reservoir.Repeat this cycle with a second cupful of salt water.
Rinse out the reservoir with clean water. You should perform this cleaning once a month.
Jul 28, 2011 | Sunbeam Irons
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
PLEASE RATE !
Apr 20, 2010 | Rowenta DX6700 Iron
My Shark Iron leaks....
fill with water turn iron on max keep turning steam dial all the way to the right until you get to self clean hold iron horizontal and make sure you have a towel or something to catch water drips and debris coming out of iron let iron steam and spit water out until it stops on its own turn dial back to regular steam settings wipe residue off of the plate with a towel adjust temp settings back to normal
Aug 14, 2009 | Euro-Pro Shark GI490 Iron
At high temp settings water leaks out of steam holes in bottom
You want to run the self-clean mode. Fill with water, then over a sink, with the iron facing down, press the self-clean button. Steam will eject, along with sediment and water deposits. You may have to repeat numerous times. The iron requires soft water, if you don't have soft water at the tap then buy bottled water at the grocery store to prevent this problem.
You can also buy a cleaning solution that you mix into the water reservoir, or you can make your own by filling the iron half-full of water then add white vinegar to the fill line, then perform the self-clean mode or steam mode over a sink.
Here is a Rowenta suggestions:
The iron is leaking.
Water: Use tap water in the iron. If tap water is hard or high in organic matter, we recommend using bottled spring water or mix tap water with distilled. Do NOT use 100% distilled water. Many softening systems may cause issues as well.
Auto-Off: If iron is equipped with auto off, you need to move iron or gently shake it an allow it to heat back up before beginning to iron.
Overuse of Burst of Steam: Allow more time between each burst of steam.
The Rowenta site does not list a manual for your older model, but here is their link:
http://www.rowentausa.com/rowenta/frame.aspx
Mar 21, 2009 | Rowenta Powerglide DE013 Iron
Rowenta Iron Problems
Rowenta has an auto shutoff feature if the iron is not used for awhile. They use multi-point security Torx head screws that require the appropriate set of bits/driver kit that may be obtained at your local Kragen's or Harbor Freight tools to access the position/timer switch mechanism. Open it carefully so you can see if the switch is somehow mechanically mispositioned or sticking. You may also want to store the iron, cool and reservoir empty in the normal upright position.
Jul 05, 2008 | Rowenta DX6700 Iron
Iron not staying on
This is a problem with a lot of Rowenta irons. It is the auto shut off that is not working properly and the only way to fix it is to have it disassembled and the switch hardwired to be on whenever the iron it plugged in. It is a thermal metal switch and it just stops working and then the iron will not turn on and the yellow light blinks.
Jun 27, 2008 | Rowenta Professional DE880 Iron
SETTING COUNTRY
Try clicking on the main part of the screen during navigation. Then click on the "wrench" icon (Change preferences). Then click the blue arrow (2x) until you get to the 3rd page (Preferences 3 of 5). Click on Manage maps. Then click on Switch map. Then select USA & Canada.
Dec 28, 2007 | Tomtom ONE GPS Receiver
Danby DCD5505W Electric Dryer Logo
91 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
