Question about NetGear RangeMax Dual-Band Wireless-N USB Adapter (WNDA3100-100NAS)
NEW- HAVE TRIED BOTH MODES- 2 HPlaptops can connect on the dual band, 2 toshiba's can not )diff) op systems- and none can connect on the legacy sigle mode. Please help.
  • 3 more comments
  • atnotary Jul 13, 2009
    Hi ****,
    It is a NeatGear Rangemax- Dual Band Wireless-N Modem Router DGND3300, do I need to give you anything else? Thanks so much in advance.
    Deborah
    Hi ****,
    No, do not have these configured, am using the default setup with this as I have ATT DSL.
    The 2 HP's can connect without any issues wirelessly. The 2 Toshiba's can only connect via land line- only the dual mode will work for any of the 4 laptops.
    Thanks,
    Deborah
    Need assistance to correct problem for printer tray to be recognized.
    I am cancelling my paid service due to the non-assistance I got from you **** Too bad I had to figure out to change the modem chanels to fix that and now and working on the printer myself. Shame on you.
    no more help, canceling service
  • 1,272 Answers
Let me know about the current issue that you are facing with NETGEAR product. I work for NETGEAR can help you with these products.
Posted on Jul 13, 2009
    President:
  • 948 Answers
Deborah, we need router make & model to look up a manual. Then you will refer to that manual while fixing your connectivity problem. Do you have your router security settings configured to allow access to the mac address of your USB adapters? That must be done or they will not connect to your network.
  • Dick
    Dick Jul 13, 2009
    One solution per question Deborah.
How do i update the firmware and is this may be the cause of the USB b not recognizing any memory sticks that we've tried?
usb b is for streaming digital media,not memory sticks,
  • High-power dual DSP engine with improved digital effects and output processing including Feedback Ferret®, 28-band GEQ/5-band PEQ, delay and limiter
  • USB 2.0 "A" connection to record directly to or playback from memory stick
  • USB 2.0 "B" connection for streaming digital out
  • 3-band EQ with sweepable mid-frequency and variable low cut filters
  • 2 stereo channels with dual mic/line inputs
  • 48 volt phantom power
  • 6 Aux sends
  • 4 subgroups
  • 100mm faders
  • Double the processing power of the original FX Series
  • All new switching power supply design is more efficient than the original
  • Silencer™ mic preamp XLR inputs
  • Weight Packed: 45.00 lb(20.412 kg)
  • Width Packed: 25"(63.5 cm)
  • Height Packed: 36"(91.44 cm)
  • Depth Packed: 11.5"(29.21 cm
May 19, 2015 | Peavey 32fx USB 32 Channel Mixer
Can you switch a rear diff from a 1997 subaru legacy wagen with a 2.2l inter changeable with a 1997 subaru legacy outback with a 2.5l ?
the biggest draw back that you will have to check first is the ratio of the diffs you want to change. If they are not the same but will fit then you will destroy the 3rd diff in the transmission from excessive use.
Aug 09, 2014 | 1997 Subaru Legacy
Cant connect to a new labtop
1, You should always secure your Wireless. 2, try different channels, setup the dual-bands as 2 SSID, 1-2.4 and the other as 5.0 with diferent channels. I would suspect it's the laptop, Disable the UAC and the Anti Virus. Is the wireless adapter, on the laptop turned on? Do you see the Wireless listed in Available Wireless Networks? For dual-band setup :http://www.pcworld.com/article/229521/dlink_setup_a_wireless_router.html
Jan 09, 2013 | Computers & Internet
I cannot connect my Wii to the internet via new D-Link Wireless N Dual Band Router DIR-815. How do I see if the wireless connection is enabled for connection?
Are you able to connect using a regular laptop? If so, your connection is fine.
I suggest you try Nintendo's Wireless Router Troubleshooting procedure here : http://www.nintendo.com/consumer/systems/wii/en_na/onlineWirelessRouterTroubleshooting.jsp
Hope this helped.
Please rate :)
Mar 02, 2011 | D-Link DIR-815 Xtreme N Wireless 802.11N...
Hi I have a 1996 gt legacy wagon it has a noisy rear diff how do I check the ratio of that diff so I can match up a new secondhand one as I've put a new one in there but is the wrong ratio
there should be a tag on the diff cover. do you still have old one count the teeth when dealing with diff gears you have too replace all of them ring,pinion & spider they grove too each other if you add 1 new gear it will make lots of noise
Jan 07, 2011 | 2000 Subaru Legacy
Netgear dualband wndr3300 - Why can I only connect to one band
Dual band means it is working on both 2.4Ghz and 5Ghz frequency. If your computer can connect on both frequency that only means that the wireless adapter in your computer is also dual band.
Jan 26, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
Rock band wont work keeps saying no data disc can not be read
1. CLEAN THE LASER. ALWAYS DO THIS FIRST. MOST TIMES THIS IS ALL YOU NEED TO GET YOUR SYSTEM BACK RUNNING A 100% AGAIN
2. IF THE LASER CLEANING DON'T WORK ON YOUR PS2 SYSTEM PERFORMANCE THEN TRY ADJUSTING THE LASER VOTAGE.
3. IF THE LASER VOTAGE DON'T WORK YOU NEED TO REPLACE THE LASER
Dec 25, 2008 | MTV Games Rock Band for PlayStation 2
4 GiG memory
Your motherboard doesnot offer dual channel memory architechture and 2x2GB memory is taken in sigle channel mode. Apart from that 32bit Operating Systems don't recognise memory over 3 Gb. So you have the following options...
1. Attach only one 2GB
2. Attach 2GB + 1GB
3. Move up to a 64bit OS with your current 2x2GB memory modules.
Please collect memory module of the same frequency if you consider option 2.
Sep 08, 2008 | Computers & Internet
Foxconn Utility CD for motherboard Intel 915 series p/n: 91-185-915-MB-OM W A N T E D
Hi Witalorant,
I have searched the driver for your motherboard chipset and found one similar for the one you were looking at, i copy and paste the link here for you to download it and install it to your unit.
Click the link below and see what driver you need to download when the page loaded..
INTEL 915
Hope it helps.
Enjoy
Pls. rate & hope to hear more from you soon..
tnx
-micro
Feb 10, 2008 | Foxconn 915P7AC-8KS Motherboard
NetGear RangeMax Dual-Band Wireless-N USB Adapter (WNDA3100-100NAS) Logo
73 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
