Question about Fujitsu Siemens LifeBook S-6000 Notebook
Fujitsu siemens s6120 laptop is locked. I am unable to unlock.
My Fujitsu siemens s6120 lifebook is locked. When i press the power-on button it displays a key sign on the led display, the laptop has been locked. I have tried all combination of numbers but no luck. Kindly advise solution to unlock.
How can i find the mac address of s6120
1. Click the Start Menu
2. Click on "Run"and type in cmd
3. Type in ipconfig /all
4. If you find your connection, it should say Physical Address!
-JH
Sep 01, 2013 | Fujitsu Siemens LifeBook S6120 Notebook
Lifebook s6120 does not start - dead i can't turn it on do i have to clean the motherboard or something else plese help!!!
unplug from the power and also take out the battery.
now hold the power button down for 30 seconds.
put the battery back in and hook up the power and try to power it on again.
Mar 24, 2011 | Fujitsu Siemens LifeBook S6120 Notebook
Will not load anything it says error loading operating system
Have you tried booitng into safe mode? hold F8 down after laptop finishes post test. this will then go to a black and white screen and you need to select "safe mode". also are there any cd in the dvd drive? and the hard drive is set to boot first in bios.
Jan 18, 2011 | Fujitsu Siemens LifeBook S6120 Notebook
When i want to install windows it doesnt show mine hard drive. i lookd in bios but it says none,i tryd to replace the hard drive but still nothing. mine laptop is an fujitsu siemens s6120. hope u have...
Make sure that the HDD connector are connected properly.
The power connection are OK? Set the BIOS as default and check.
Please post your feedback and Vote if the problem resolved as per your satisfaction
Sep 23, 2010 | Fujitsu Siemens LifeBook S6120 Notebook
3 others indicators start blinking !
Dear friend,
Just follow the instruction.
1. After press power button for turn on press F8 key.
2. You will find few option there. Just select these mention option " Last know good Configuration ...." use by your up/down arrow on your keyboard.
3. Press enter there.
4. your will see the system asking you for which OS you want to use. If you have only one OS then just press ENTER there or select the OS and enter.
Then just wait and watch what's is going. If the same problem then contact me again here in Fixya i will give you another way to solve the problem. Thanks.
Feb 03, 2010 | Fujitsu Siemens LifeBook S7020D Notebook
What do you do if you have forgotten your password for you "Fujitsu Siemens" Laptop?
Turn it over, open it completely up, and remove the battery from the motherboard for 30 seconds.
Oct 20, 2009 | Fujitsu Siemens LifeBook S6120 Notebook
My wifi wont work. I dont have the driver. the ones i downloaded wont drive it. pls give me a hint on what to do? I use lifebook s6120 fijisu siemense
There are some wireless drivers at the bottom of http://www.drivershq.com/Drivers/Fujitsu-Siemens/Lifebook/S6120/24971/45495/48955/Drivers.aspx
Oct 12, 2009 | Fujitsu LifeBookS6120 Notebook
Fujitsu siemens notebook s6120 laptop switching itself off
the processor fan might not be working due to which the laptop gets heated up and switches off. if u dont replace it u might end up burning the processor.
May 17, 2009 | Fujitsu Siemens LIFEBOOK S-6120 PC...
Fujitsu Siemens LifeBook S-6000 Notebook Logo
879 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Lee Durbin
Lee Durbin
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
