Question about Garden
Gas is not getting into the carb.
When you add gas to carb it starts but as soon as there is no more gas in carb it dies. Is there some kind of diagram that could help me check the carb?
  • 37 Answers
Follow the fuel line down to the carb. There should be a filter inside the carb that is probably clogged. Then make sure gas flows through the line from the tank to the carb.
Posted on Jul 13, 2009
1985 ford f150 starts, but dies if gas pedal is not pressed, no problem starting, but as soon as I put in neutral it dies . . . tries to keep running but dies
Could be as simple as a vacuum leak from old hoses.
The carb WILL become DAMAGED from ethanol fuel.
DO NOT use that in a vehicle that sits.
Some premium gas has no ethanol,find it and use only it.
A good engine an worth spending a little money on.
May 01, 2017 | 1985 Ford F150
68 302 engine with a elect point conversion kit, engine when hot after shut off for about hour hard starting . have to pump gas befor it catches. it will start right away when hot if you restart it as...
What you describe sounds like the fuel in the bowl of the carb is evaporating. A thing to check if you are able is the fuel pump. A pressure test on the fuel pump will determine if the diaphragm in the pump is able to hold pressure after the 302 is shut off. A hot carb will evaporate some fuel in the bowl after shutdown. the pressure of a good fuel pump will add fuel as necessary.
If the carb bowl is empty when trying to start it will take a few turns of the engine a a couple pumps of the gas pedal to get gas to the engine.
This is just a suggestion to try. Sort of test before you buy kind of thing.
Good luck and great engine.
Wayne
Jun 27, 2011 | Ford Mustang Cars & Trucks
I have a 1994 Intruder. It only starts and runs
The hot side is running way too lean. Have your carbs synchronized may help. Try draining the bowls. Good luck.
May 28, 2010 | 1994 Suzuki VS 800 Intruder
MTD 5hp. Starting and running only while I spray
Remove the fuel line from the carb. Drain fuel tank and blow thru fuel line until clear. If you use compressed air be very careful to use LOW pressure. I just use my mouth. reinstall fuel line replace the fuel filter, add a new spark plug for good measure and refill gas tank
You should be chipping away right soon!
Mar 04, 2010 | Garden
1992 Pace Arrow Motor Home 454 Chevy...not getting fuel to start
After you dump the fuel in the throttle body it will continue to run on its own or die as soon as it burns up all the fuel you dump in? Do you have access to (Noid lights)? Are both plugs attached to the distributor?
Jun 24, 2009 | 1985 Chevrolet Chevy
Bike turn off while driving
I was on my way home from work when I stopped at the stop light and when I went to take off my bike just died. It started right back up but as I gave it gas it would die again. I managed to roll it out of traffic into a parking space. I tried the choke the fuel valve, but nothing worked. It would idle, but as soon as I would give it some gas it would just sputter and die. I got a ride to my house where I got my truck and came back to my bike. I started it up and soon as I gave it some gas, it died. I started it up again and gave it some gas and then it started working just fine. I revved it a few times, but it wouldn't die again. I drove it home and didn't have a problem. It seems to be running fine now. What the heck?? It only has 693 miles on it. It has almost a full tank of gas. What could possibly be wrong?,It's fuel or air related. If your bike didn't have any issues at all, no minor symptoms until it fell on its face like that, I'd wager something worked its way loose. Could be something is preventing fuel from reaching the carbs or something rattled loose in your airbox or carb boots. If something blocked off your air filter it would show those symptoms, or if you suddenly had a huge vacuum leak from a carb boot coming undone. I'd start by verifying you have fuel in the carbs by attaching a length of tubing and opening the drain screw at the bottom. Fuel comes out of your carbs, look elsewhere. No fuel, find out why it's not getting to your carbs. Perhaps your fuel line kinked.,,,
Nov 10, 2008 | 1984 Laverda Alpino 500
My bike die
my bike just died. It started right back up but as I gave it gas it would die again. I managed to roll it out of traffic into a parking space. I tried the choke the fuel valve but nothing worked. It would idle, but as soon as I would give it some gas it would just sputter and die. I got a ride to my house where I got my truck and came back to my bike. I started it up and soon as I gave it some gas, it died. I started it up again and gave it some gas and then it started working just fine. I revved it a few times, but it wouldn't die again. I drove it home and didn't have a problem. It seems to be running fine now. What the heck?? It only has 693 miles on it. It has almost a full tank of gas. What could possibly be wrong?,it's fuel or air related. If your bike didn't have any issues at all, no minor symptoms until it fell on its face like that, I'd wager something worked its way loose. Could be something is preventing fuel from reaching the carbs or something rattled loose in your airbox or carb boots. If something blocked off your air filter it would show those symptoms, or if you suddenly had a huge vacuum leak from a carb boot coming undone. I'd start by verifying you have fuel in the carbs by attaching a length of tubing and opening the drain screw at the bottom. Fuel comes out of your carbs, look elsewhere. No fuel, find out why it's not getting to your carbs. Perhaps your fuel line kinked.,,,
Nov 10, 2008 | 2007 Highland Highland Outback
Bike died
Nov 10, 2008 | 2003 ATK 260
Garden Logo
345 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
