Question about Westinghouse SK-19H210S Television
HDMI port not working
I'm having the same problem. When I play my PS3 using the HDMI port, the screen used to randomly go blank for a few seconds before returning to normal. Usually if I unplug the HDMI cable and plug it back in it works for the rest of the day. But today I turned on my PS3 and there was no picture or sound. I tried changing setting from the PS3 and from the TV, but nothing worked. I unplugged the TV for a while then plugged it back in and restored the TV to its factory default setting, but it still didn't work.
I have the same problem - its a HDCP handshake issue. Sony says the firmware in the Westinghouse TV needs to be updated - Westinghouse says that they have firmware updates for some models depending on your TV's serial number, otherwise they are working on firmware updates for the rest of us that should fix the problem. Call Westinghouse to see if you can get updated.
Posted on Oct 26, 2009
LG Tv M227WDL HDMI black screen
If the HDMI input is failing you will need to ring Customer Support or Get a New TV because if its not outputting then The HDMI may not get Prosecced (sorry about spelling) And make sure you have checked its the Correct port and that there is no Blue-Tac or dust in the port ( that ussually solves this) If all else fails Use a Hairdyer and give it a Big clean :D
Mar 14, 2014 | Televison & Video
Denon AVR and PS3 issues
Sounds like a problem with the digital board. Expensive fix - hope it's still under warranty.
Jul 02, 2013 | Audio Players & Recorders
PS3 HDMI - Sony Bravi KDL-40V2000 Problem
  • Have your ps32_bing.gif in standby mode (red light).
  • Now, press andhold the power button in the front down. Your ps3 will beep twice. Letit go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all!
try this
May 08, 2010 | Sony Playstation 3 (PS3) Console
My xbox360 wont play movies my ps3 blank screen
you need to configure both to hdmi or not to hdmi in order to get any picture out whatsoever on the xbox its a switch on the video and for ps3 it needs to be done in the settings but they both need to be done before changing tvs otherwise
Robb
Apr 28, 2010 | Samsung DLP HL-P5663W 56" TV
I normally play my ps3 through HDMI. I am currently in a hotel trying to use it on a tv with only component inputs. How can I change the video setting without seeing the menus?
all you need to do is connect your ps3 to the tv using your hdmi cable and hold the on button on the ps3 for 6 seconds. You will hear the initial beep then a second beep, this will reset the settings on the system and it will change the settings to match the tv being used.
Apr 06, 2010 | Sony Playstation 3 (PS3) Console
PS3 screen flash / sound cut-out
The PS3 has an issue with what's called the "HDMI handshake" between the PS3 and the TV. The PS3 does not even realise that this is happening. What you might try to do is turn the system on, play a game, and when the flashing and no sound occurs, unplug the HDMI cable from your PS3, wait a few seconds and plug it back in. This may resolve your issue. If it doesn't work, try component cables, there is no known issue with this problem occuring with this type of connection. Good luck!
Aug 20, 2009 | Video Game Consoles & Games
Blank Screen using HDMI-DVI cable for PS3
Sounds like your LCD monitor isnt HD compatible.
Mar 17, 2009 | Hanns.G Corporation HW191D 19" LCD Monitor
I've just purchased an InFocus x10 and i'm having problems playing my ps3 on it. Playing movies through my dvd player is fine but when i switch it over to the ps3, it is having problems detecting the...
I have the same problem. I actually get the initial language choice screen showing up on my X10 and then once I select a language, the PS3 says that it detects an HDMI device and do I want to get sound and video through HDMI. I say yes, and screen goes blank. Saying no, screen also goes blank.... Any solutions to get past this screen?
Aug 29, 2008 | Televison & Video
Hdmi
I can't be exactly sure without more information, but it sounds like you ps3 is outputting from another port. My ps3 originally was outputting from the component/composite cable port so in order to use the hdmi output I had to do a soft reset. That makes the ps3 sense what cable is plugged into it and automatically output through that port instead of using whatever is the saved setting.
With your ps3 turned on hold down the power button for a few second until it beeps and flashes 3 times (should be about 5 seconds). You might have to try it a few times to get it to work, but you should get picture and be able to adjust the settings on the ps3.
Dec 08, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
961 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
