Question about Irwin 2035108 Aluminum Box Beam Level
How can I replace the hand hole (hand grips) on my level?
  • 142 Answers
To the best of my knowledge, you can't
Posted on Jul 13, 2009
I can't get the chuck to work or open to change the drill bit. I have really tried!
Hi Alice:
Is this a "key"? If so, put it in place with the drill pointing up and the key handle pointing level and towards you. A light tap with a hammer on the key handle should loosen it.
If it is a "manual grip", try putting the drill in reverse, and at low speed. Hold the drill handle with your right hand, and hold the grip firmly (really firmly) with your left hand, and squeeze the trigger. It should release the chuck. If it doesn't, try putting a pipe wrench on the grip.... gun facing away from you, wrench from the top, handle on right. gently tap on the wrench handle should loosen it.
Cheers.
Apr 08, 2016 | Ryobi Drills
Installing Harley Davidson Chrome & Rubber Hand Grips Large 56263-96A
Sounds like the throttle lock is possibly binding up. Remove the right grip. There should be a little half moon shaped piece of plastic in there at the bottom of the switch housing. This plastic piece will have a small hole in the outside edge. This hole has to be placed over the pointed end of the throttle stop. The throttle stop is the plastic star wheel on the outside of the bottom of the right switch housing. There is a small metal Jesus clip on the inside of the switch housing. This clip is supposed to hold the stop from being turned completely out of the switch housing. It's possible the clip came off and is wedged in there.
May 20, 2012 | 2005 Harley Davidson FLSTC - FLSTCI...
Can i replace the upper lock on my quinny zapp stroller?
Hi
The hand grip connection bar on the Quinny Zapp can be replaced but it is fitted with pop rivets so it is listed as a Level 3 repair, which means the chassis needs to be sent to our engineers for the repair to take place.
Which country are you in?
May 07, 2012 | Quinny ZAPP Stroller
How do i replace the hand grip on guardian red dot crutches?
I had the same problem, but i found an answer.
have a friend with 2 good feet help you with this.
Turn the crutch upside down and place armrest on the ground.
Stand on the outside edges of the armrest and pull crutch upward. The armrest is not glued to the rest of the unit. It's just a snug fit. Once the armrest is removed, the hand piece can be removed.
Now comes the struggle to remove the damaged rubber hand grip, and put the new one on, took me about 5 minutes to do this step.
Then reverse what you've done, put the hand grip back on the crutch, put the armrest back on, turn the crutch upside down, and push the armrest back into place.
Hope this helps!
Jan 01, 2012 | Optics
How do I change the line on my 25 cc homelite zip start trimmer
1) Use a pair of vise grips to open the wheel on the bottom of the feede;
2) Remove the wheel, taking care not to lose the screw inside it;
3) Remove the outside wheel, feed line into one of the interior wheels and wind it around until the wheel is full following the direction of the arrow on the outside. Leave enough line (4 - 6") to feed out the holes;
4) Repeat for other wheel;
5) Replace wheel, feeding excess line into outside wheel holes on wheel frame still attached to weedeater;
6) Hold wheel together tightly and reattach wheel hub. Hand tighten only as it will tighten itself with use and require vise grips to remove again.
Hope this helps.
Nov 01, 2010 | Homelite Mighty Lite Lawn Trimmer
How to replace right hand throttle grip 2003 ultra
Remove the switch housing screws and spread it away. Loosen the adjuster locknuts on the throttle cables and adjust cables in, this will allow you to lift the cable off of the throttle grip. Be care full not to lose the barrels.( the small round caps on the end of the cable.) Assembly is the reverse. Make sure to check proper operation of the throttle before starting the bike.
Apr 06, 2010 | 2003 Harley Davidson FLHTCUI Electra Glide...
Samsung camcorder SMX-F34BN. Need to replace hand grip. Have replacement part, but do not know how to remove old and replace. Help
Follow the steps to replace hand grip :
Remove two screws near battery
Remove the tiny screws on each side of the hand grip release.
Once screws are removed, gently prise of button. Do not attempt to remove the lever.
Remove the four screws holding the eyepiece in place.
Once the four screws are removed, pull out the eyepiece, notice the button that operates the cartridge access.
On the top of the camera, using a pointed tool and light hammer, gently tap in an anti-clockwise direction.
Now slowly lift from the front, taking care not to damage the power zoom buttons on the other side, and slide towards rear of camera to remove cover.
With the camera facing you, remove screws below the lens, then gently remove the side cover above the hand grip.
Use a blade to scrap away glue around the two screw heads, then remove screws. Then, using a pointed tool, insert into one of the small holes, and using a light hammer, gently tap to unscrew the hand grip screw.
Thats it hand grip is removed . Now replace the hand grip and follow the above steps in vice versa .
Hope this helps .
Mar 29, 2010 | Cameras
How to change the fan blade that is used for the suction on the vacuum cleaner?
You will need to get a genuine fan kit form a service center, then elevate the vac and remove the carpet head. From the back of the housing there will be a series of screws facing forward into the front housing, several are counter sunk. Removing them will replace the front face of the housing. You should not have to pry.Look for partly hidden screws
The belt shaft is threaded, once removed pay attention to washer and spacer location in front and back of fan.
Grip the old fan by hand and the shaft with a set of vice grips or slid a long nail through the fan shaft hole to unscrew the shaft.
Installation is reverse order with the shaft and screws hand tight... Post back to say how you make out
Oct 10, 2009 | Kirby G4 Bagged Upright Vacuum
I have an older Huffy, with grip shifters. The shifter (left hand) is almost impossible to shift the chain from the small sprocket to the middle or largest sprocket. The deraileur seams to be moving freely...
First, try to isolate the trouble like you have... obviously the derailieur is moviong freely. Next, I would disconnect the shifter cable from the derailieur (make sure to mark previous position of cable) Next, shift the left hand grip to see if the grip moves freely, you've already replaced the cable, soooooo, disassemble the grip and grease or replace the grip shift unit...hope this helps
Jul 13, 2009 | Huffy Alpine 24 Youth All-Terrain Bicycle
Brake assembly
If you loosen the wire that is connected to the gripping machanism first , you will have long enough wire to put it throu the brake grip first then tighten it back at the wheel gripping area.
Dec 01, 2008 | Huffy Disney Princess 16 in. Girls Bicycle
Irwin 2035108 Aluminum Box Beam Level Logo
Top Irwin Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an Irwin Measuring Tool and Sensor Expert? Answer questions, earn points and help others
