Question about Kitchen Appliances - Others
Need plastic timing belt drive pulley for Breville BB 380
Need plastic timing belt drive pulley for Breville read maker BB 380. Original has split.
  • Jon Fletcher Nov 25, 2009
    Thanks, but part was for my Son in Law's machine some 6 months ago and after failing to find the part, he bought another m/c
I may have a machine you can use for parts. I have a BB380 which mixes the dough OK but trips the electrical core balance switch in the house when it goes to bake - so I was taking the pan out and bakeing it in the gas oven. But I got tired of resetting all the electric clocks in the house and bought a new machine. Would this be of assistance?
Posted on Nov 25, 2009
Hydrostatic trans getting weak going forward. Won't lug engine and have to go to low gear to pull hills it used to pull in B. Reverse is still strong. 380 hours, have change filter, oil looks good
The big pulley on top of the hydro axle is driven by a rubber belt.
V Drive belts pull from the two sides of the belt, as they wear down the bottom of the belt gets lower in the pulley making it loose and narrower then original. There is a idler pulley mounted on a arm with a big spring that pulls it tight to make belt not slip
Mar 14, 2016 | Garden
Breville BB 400 Bread maker instruction manual
for any breville product free phone 0800525089 for a PDF copy to download. k
Oct 29, 2012 | Breville BB400 Ultimate Bakers BB-400...
Need Manual to use Bread Maker
There are a couple of online sources for the Breville BB290 Baker's Oven Instructions & Easy Bake Recipe Book. You can view at the first site below but to download a copy both sites charge a fee. See here:
http://www.scribd.com/doc/39035197/BB290-breadmaker
or
http://manualfox.com/link/breville.htm
Trust this is helpful.
Jul 24, 2012 | Kitchen Appliances - Others
Maytag Neptue frontloading washing machine model MAH5500BWW stopped spinning (machine is about 15 years old). I opened up the back and saw the drive belt was thrown. Reinstalled it (perhaps badly) and...
i would say you have a warped main pulley, run the machine in spin,watch it early to detect any wobling in the belt should be no sideway movement. also check main pulley is tight with no lateral wobling.
Dec 21, 2010 | Washing Machines
My pro form 380 stops while I am walking
Either the walk belt is loose or the front roller pully has spun. In order to determine which one, you need to remove the moter cover and watch the drive belt and front roller while you walk, try to stop the belt and see which one stops. If the walk belt stops and the front drive roller keeps turning, then you need to put a couple of turns on the rear allen bolts. If the roller stops when the walk belt stops, see if the drive belt(small one going to the motor) stops as well. If the drive belt turns fine,but the walk belt and the front roller stop, you need to replace the front roller, because the plastic pully that is connected to the roller, is pressed on and cannot be tightened.
Hope this helps
Nov 10, 2010 | Proform 380 Treadmill Walking Belt
Belt tensioner has hairline split causing water to leak and overheat.2000 buick lasabre 3800 engine,380 motor
yes belt tesioner is internal part of cooling system it has two plastic elbows with o-rings that crack crumble and deterioate haven,t seen crack in aluminum part though but remove belt by releasing tensioner remove alternator and idler pulley then remove bolts holding tensioner assembly to head and block this entire thing can be purchased thru napa i know but do not reuse the plastic elbows and make sure to lubricate the o-rings on new elbows so when istalled puthe the elbows in the assembly first lower it in place lined up with waterholes and gently push in and slide in place
Aug 05, 2010 | Buick LeSabre Cars & Trucks
I need 2004 Hyundai XG350L Service/repair Manual
3.5L Engine
Remove or disconnect the following:
  1. Negative battery cable
  • Engine coolant
  • Water pump pulley bolts
  • Alternator bolt, loosen only
  • Water pump pulley and drive belts
  • Crankshaft pulley
  • Timing belt cover(s)
  1. Turn the crankshaft until the timing marks on the camshaft sprocket and cylinder head are aligned.
  2. Loosen the timing belt tensioner bolt and turn the tensioner counterclockwise as far as it will go. Tighten the adjusting bolt.
  3. Mark the timing belt with an arrow showing direction of rotation.
  4. Remove the timing belt.
  5. If defective, remove the timing belt tensioner.
Timing belt sprocket alignment mark positioning for belt removal and installation—3.5L engine
To install:
  1. If necessary, install the timing belt tensioner.
  2. Attach the top of the tensioner spring on the engine coolant pump pin. Ensure the hook on the pin is facing down and the hook on the tensioner is facing away from the engine
  3. Rotate the timing belt tensioner to the extreme counterclockwise position. Temporarily lock the tensioner in place.
  4. Align the timing marks of the camshaft and crankshaft sprockets.
  5. Install the timing belt on the crankshaft sprocket, then onto the rear camshaft sprocket.
  6. Route the belt to the coolant pump pulley, the front camshaft sprocket and the timing belt tensioner.
  7. Apply force counterclockwise to the rear camshaft sprocket with tension on the tight side of the belt and check that timing marks are aligned.
  8. Loosen the tensioner bolt 1–2 turns and tighten the timing belt to a tension of 57–84 lbs. (260–380 N).
  9. Turn the crankshaft two turns clockwise.
  10. Readjust the sprocket timing marks and tighten the tensioner bolts.
  11. Install the timing belt covers.
  12. Install the crankshaft pulley and tighten to 108–116 ft. lbs. (150–160 Nm).
  13. Install or connect the following:
    • Crankshaft pulley
    • A/C compressor belt
    • Water pump pulley
    • V belt
    • Negative battery cable
    • Engine with coolant
Feb 10, 2010 | 2004 Hyundai XG350
My cuisinart bread maker is making a clicking sound during the knead cycle but not turning the spatula in the pan. I have lifted the pan and the bottom part of the machine is not turning at all- just...
If the motor shaft is not turning it could be the belt has fallen off the pulley or the pulley is slipping, or the motor is broken. The motor, pulley and belts are located inside the base of the machine. Hopefully it's just a loose belt. Hank
Jan 27, 2010 | Cuisinart CBK-200 Bread Maker
Need to know the correct tamper size for a Breville 800ESXL ??
I found this one on ebay:
http://cgi.ebay.com/TERRYS-ESPRESSO-COFFEE-TAMPER-50-55mm-DUAL-SIDES_W0QQitemZ330319118719QQihZ014QQcategoryZ20671QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
the 50mm side works perfect for the Breville 800ESXL and the material matches the machine. It takes up less space than the original spoon/tamper combination and sits nicely on the warming surface when not in use.
Mar 29, 2009 | Breville Die Cast 800ESXL Espresso Machine
Kitchen Appliances - Others Logo
138 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
