SOURCE: finding oil inside spark plug chamber
hi you will find that the rocker cover is proberbly leaking into the the plugs housing replace the rocker cover gasket yates210456
SOURCE: i have an oil leak in a spark plug chamber how do is fix it
depends where the oil came from.of it has leaked down from a valve cover gasket,that is not hard to fix.if it a leaking valve seal that is expensive and if the head gasket is leaking,expensive.look at the outside edge of the valve cover,and check the edge for oil.if there is alot of oil,by the time the plug is unscrewed oil can go inside.the oil would burn off,so if there is oil inside it is dripping down probably from a valve seal.take off the valve cover and inspect the seals they are probably no good.there are 2 seal sets,one is in the valve cover,and that results in oil on the outside of the plug,and the actual valve seal which results in oil in the inside of the engine.
SOURCE: Oil in #2 spark plug chamber. How do I fix
This is not good. There are two ways to get oil in your cylinder..best case, valve guides..requiring a head job, worst case, blow by the piston, requiring an overhaul. Wish the news was better. Good Luck! I hope you find this very helpful!
