Question about Daewoo Microwave Ovens
Ewave OTR Microwave Oven, Model KOT-153UW. Light
Ewave OTR Microwave Oven, Model KOT-153UW. Light bulb blew and turntable doesn't turn. I replaced the turntable drive motor, but apparently the motor wasn't the problem.
  • Anonymous Mar 27, 2014
    Unlock
  • Daewoo Master
  • 9,047 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid in about a week or so.
At our Web site, you can get details of our service, plus we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
The lights can can be inoperable or stuck on or no bright, too. Sometimes this will similarly affect the exhaust fan operation or inside light, too.Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jul 13, 2009
  • Bill Isles Aug 21, 2012
    I want to say that I found Mr. Miller's solution here on Fixya and I sent our panel in and it was repaired and returned in less than 10 days. We now have a microwave that works perfectly! Thanks!!!!
Bangladewh sylhet golap gonj saima aktar
Posted on Jul 24, 2011
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Replaced the touchpad and put it all back together. It now heats, but the oven light doesn't come on and the turntable doesn't rotate. Do you think there's a loose wire?
First check is the main fuse of the unit. On countertopunits, you will need to take the shell off. The fuse will be close to where thecord comes through into the unit. OTR units, this main fuse is usually behindthe control panel or possibly behind the vent. Usually the fuse is obvious ifblown, otherwise test with an OHM meter, if open, replace fuse. Some brands will also have a thermal cut-off fuse in theincoming voltage line to the control board. This thermostat looking fuse isusually above the oven cavity somewhere under the outside shell. Sometimes youcan get to it through the vent of OTR models. Test with an OHM meter, replaceif open. Forturntable: First, make sure the turntable coupler under the glass dish is notbroken. Second, on the control board, find the turntable relay and test forvoltage. Some turntable motors are 24 volts DC, so make sure you're testing thecorrect voltage. If no voltage from the control board, then replace the controlboard. Otherwise head towards the turntable motor. On OTR models, you can get to the motor by un-screwing thebottom panel on the microwave. On countertop models, there will either be aknockout or screw on access panel. Check for voltage at the motor. If novoltage, check the wiring back towards the control. If voltage, then replacethe turntable motor. Hope this will help you. Good Luck.
Sep 03, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
The turntable on our Ewave KOT 170SW Microwave oven has quit rotating. Other than that the oven works fine. Any troubleshooting tips? If the turntable needs to be replaced, how big a job is it? I'm not...
i went to replace lite bulbs but didnt unplug it..removed cover and shorted out...now no lite and no turntable but does come on & heats food is it fixable.......ewave microwave kot-131uw....
Feb 28, 2011 | Kenmore 80412 Microwave Oven
How to replace the door handle on an Ewave KOT 170SW Microwave
Ewave KOT 170SW Microwave, it starts runs for a few mins. then stops. Shorter then time set for.
Dec 10, 2009 | Microwave Ovens
Ewave over the stove microwave fuse blows when I
The light is the only thing that comes on when you open door. You either have a shorted door switch (Micro switch) or a shorted bulb. You have either a shorted bulb or bad socket. From my experience, it's the bulb. Just because it may seem to start to come on when you open the door, it's most likely bad. At least it not expensive.
Please rate solution
Aug 28, 2009 | Microwave Ovens
Replace OTR Microwave
Thanks for responding. It is a EWave KOT-152UW. I think EWave is part of Magic Chef. I think it is the door switch. When I opened the microwave, the circuit breaker tripped. I reset the circuit breaker, and it worked for several days, but the last time, the microwave went dead. The reason I want to use the same bracket is it has through the wall (horizontal) venting to the outside, and I am not keen on trying to cut more holes.
Nov 04, 2008 | Microwave Ovens
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Microwave Ovens Logo
1,156 people viewed this question
Top Daewoo Microwave Ovens Experts
William Miller
William Miller
Are you a Daewoo Microwave Oven Expert? Answer questions, earn points and help others
