Question about Black & Decker 14.4 Volt Battery Charger #5101181 02
Same problem here.
Only reads .18v at the charger. Opened it up and am getting no voltage out off of the board inside the charger. No heat on the outside of the plug in so I am assuming it is the charger.
    Top Expert:
  • Black & Decker Master
  • 12,113 Answers
Your charger burnt out --their cheap to replace online best source of getting a replacement also would get the multi charger
Posted on Jul 01, 2016
  • 575 Answers
There is no capacitors inside this board. It only has resistors and diodes. The resistors usually burn up. No specs are available for the resistors ratings. If yours is burnt, you wont be able to ID the resistors ratings. You will need to buy a new charger.
  • 5,660 Answers
If you're only reading .18 volts DC at the charger itself, then it's time to replace the charger.
It's probably some inexpensive Electrolytic Capacitors inside the charger that have bit the dust.
Here's info about Electrolytic Capacitors,
1.http://en.wikipedia.org/wiki/Capacitor_plague
2.http://www.capacitorlab.com/visible-failures/index.htm
Both sites relate to computer motherboards and computer power supply's, but know, that there has been a problem with 'Caps' for all kinds of electronic components, no matter what they are, therefore these same visual signs of failure apply. (Sorry about the run on sentence!)
3.http://www.absoluteastronomy.com/topics/Capacitor_plague (Read the entire article, and my statement above will become more clear)
Posted on Jul 13, 2009
My Brand new Ryobi 18v lithium-ion battery P104, I bought this three years ago and just now needed it. I opened it from the blister pack it was in and I tried to charge it. When in the charger the red...
get the new charger; and consider returning to store or manufacturer.
if you have the black charger, throw it out
you need the green/two-tone charger for ryobi one 18v
Mar 18, 2017 | Drills
Broken dewalt battery 18v lithium ion 2.0ah flashes fast red when in charger
When a Dewalt charger is showing a fast blinking red light it means the battery is no longer chargeable. It may be because of a bad cell or short inside the battery. Whatever the reason the charger will not charge the battery and it needs to be replaced.
Oct 07, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Can you charge ryobi lithium batteries in a regular ryobi charger?
NO! Never charge lithium batteries in a charger designed for nickle based batteries like the NiHi your old charger was meant for. Ryobi did design the new Lithium charger to be backwards compatible so you can charge your older 18V NiHi batteries in the Lithium 18V charger.
Also note, NEVER miss-match the voltage, for example, make sure you are not trying to charge 12V batteries in an 18V charger unless the manufacturer has specifically stated that the charger is capable of multiple voltages.
Dec 25, 2010 | Ryobi Two 18V Lithium-Ion Batteries +...
Charger not charging battery
Make sure all the wires coming from the wall outlet to the charging station are not frayed or cut. Next, if you have a meter measure the voltage coming out of the pins of the charger (don't worry it's only 18V you won't get shocked). If there IS power coming from the charger, your batteries might be dead. They can only be charged and uncharged so many times before the chemicals inside the battery begin to lose their capacity and it will not hold a charge. I hope this helps!
Aug 30, 2010 | RTO 18v Cordless Drill Driver Kit W/...
Charger broke
common problem, go here
http://mrclm.blogspot.com/2009/09/black-decker-18v-firestorm-drill.html
May 14, 2010 | Black & Decker 18V Cordless Drill/Driver
Powa Force drill charger is dead
Powaforce battery charger.
  1. Measure the dc output (with multimeter) on female plug. Should read ±16 – 20V DC. If no voltage here open charger and measure 220v AC on input wire before transformer. No voltage faulty input cable or 3pin plug. If ok check for dc voltage after transformer. If transformer faulty (not worth repairing) replace with same dc volts and amp (important)output. Check now output cable.
  2. If voltage is on cable but base does not light up, probable faulty capacitor. If light is on but does not charge, probable rectifier that gives too little amps.
  3. Any good tv repair technician can help you. My tv tech already fix about 9 of my torch and drill chargers. Parts usually about R5 – R10.
ps. email me the specs of your charger the input, output, the current (MA) and the voltage 14.v or 21v to globalsat1@gmail.com
Dec 04, 2009 | Drills
Water not heating up
If water is not heating up, parts that must be tested are the heating element, the thermostat , and finally the control assembly and wiring.
T he heating element is tested by reading continuity with a multimeter.
The thermostat can also be tested by reading impedance, that should result over 1Kohm at ambient.
If the multimeter and element read fine, then there is need to test wiring and timer control board. this is done by checking voltages at heating element and reading voltages on control board connectors. A faulty board can also be spotted by visually checking the board for burnt components or leaky and bulged capacitors.
Apr 07, 2009 | Dishwashers
Both cordless drill batteries dead.
Your battery could say its good by just testing voltage,but when a load is put on it , its a different story. My dewalt batt. did the same thing I opened up the batt. case and there was 12 "C" sized batteries inside linked together with little metal strips. I bought 12 rechargeable "C" batts. and carefully drilled where the metal strips are soldered, changed out batt. and re solder. It's been over a year now and still drilling . Also you should do this one batt. at a time so you don't put one in the wrong order .
Mar 17, 2009 | Craftsman Drills
Broken battery port
Try this link for parts:http://www.ereplacementparts.com/dewalt-dc011-type-72v-18v-radio-charger-parts-c-1009_2641_7415.html
Feb 09, 2009 | Dewalt DC011 AM/FM Radio
Black & Decker 14.4 Volt Battery Charger #5101181 02 Logo
340 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Rabbit Brains
Rabbit Brains
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
