Question about Epson LX-300 Matrix Printer
LX300 + II Printer Head stack in the middle
My LX 300 + II the printer is not going from left to right it stocks in the middle after initialization. Going to Left side then stock in the middle. It doent go to the right side. And when you manually push, it slide to the right.
    President:
  • Epson Master
  • 1,447 Answers
It is the problem sensor you open left sensor then folow what condition it then solve i wish you are success
Posted on Jul 13, 2009
LX300+II when switch on all lights are blinking and 5 beep sound and the head move only a little bit..what suppose to be the problem?
Check the printer for dirt inside or any broken levers or gears and clean the printer. It the problem persists take it in for repair.
Aug 08, 2011 | Epson LX-300+ II Matrix Printer
IM HAVING DIFFICULTY REMOVING THE INK CARTRIDGE FROM MY EPSON LX-300+II, THE RIBBON MUST BE JAMMED ON TO THE PRINT HEAD
first pls remove the power cable after >Open the top plastic lid. > Slide the printer head to the middle of the printer. > Pull the printer cartridge up and out evenly.
Feb 22, 2010 | Epson LX-300 Matrix Printer
My epson LX-300 printer got wrong. it's printed strange character seem wingdings character. i used continous form, LX300 pulled the paper over n over. pls tell me how solve it tks
either corrupt drivers, or bad print head. Try reinstalling the drivers for the printer. Otherwise, the problem will be more expensive to fix then to replace the printer.
Apr 30, 2009 | Epson LX-300+ II Matrix Printer
EPSON LX300+II PRINTS THE SMALL FONT & LEFT SIDE
change the fonts of the printer by pressing the font button on the panel (Refer user manual for more details)
Feb 04, 2009 | Epson LX-300+ II Matrix Printer
No power on epson lx300
no power in printer give solution how to repair this
Jan 19, 2009 | Epson LX-300 Matrix Printer
Print output
I had the same problem when printing on Windows XP Pro or Vista Business OS while the prinout was fine using DOS or Linux environment. My problem was that every other line the fonts wiggle sidewards towards the right as if it were on italics.
To correct this, simply download the LX300-II ESC/P driver then update your printer driver by re-installing it using your device manager.
Apr 16, 2008 | Epson LX-300+ II Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
DOT MATRIX PRINTER PROBLEM
Hi, to perform a self-test on an Epson LX300 > start with the power switch off. Press LF/FF (middle switch), without releasing that button, power on the printer. If everything is ok it will print a sel-test page. To do a Hex Dump > start at power off, simultaneously press Font and the LF/FF buttons (left & middle buttons), then power on; to revert the printer to its factory default setting(s) > start in off position, press Font (left) button then power on. (Slightly different with an LX300+) Hope this works out for you. Cheers.
Apr 19, 2007 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
323 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
