Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint wf860 my washer stopped mid cycle and displayed f 04 something I have never seen before, it is full of water. Could you please advise. Many thanks Flasham
    Novelist:
    Champion:
  • 244 Answers
Not sure about the f04 code but if its still full of water try putting the washer onto a drain cycle if the water does not drain then your pump is either blocked or faulty to check if its faulty pull the washer outnow take the drain hose and place into a bucket low to the floor if it comes straight out then the pump is faulty what it is is they have a magnectic part which goes down if the water doesnt come out its blocked you will have to take the washer outside tip it backwards but dont put it on its back now undue the sump hose which is situated in the centre of the drum pull it the water will drain out now undue the 2screws under the pump pull out undue the pipes you should see the blockedge if not could be in the drain hose itself m8 let me know how you go on if the pump needs replacing shouldnt cost no more than £20
Posted on Nov 17, 2007
The most likely cause is the sump filter blocked it is located in the bottom hose under drum.
Regards
Advisor
Hotpoint ultima WDD960, My washer dryer has stopped mid wash cycle annd is displayinh F:o5
  • F05 - Pressure switch jammed on full - Check pump for blackages.
  • The best thing is to see if it is filling and draining properly
Oct 28, 2011 | Hotpoint Ultima WF860 Front Load Washer
Machine stopped mid cycle with water still inside and the panel is saying FO/5
F05 means you have a pressure switch fault, check the pressure chamber or pipe also the wiring from the switch. For more Hotpoint, Creda or Idesit error code definitions use this link
Mar 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
Demo mode
To fix, hold the Start Button in until it completes the full cycle about 3 mins. It should say end or something similar then start as normal.
May 10, 2009 | Hotpoint Ultima WF860 Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
F-04 on my screen
F04 means pressure/water level switch jammed on empty
Check pump and filter located at rear of washer behind removable panel.
Please rate my solution.
Thanks.
May 04, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WD860 machine has stopped mid cycle displaying f-04 I have taken the panel off the back and cleared out the tube from the drum by removinng the clip but this has not worked. On thurning the...
f04 is a pressure switc problem.
take the lid off and check the clear plastic hose is attached to the bottom of the pressure switch, a round part with wiresand the other end to the sumps breather tube.if it is and there are no holes or splits in the tube it may need replacing.
Feb 18, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint aquarius shower
water pump clogged with debry clean out
or the your home lost preasure in pipes
Mar 25, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima WT9 60
the internal circuit board has come loose, switch off power take the top off and tighten the connections on the plugs inside
Feb 01, 2008 | Hotpoint Ultima WF860 Front Load Washer
HOTPOINT ULTIMA SUPER SILENT ( WF 860 ) 1600 SPIN SPEED.
I read that someone has a problem with F-03 on the display. I have seen this for the first time on my hotpoint wf860 1600 spin. I read the manual the only thing I can think of maybe an unbalanced load in the machine. Albeit the manual is not clear about this. P21 automatic features unbalanced load warning.
Sep 04, 2006 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
449 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
