Question about Nikon Coolpix 8800 Digital Camera
Nikon 880 doesnt focus when zoomed in
Nikon 8800 how to focus when zoomed in very close to a subject
  • 390 Answers
Hi
try the macro option
its a button with the flower button on it
select the mactro option and you would be able to focus on the closest objects
happy photographing, enjoy
cheers
pls rate if ithis was any help
Posted on Jul 13, 2009
How can I keep the picture sharp when zooming in macro
When you zoom in macro with a Coolpix camera, you must change the camera to subject distance to compensate because as you zoom in and out, the depth of focus of the lens changes dramatically.
Jun 10, 2014 | Nikon COOLPIX Cameras
Will filters I have from old Nikon film camera fit or work with my Nikon Coolpix 8800? (I have heliopan filters) Thank you!
filter size of the Coolpix 8800 is 58mm, you might find single piece adapter/converter rings on ebay...... assuming the Heliopan's are 77mm.... try searching "77 58 ring" but you might have to get 3/4 rings to bridge the difference. Eg. 58-62mm, 62-67mm, 67-72mm, 72-77mm
Oct 01, 2013 | Nikon Coolpix 880 Digital Camera
Nikon autofocus shows r10 and the autofcus is not working when I zoom in and seems to be making a noise
The "r10" message in the viewfinder is NOT an error code. The "r" stands for "remainder" and the "10" is the value. Together, it tells you how many more photos the camera's built in, high speed memory buffer can hold BEFORE the shutter will be stopped - so that the pictures in this memory can be transferred to the removable memory card. The process will take a few seconds or more - depending on the speed of the memory card you provided in the camera. If you pay attention to the the "r" number, while taking photos is rapid succession, after each picture - the number will decrease by one. When it reaches 0, you can no longer take additional pictures. During this time - the camera is moving the pictures to the memory card. When done, the "r" number will be high again, and the shutter will operate again.
The auto focus motor will make some noise it is turning to advance or retract the focus mechanism, and is normal. The camera requires sufficient contrast to obtain focus. Most of the time, a well lit subject will provide this. If you are zoomed in on a rather featureless subject - such as a clear or overcast sky, solid color flat wall, etc., where there is a lack of contrasting objects in the viewfinder, the camera can not detect an "edge" on any object; so it attempts to focus over the entire range of the lens to find it. If it can't, it prevents the shutter from releasing.
There is also a minimum distance that the lens will focus, too. If you are trying to zoom in on a close object, the lens may not be able to do it. In this case: either back away, zoom out - or both. If you need to get close to objects, you should consider buying "Macro" lenses. Nikon brand lenses that do this type of photography, oddly are called "Micro" lenses instead.
I hope this helps. Good luck!
Oct 09, 2011 | Nikon D50 Digital Camera with 18-55mm Lens
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Jan 26, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
Auto focus at full zoom not responding Nikon D80 with 18-200mm VR
Hi - I own this lens and it manually focuses at all focal lengths (hard to see at 18mm unless your subject is extremly close). You may need to get the lens checked. BTW - Mine was set as follows when I checked for you:
  • D80 was "on"
  • M/A
  • VR = Off
  • Normal (not Active)
Hope this helps!
Apr 09, 2009 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Close up shots won't auto focus.the lens trys to adjust but the final setting is out of focus. the camera works fine on subjects at least 2 feet away
try using the little throttle that is located just below your on/off switch. if you push that either up/down, it should help you manually focus your subject. It is actually a really fun feature to play around with.
Feb 28, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Lens for Nikon D60
I will try to help you, but please understand that my experience is with Nikon film cameras. Assuming that the D60 works in a manner similar to a Nikon 35 mm body and that Sigma macro lens work like Nikon macro lens, you should be able to determine the usable subject to lens distance by experimentation. First, make sure the lens is in the macro mode. To do this you must set the auto-focus mode control to the manual focus mode (see your manual). On Nikon lenses, you must first set the focus ring to infinity, then move slider switch, which has two positions marked; "normal" and "macro., to the macro position. You should now be able to rotate the focus ring to the macro range. Use the zoom ring to zoom in and out and focus with the focus ring. The the range over which the lens to subject to lens distance will yield an in focus image will be rather limited and in the range of an inch or so to 6 or 8 inches.
Dec 09, 2008 | Cameras
Coolpix macro problem
I called customer suppot.
Follwed these steps:
1. Make sure camera and subject are perfectly still
2. Push flower button till white flower is on screen
3. slowly press zoom in and out till flower turns yellow
4. wait 10 secondes or so
5. camera will focus on object
6. if not, press zoom in/out again, then wait again
Jul 10, 2008 | Nikon Coolpix 5700 Digital Camera
Focus on a particular subject?
If the camera is having trouble doing an auto focus you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance away from you, and then move the camera back to your original subject and take your picture without losing that focus. First turn the camera on and locate the AutoFocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away from you as the subject that the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While keeping the shutter button pressed halfway, move the camera back to include the subject you originally wanted in the image, then press the shutter fully. (Please see page 42 in the D-535 Zoom Reference Manual in Section 3, under the heading titled “If Correct Focus Cannot Be Obtained”, for a more detailed explanation.)
Aug 31, 2005 | Olympus D-535 Zoom / C370 Zoom Digital...
Nikon Coolpix 8800 Digital Camera Logo
114 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
